| Re: aussi jib halyard
[Re: mmadge]
#35684 07/18/04 07:55 PM 07/18/04 07:55 PM |
Posts: 60 Hong Kong | Looking at my one, you need a special wire piece at the top to replace the current one which has two wires coming off the top loop rather than a single one leading down to the pulley and two pulleys that give you I think a 3:1 purchase and a hell of a lot of rope! (four times the height from the bottom of the mast to the shroud plate). There's a picture of one at murrays http://www.murrays.com/archive/30.pdf in the bottom right hand corner | | | Re: aussi jib halyard
[Re: schobiedoo]
#35688 07/19/04 11:45 AM 07/19/04 11:45 AM |
Posts: 152 Central Texas | Hmm... I have thought about the benefits of the Aussi Halyard before, I have seen it at my friendly local sailboat shop for $100 plus and I am confused about the promised benefits... 2/3 or 66% of reduced mast compression - How??? Easier tacking - Why is that - with the purchase in place there will be even more lines for the jib to get stuck in??? Better mast rotation and more consistent bend - Hmmm... it pulls from the same fixed points so why will there an improvement. I have read about some people relocating the lower block to the front of the mast... That makes sense to me in terms of mast bend. I have also heard of installing a fairlead or a clip to keep the purchase or wire close to the mast - that would help the jib to tack with more ease. Why would it be a good idea to replace the wire part of the halyard with a line? What is the benefit of placing the double block far up on the mast?
Thanks,
Patrick
Patrick, Hobie 16 '85
[Re: yoh]
#35689 07/19/04 03:27 PM 07/19/04 03:27 PM |
Posts: 152 Central Texas | O.K. I stared at the pic at Murrays for a while longer and checked the official German Hobie sites assembly charts for the euro Hobie 16... Now it makes more sense! The purchase runs parallel to the forestay not along the mast like the old 2:1 hmmm.... now the 66% of reduction in load on the mast base makes more sense. The Euro Hobie 16 seems to have a clip or a fairlead in the front of the mast. They also have the jib halyard cleat in the front of the mast.
Patrick
| | | Re: Matt, couple of ?
[Re: CMerrell]
#35697 07/22/04 08:18 AM 07/22/04 08:18 AM |
Posts: 1,884 Detroit, MI | Hi Chris, The jib halyard is 4mm Gottifredi Maffioli Swiftcord - a single braid Dyneema line that has a non-slip fiber woven in. You can get it directly from Hall Spars who has the exclusive import license ( here). It's only $0.38/ft, so the halyard was only about $30. I'm not so sure about it, though. I used it for the first time last weekend and it might be too stretchy. As for the wind indicator, the position is more a function of my choice of bridle fly. I've always thought that the Winddex vanes were much more sensitive than anything else. Because it's really a masthead vane, it has to be supported from below, thus the bent mount. (If you plan to do this, you have to heat the aluminum rod with a torch, otherwise it will break.) I like the tacking vanes (very useful with a novice crew). I use it primarily for upwind work in light to moderate air. What you don't see in the photo is my "back-up" system of 18" lengths of 8-track tape flown off the bridle wires. Those are used for downwind work, since the opposite bridle wire gives a good reference for 90 degrees apparent wind. I've been using a system like the one you see in the photo for probably 25 years. See you in Syracuse this fall? | | | Re: Matt, couple of ?
[Re: CMerrell]
#35699 07/26/04 07:34 AM 07/26/04 07:34 AM |
Posts: 1,884 Detroit, MI | Chris, You really have to get your priorities in order!  I took my wife to Mexico in May for Mother's Day (oh, yeah - there happened to be a little event going on there at the time - 16 WORLDS!). I'm working on taking her up north for our anniversary - and BTW, there's a regatta going on that weekend in Charlevoix that we just might have to go to!  /lawyer's phone number is already on my speed dial  We'll miss you in Syracuse. | | | Re: Matt, couple of ?
[Re: mbounds]
#35700 07/26/04 07:21 PM 07/26/04 07:21 PM |
Posts: 4 | Matt, you are so right. Charlevoix is an ideal place to celebrate a birthday or anniversary. I can not think of any woman who would not enjoy a weekend in Northern Michigan, bonding with their spouse... Love [color:"red"] [/color] is in the air...use it to get to the weather mark!  Rabs | | |
1 registered members (vasil),
512
guests, and 31
