| Nacra 5.2 jib block setup #35200 07/07/04 03:10 PM 07/07/04 03:10 PM |
Posts: 69 San Francisco | I just purchased a 1984 Nacra 5.2. I'm a bit confused on how to rig the jib blocks. There are no jib tracks on the decks. There is a cable on both sides running underneith the trampoline from the rear cross bar to the the front one. There are two slits in the trampoline about midway just over the cable on both sides about 6" apart. There's a line tied to each cable at the rear crossbar eyelets. The length of each reaches to about the center of the slits in the trampoline.
So do the jib blocks attach to the cable through the trampoline? Does the line from the rear cross bar come over or under the top of the trampoline to the jib block? I also heard that some kind of insulation can be used on the cable (hose tubing?).
Any input on this would be great!
Thanks
Tim S. Urfer
1984 Nacra 5.2
| | | Re: Nacra 5.2 jib block setup
[Re: TSurfer]
#35201 07/07/04 04:10 PM 07/07/04 04:10 PM |
Posts: 606 Maryland | Cable comes up through the rear slit and back down under the front slit. Line follows the cable to the top of the tramp. Jib blocks are attached to the cable on top of the tramp and the line is attached to the same shackle. The line is used to move the block forward and aft.
Good Luck,
Kris Hathaway | | | Re: Nacra 5.2 jib block setup
[Re: Kris Hathaway]
#35202 07/07/04 04:16 PM 07/07/04 04:16 PM |
Posts: 606 Maryland | Also, the line should run through a small block on the aft beam. The small block is attached at the same point where the cable is attached. The line then surfaces to the top side of the tramp while heading to the opposite side of the boat to a cleat on the aft beam. Thereby, you will be able to adjust the jib block from the windward hull.
[Re: Kris Hathaway]
#35203 07/07/04 04:35 PM 07/07/04 04:35 PM |
Posts: 69 San Francisco | That clarifies things. Thanks Kris. I'll need to re-run the cable since the previous owner did not have it running through the tramp.
Where do you suggest putting the cleats on the rear crossbar?
Tim S. Urfer
1984 Nacra 5.2
#35207 07/08/04 08:14 AM 07/08/04 08:14 AM |
Posts: 606 Maryland | LOL Jake. I tried to protect the innocent and not reveal boat's owner. Err....It must have been after Isabel...yeh that's it...Isabel.
Yes. The setup relies upon pressure on the jib to pull the blocks forward. However, I sailed better in light winds with the blocks mostly aft. I moved them forward when the wind picked up and corresponding chop to power up my 5.2. When things really started to blow and the jib started to over power, I moved them aft again.
[Re: dickcnacra52]
#35209 07/08/04 10:42 AM 07/08/04 10:42 AM |
Posts: 12,310 South Carolina | I rarely use hiking straps and honestly, they scare me a bit. If I am hiking, I usually hook in to the trap line and drop my butt off the side. Call me crazy (you wouldn't be the first!) but I get concerned about having my leg stuck in the hiking strap during a capsize. I've come close to this myself and I've heard of serious knee injuries this way.
I do, however, occasionally put my heel on the hiking strap as an additional foothold but by-and-large do without them.
Jake Kohl | | | Re: Nacra 5.2 jib block setup
[Re: dickcnacra52]
#35210 07/08/04 01:39 PM 07/08/04 01:39 PM |
Posts: 69 San Francisco | Nothing like a picture to get a description across. Thanks again Kris.
What threw me off with my initial question was that I was almost certain the cables under the trampoline were secured with a riveted eyelet on both ends. After further inspection last night I noticed the aft portions were shackled making the transistion to up-through and back-under the trampoline a whole lot simplier.
Dick - I imagine you could set up the same system for the forward block adjustment as is set up for the aft, but I'm not sure if it's really necessary?
Tim
Tim S. Urfer
1984 Nacra 5.2
[Re: dickcnacra52]
#35213 07/08/04 04:37 PM 07/08/04 04:37 PM |
Posts: 69 San Francisco | Dick - No problem and thank you. There aren't many here either so racing is a bit out of the question. Although there's Tuesday and Friday night races on the Bay here for any class so if I was to race I might just win them based on speed alone. I'm pretty new to Nacra's except for the ride I got 23 years ago on a 5.2 which absolutely changed my outlook on catamarans, as I was sailing a lot of Hobies. I just never had the opportunity to buy a Nacra until now. Gotta sell the 14 now.;-)
This forum and I'm sure others like it seem to be the best way to get info for the 5.2's. I did extensive searches via google and still couldn't find answers to basic questions, unlike the Hobie's.
If there's anything you come across that suits 5.2's let me know. I'll be reading and will do the same.
Tim S. Urfer
1984 Nacra 5.2
[Re: dickcnacra52]
#35215 07/08/04 08:15 PM 07/08/04 08:15 PM |
Posts: 12,310 South Carolina | Actually there are still a considerable number of 5.2s around. I know of several in FL and there's a significant local fleet in the midwest somewhere. It was a very well respected boat in it's time. At Spring Fever, there were four preregistered (although none of them except me showed up due to the bad short term weather forcast).
Regarding the rigging, except for a few nuances, all catamarans are rigged in a similar fashion. Keep the questions coming - we'll keep answering!
[Re: dickcnacra52]
#35217 07/09/04 09:13 AM 07/09/04 09:13 AM |
Joined: Aug 2003 Posts: 241 Largo, Florida papayamon2
Posts: 241 Largo, Florida | Dick, The idea is to prevent the jib sheet from sliding under the mast base and getting pinched or stuck there while sailing (which does tend to happen). On my Prindle, which uses the same setup, I run a bungee cord on each side (personal preference instead of the line) from the flat dolphin striker bar about a foot and a half out from the center post up to where the diamond wire attaches near the base of the mast. When sailing, the jib sheet stops at the bungee cord instead of sliding under the mast base, thus acting as a "jib sheet jam preventer". I must admit, I was puzzled by the manufacturer's manual as well--I thought, "Hey, the guy that sold me the boat left something off!"  Kevin Prindle 18 Largo, FL | | | Re: Nacra 5.2 jib block setup
[Re: papayamon2]
#35218 07/09/04 09:54 AM 07/09/04 09:54 AM |
Posts: 1,253 Columbia South Carolina, USA | That jam preventer also keeps it off your downhaul cleats. That brings up a good point, install a downhaul that is adjustable from both sides, so you can crank on it in a blow. Anybody got a pic? We use the pivoting exit blocks, and if you look at them, and their placement you can see that the jib sheet can get tangled around them preventing the sheet from going to the other side in a tack. The 5.2 is a fine boat, we have 2 in Columbia SC, you say you are from the south? Where are located? David Mosley www.seacats.org
[Re: dickcnacra52]
#35219 07/09/04 10:48 AM 07/09/04 10:48 AM |
Posts: 12,310 South Carolina | Run the bunji (use 1/4" or smaller) from the mast (rotator bar or higher - I had a small eye strap for this purpose about 18" up from the bottom of the mast.) to the connection of the bridle wires and the forestay - just under the jib. That will keep the jib sheets from jamming on anything on the mast.
Jake Kohl | | |
13,708
guests, and 708
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online14,249 9 seconds ago | | |
