| Re: Simple questions as well...
[Re: Wrinkledpants]
#34366 06/14/04 06:15 AM 06/14/04 06:15 AM |
Posts: 12,310 South Carolina | 1) You can loosen the rudder in the casting simply by loosening the through bolt that secures the rudder (the same bolt that it pivots on).
2) Class legal purchase on the main sheet is 7:1. I have 7:1 on my 6.0 and need more (class legal on the 6.0 is 8:1).
3) Boards go all the way down (to the stopper rope) while sailing upwind. Bring them about half way up for sailing downwind. You may find it usefull to use a permenant marker and put lines on the daggerboards to reflect these positions.
Jake Kohl | | | Re: Simple questions as well...
[Re: Wrinkledpants]
#34367 06/14/04 06:41 AM 06/14/04 06:41 AM |
Posts: 324 South Florida | Wrinkledpants,I think this one is easy.
1. All the way down is the correct position for the rudders, although you may want to rake them forward for a more sensitive tiller or backward for a stiffer feel. I had to remove my rudder blades and sand them silightly at the bolts because the person I bought the boat from had painted them and the paint was causing them to stick. If the rudders are not all the way down you will have more of a struggle with the tiller, especially in that type of wind. And the lack of a jib would tend the boat to point into the wind, so you would be fighting this also. When I'm sailing out in shallow water, and I have the rudders partially up the difference in the ammount of pull is HUGE. To the point that in heavier wind I have litteraly had to grab the cross bar with both hands, dig a heel into the tramp lacing and pull like hell.
2. It seems obvious that a higher ratio is what you need but there may be a technical or class legal reason why you can't.
3. The daggerboards go all the way down (unless you are in shallow water). And of course there will be many who'll tell you that the windward daggerboard goes up so as to reduce drag. Sailing solo I rarely have time to think about this!
Anyway, Gotta go work. Have a good one
Fred F
(ex Hobie 18)
[Re: dickcnacra52]
#34375 06/14/04 09:34 PM 06/14/04 09:34 PM |
Posts: 12,310 South Carolina | Properly adjusting the fore and aft position of the jib blocks ensures that your jib draft is steady from the top to the bottom which ensures that your jib is at full power. The best position can change depending on wind strength and the shape/condition of the jib. In order to determine the best fore/aft position of these blocks you should have both an upper and lower set of tell tales properly installed on the jib. While under sail, gradually round your boat down onto a deep reach and watch to see when the outer tell tales stall in relation to each other. If the upper is stalling before the lower, it means the top of the sail is flatter than the bottom and you need to move your jib blocks back slightly in order to get more sheeting pressure toward the bottom of the sail. If the bottom stalls before the upper, it means that the bottom of the sail is flatter in relation to the top and you need to move the blocks more forward in order to get more sheeting pressure toward the top of the sail. You can also check your adjustment by luffing the boat up into the wind to ensure the inside tell tales also react in the same even manner.
On boats with limited fore and aft adjustment of the jib blocks (like ones with the blocks attached to the front beam), it's possible to make the same kind of sheeting angle adjustment by raising or lowering the position of the jib on the forestay.
Jake Kohl | | |
545
guests, and 38
