Book to improve skills? Tell tale placement? #35088
07/05/04 11:12 PM
07/05/04 11:12 PM
Minneapolis, MN
duganderson Offline OP
Minneapolis, MN
I'm a recreational cat sailor (H21 sport cruiser). Is 'Catamaran Racing for the 90S' the best book for improving my skills and becoming a better sailor...I checked it out at the library and may buy it.
Also, is the tell tale placement recommended in the above book the best for a recreational but wanting to improve sailor?
Thanks, Doug
Re: Book to improve skills? Tell tale placement? [Re: duganderson] #35089
07/05/04 11:58 PM
07/05/04 11:58 PM
Andrew Offline
Andrew  Offline
Yes, that's the best book on the market, bar none. The telltale placement is hard to beat - think about it: Racers want their boats set up the simplest way possible without giving up speed. They want to sail as efficiently as possible, as much of the time as possible, and they want the best performance they can get. Just because you're cruising is no reason not to sail well. Good luck!
0 registered members (), 4,150 guests, and 676 spiders.
