Looking for Nacra non-captive mast base #34931
06/29/04 09:21 PM
06/29/04 09:21 PM
Québec, Canada
CharlesLeblanc Offline OP
Québec, Canada
Hi there, I just moved and I am now in a fairly remote location (50.27N-66.44W) and I want to modify my current Nacra 5.2 to make easier to set-up and sail singlehandled.
Stepping the mast and righting the boat are a big concern for me. I could try to build a mast hinge and a mast stand to try to step the mast alone but I would rather spend my free time sailing instead of building and adjusting such a device.
I am looking for an old, used and beat-up Non-Captive mast base. I would like to install a 24’ mast and sail on my boat.
I already have the 24’ mast, sail and enough spare rigging but if I would find a mast base, I would be able to setup my boat like a H14 to make mast stepping much easier.
I do not mind is the mast step is damaged as long as the cup is still ok, my new mast will have a smaller mast section so there will be some tinkering.
I am simply trying to salvage what’s left of my sailing season.
If you have a mast base lying around, please contact me and we will try to work something out.
email using the Catsailor message or directly at
leblancc_99@yahoo.com
Charles Leblanc Nacra 5.2 #26
Re: Looking for Nacra non-captive mast base [Re: CharlesLeblanc] #34932
06/30/04 08:05 AM
06/30/04 08:05 AM
Magnolia, Texas
NacraMike Offline
NacraMike  Offline
Magnolia, Texas
Charles, I changed out my 5.2 to a captive mast base last year. I have the old non-captive with the old rod and bolt somewhere. I will take a look this evening and see if I can find them. I'd be more than happy to send it to you (no charge) if I can find it. You know that the ball is smaller on the non-captive unit although still available but expensive.
Re: Looking for Nacra non-captive mast base [Re: NacraMike] #34933
06/30/04 08:35 AM
06/30/04 08:35 AM
I upgraded my 5.2 as well...I'm quite sure I no longer have the casting but I might have the old post if you still need it (no ball though).
Re: Looking for Nacra non-captive mast base [Re: NacraMike] #34934
06/30/04 05:32 PM
06/30/04 05:32 PM
Québec, Canada
Québec, Canada
Mike,
Thank you for your help, my Nacra 5.2 is still completely set up with the non-captive system with the small ball. I did own a Nacra 5.7 before and it was with the captive mast system so I can tell the difference between the two systems.
I almost did the upgrade last year but I think that the one person mast stepping will be easier with the non captive system and the vertical pull technique.
Re: Looking for Nacra non-captive mast base [Re: CharlesLeblanc] #34935
07/01/04 08:39 AM
07/01/04 08:39 AM
Magnolia, Texas
NacraMike Offline
NacraMike  Offline
Magnolia, Texas
I found it Charles. Click on my username and email me your shipping address and I will get it off to you.
Re: Looking for Nacra non-captive mast base [Re: NacraMike] #34936
07/01/04 09:24 AM
07/01/04 09:24 AM
Do you still need a post (I forgot to look)?
Re: Looking for Nacra non-captive mast base [Re: CharlesLeblanc] #34937
07/02/04 12:59 PM
07/02/04 12:59 PM
Magnolia, Texas
NacraMike Offline
NacraMike  Offline
Magnolia, Texas
Charles, mast base is on it's way to you by USPS.
Enjoy.
0 registered members (), 2,782 guests, and 286 spiders.
