Are black telltales easiler to see through sails? #35547
07/15/04 11:35 PM
07/15/04 11:35 PM
Minneapolis, MN
duganderson Offline OP
Minneapolis, MN
My local sail shop has only has red and green telltales. Should I try to find some black ones.....is black easier to see through the sails or doesn't it matter?
Thanks, Doug
Re: Are black telltales easiler to see through sails? [Re: duganderson] #35548
07/16/04 06:30 AM
07/16/04 06:30 AM
Yardley PA
DanWard Offline
DanWard  Offline
Yardley PA
Black is easier to read through the sail. I tried the red and green ones once and did not like them...Dan
Re: Are black telltales easiler to see through sai [Re: duganderson] #35549
07/16/04 06:50 AM
07/16/04 06:50 AM
Depends on what color your sail is.
I've always used the black ones, although sometimes it is hard to tell which side is which, especially when looking through a sail window.
Re: Are black telltales easiler to see through sails? [Re: duganderson] #35550
07/16/04 08:27 AM
07/16/04 08:27 AM
Punta Gorda, FL
KARTZ1 Offline
KARTZ1  Offline
Punta Gorda, FL
For training my new crew (14 year old daughter) I used a black tell tale on the starboard side of the sail and a red one on the port side. That way when I can say in or out on the sheet and watch the effect on the change on the tell tale. On a white Hobie sails the red shows through good and the black very good.
And yes Rick's shop has the black ones.
Jack Kartz
0 registered members (), 361 guests, and 45 spiders.
