| Harken Blocks for the Wave Main #35567 07/16/04 10:29 AM 07/16/04 10:29 AM |
Joined: Jun 2001 Posts: 3,293 Long Beach, California John Williams OP
Posts: 3,293 Long Beach, California | Hi Wavers - Harken has come up with a new set of blocks for the Wave - a 40mm carbo fiddle at the bottom, and a 40mm carbo double at the top. This ball-bearing system ratchets, is very light weight and is better quality than the stock Ronstan All Purpose blocks that come with the newer Waves. I've sailed with it a couple of times now and really like it. Drop Harken a note if you want a set - the ratcheting double is new and doesn't appear in the catalog.
| | | Re: Harken Blocks for the Wave Main
[Re: John Williams]
#35568 12/21/06 08:48 AM 12/21/06 08:48 AM |
Posts: 3,293 Long Beach, California | Just noticed the link was cracked on this - here is Harken's photo, and the link to the tech page for these blocks. http://www.harken.com/blocks/hobiewave.phpYou can order these blocks through the Catsailor on-line store! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
[Re: hobie1616]
#35572 08/15/07 05:20 AM 08/15/07 05:20 AM |
Posts: 24 central Maine | Yeah, I think it would be a more economical substitute, just no ratchet. That may be the way I go anyway. Hard to justify an extra $50 for that 411 block.
I did have a hexaratchet block on my last boat, and really liked it. I just wonder if anyone has the system listed above, and if it is worth the upgrade on a Wave. Thanks for the reply!
Jim
2007 Hobie Wave
[Re: RickWhite]
#35574 09/12/07 08:10 PM 09/12/07 08:10 PM |
Posts: 24 central Maine | I am experimenting w/ a Harken 40mm triple w/ ratchet which I picked up way cheap on ehay.
I disassembled and swapped the ratchet sheave and mechanism into an outside position. So basically I now have the HSB411 block in triple form, I just don't use the middle pulley of course. I use this block in the upper position in place of the stock Ronstan fiddle. I reeved it as shown in the pic. I am still using the lower stock fiddle/cam for now.
I got to try it today in some pretty stiff and gusty winds. It works great, just love the ratchet. I forgot how nice these work. In light winds just switch it off. In moderate to heavier air it helps hold the sheet position with a light grip on the sheet.
I did find that during those really strong gusts, it does not always allow the sheet to ease out quick enough. I almost went over a few times. I wonder if that fuzzy dacron sheet is just not mean't for ratchet blocks. I know 1/4" would probably run thru the blocks easier, 5/16" just feels better. Any suggestions for mainsheet line upgrade?
Jim
2007 Hobie Wave
[Re: wannahobie]
#35575 09/13/07 01:15 AM 09/13/07 01:15 AM |
Posts: 3,293 Long Beach, California | I used 6mm Maffioli Swiftcord - easy on the hands and the smaller diameter feeds substantially better than bigger stuff through the 40mm blocks. I tried Yale LiteSpeed first because I was concerned about the way Swiftcord might wear in the ratchet - turned out my fears were unfounded. You can pick up cut lengths of Swiftcord pretty cheap, too.
[Re: John Williams]
#35576 09/13/07 07:10 AM 09/13/07 07:10 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Hi John, Gotta tell ya.., as soon as I found Salsa my search for good mainsheet has ended. It is the best and not expensive.., about a dollar a foot. Doesn't knot up, glides through the blocks and very easy on the hands. Rick | | | Re: Harken Blocks for the Wave Main
[Re: RickWhite]
#35577 09/13/07 10:38 PM 09/13/07 10:38 PM |
Posts: 3,293 Long Beach, California | I've heard that from several folks, Rick. I haven't had to replace any line lately, so I haven't gotten to try it yet. The Maffioli mainsheet and Harken blocks went with the Wave when I sold it to Matt MacDonald. <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
[Re: John Williams]
#35578 09/14/07 05:41 AM 09/14/07 05:41 AM |
Posts: 24 central Maine | Thanks guys. I think I will need to give the 6mm salsa a try.
I may not do it 'til spring, as cat sailing here in Maine is basically done, although there may be a few good days left. But this isn't So Cal or Keys <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Jim
2007 Hobie Wave
220
guests, and 29
