| Re: F18HT in the Newport Regatta (my thoughts)
[Re: mbounds]
#35474 07/15/04 04:53 AM 07/15/04 04:53 AM |
Joined: Nov 2002 Posts: 612 Cape Town, South Africa Steve_Kwiksilver
Posts: 612 Cape Town, South Africa | Questions : Hunt, you mention you don`t need to be that heavy, what is the ideal crew weight on these boats ? With that monster mast & mainsail area, and 21sqm kite, I`d have thought heavier is better. Is 125kg crew weight too light ? (And how big do your forearms need to be to close that leech ?). At this crew weight, what is the max. windspeed you could expect to be competitive in ?
Matt, costs are interesting : I read on the Stealth web-site that F18HT costs 25% LESS than F18 boats, something of a mystery to me, I`d have expected the reverse. I can agree that development classes cost more to stay competitive, but only to a point : there is not that much you can modify on simple boats, I`m sure a "standard" F18HT boat is going to be competitive without too many mods, correct me if I`m wrong here. At 25% less than F18, there is a fair amount left over for modification anyway ! (Assuming you have the budget for either to start out with). I`m surprised to find that a boat 50kg lighter with a carbon mast costs LESS to produce.
Last question, which is faster, and in which conditions ? I`ve only seen video footage of F18HT, never seen a real live one. I`ve sailed Hobie Tiger, and the extra weight makes it feel a bit unresponsive, but very smooth (still damn fast though.*) I`m sure the lower weight of HT makes it feel much more lively, maybe sacrificing the smooth ride of F18 ?
(*Comment based on comparison between Hobie Tiger & my 16ft 100kg F16 Mosquito - Hobie Tiger sailors need not take offense. - Tigger is quicker, but nearly twice the weight!!)
Cheers Steve | | | Re: F18HT in the Newport Regatta (my thoughts)
[Re: Steve_Kwiksilver]
#35475 07/15/04 06:18 AM 07/15/04 06:18 AM |
Well the answer has been given by the A-cat class, didn't it.
M&M A2 15.500 US dollars (I seem to remember that being without a sail) Boyer Flyer 15.000 Euro's incl sail = 14.000 - 14.500 US$ without a sail.
Compare this to F18 prices
Tiger F18 14.500 US$ (Correct me if I'm wrong here) Nacra F18 12.500 US$ Cirrus F18 in EU 15.500 Euro = 14.500 US$ because of lower US taxes etc.
For a boat that has only one sail and not alot of everything else it sure is expensive in a relative sense.
Count how much more gear is fitted to an F18 and they are running down A's in anything but drifters.
It is unbelievable how much money can eventually be sunk in a simple development boat.
Remember that Stealth is producing very inexpensive boats. Ventilo for example asks alot more for their HT's about the same as a I-20.
To give a comparison, Steaths 16 footer is only 15-20% more expensive than a bare Hobie 16. Given the gear on it alone makes this is a major achievement. Their HT is much the same.
Besides making a carbon mast in house is significantly cheaper.
[Re: Wouter]
#35476 07/15/04 07:15 AM 07/15/04 07:15 AM |
Posts: 1,884 Detroit, MI | Your pricing for the Tiger is right on, Wouter, although buying a new one is not the most economical option. New boats need minor hardware additions that will tack on another $500 - $1000. (Depends on what kind of snuffer system you want to use.) I bought my Tiger used (2002 Alter Cup boat) w/ a new jib and 2nd spinnaker for $10,500. So far, it's been quite competitive (when the nut at the end of the tiller is tightened down properly  ) I've heard numbers as high as $30K being tossed around for the acquisition, set up and modification of F18 HT. That's a lot of money for most 19 year olds. Even $15K is a lot. If I had that kind of disposable money when I was 19, I'd be looking at cars, not boats | | | Re: F18HT in the Newport Regatta (my thoughts)
[Re: wildtsail]
#35477 07/15/04 07:23 AM 07/15/04 07:23 AM |
Posts: 285 | With regards to the ideal crew weight a note: at the Newport Regatta, held in medium to light winds, races were won by crews weighting 300, 350 and 380 lbs.
With regard to the entry cost have a look at the classified on the US 18HT web site: you will see that you can buy a very good used 18HT for less than 9,000 USD. I doubt that you can find a very good used F18 in the US for the same amount of money!
With regard to the quotation of new boats, I am aware that in Europe a Tiger, a Cirrus, a Mattia etc., when you add all the racing optionals, is priced well above EUR 15,000. For a new Javelin 2 you have to pay only EUR 12,800 and for a standard Stealth 18HT EUR 12,000, i.e. some 2,700/3700 USD less.
Moreover it is true that the 18HTs have far less fittings than a F18, but it has to be underlined too that they features an expensive carbon mast and hulls some 10-14 Kg lighter than the ones of a F18 | | | Re: F18HT in the Newport Regatta (my thoughts)
[Re: mbounds]
#35481 07/15/04 05:35 PM 07/15/04 05:35 PM |
Ain't that the truth !
Have been racing on a friends Inter 18 a few times this year and have thoroughly enjoyed myself and did reasonable well too. Considering that we are definately a crew of opportunity..
Old boats are for more compitive them alot of people think. You need to make sure that all the gear is working properly and smoothly again.
The rest is just to learn to sail better !
[Re: Catfan]
#35482 07/15/04 05:44 PM 07/15/04 05:44 PM |
Posts: 9,582 North-West Europe | Cool !!
>>you will see that you can buy a very good used 18HT for less than 9,000 USD. >>I doubt that you can find a very good used F18 in the US for the same amount of money!
Here is a claim that is easily disproved :
Catsailors Classified section accessed today 16 july 2004 (just a wild pick)
-1- 2000 Inter18 + cat trax, trailex trailer extra's as Harnesses, drytops,vests,all my gear times two. = 9500 US$
Sounds pretty good with all those extra's but We'll keep looking :
-2- 2002 Hobie Tiger Top 10 finish in Tiger Worlds, Singapore = US$ 9000,-
Ahh, there it is, about halve way down the page after 46 sec searching; A plended 2002 Tiger for 9000 US$
May have been wise to have done some fact checing before you made that claim Catfan !
343
guests, and 59
