| Hobie 14 model year? Beginners boat? #36098 07/26/04 12:50 AM 07/26/04 12:50 AM |
Posts: 106 NW Washington | Hi :-)
Looked at a Hobie 14 today. Owner wasn't around. I'd talked to him on the phone yesterday. Said it was an early 80's model. Sail wasn't there, but most everything else looked decent. If I get serious, I'll find a checklist someplace. Think I have one downloaded from the Sailing Pro Shop. If you know of a good checklist too, I'm all ears.
But how do you determine the year it was built? I didn't see any hull number anywhere.
And what are the pros and cons of this boat for a beginner? Price might be right.
Take care, Dan
Danno
| | | Re: Hobie 14 model year? Beginners boat?
[Re: jfint]
#36100 07/26/04 01:15 AM 07/26/04 01:15 AM |
Posts: 106 NW Washington | Think it's got just the mainsail. Thanks for your feedback.
Cheers, Danno
Danno
[Re: Danno]
#36101 07/26/04 07:18 AM 07/26/04 07:18 AM |
Posts: 371 Michigan, USA | If it doesn't have the jib (Turbo), then it won't have a trapeze.
Les Gallagher
[Re: jfint]
#36105 07/26/04 12:06 PM 07/26/04 12:06 PM |
Posts: 12,310 South Carolina | It's hard to tell but I think that little movie is a Prindle or a G-cat....
Hobie 14s or a 16s are good beginner boats in that they are cheap to buy, plentiful (for good reason), simply rigged, and inexpensive to maintain. Many people sail them very successfully in all sorts of weather and water conditions. You do have to be a little more conscious about how hard you power up the boat to keep the bows from going under - but it's not a death sentence. Yes, SCs, Nacras, etc. are more pitch pole resistant but they ALL will pitch pole if pushed hard enough. A H14 or H16 would make a great beginner boat even if tacking requires a little more forethough. We can help him here to roll tack that thing in a snap!
One of the hulls should have a serial # stamped into it (usually around the stern). In that serial number is the date of manufacture. While I can't find it, there's a thread somewhere that explains what each number means (although it should be pretty obvious when you look at it).
Jake Kohl | | | Re: Hobie 14 model year? Beginners boat?
#36106 07/26/04 12:29 PM 07/26/04 12:29 PM |
Posts: 1,459 Annapolis,MD | I always thought that the Hobie-14 was the ultimate boat to learn cat-sailing on, for the same reasons that Bill said a Sunfish was good. Balance, weight distribution, tacking techniques, etc. - you get fairly instant feedback when you do it wrong and when you do it right. It's true that this boat may amplify some cat traits. For instance, my 6.0 tacks much better than my 14, but it will still go into irons or be difficult if you don't pay attention - but you have to goof much more to make it happen if it does at all. Having learned the technique for tacking the 14 has made me appreciative for techniques of tacking any cat. Same goes for weight, and avoiding capsizes and pitchpoles.
So, in a nutshell, learn to sail a 14 well and you've got a great basis for sailing other cats IMO. Of course, notice that I said learn cat-sailing on. It might not be the best to learn sailing itself on - but with adequate instruction, why not?
I've also felt that the 14 could be catamaran racing's Laser, and that Hobie goofed by not finding a way to keep that model/class alive. | | | Re: Hobie 14 model year? Beginners boat?
[Re: jfint]
#36109 07/26/04 02:54 PM 07/26/04 02:54 PM |
Posts: 106 NW Washington | Pat:
Good point about boat usage. I'm learning sailing on a Force 5. Not doing too bad so far. Can handle it in 15 knots, as long as there aren't many gusts!
I'm looking to learn cat sailing and eventually sail in relatively unsheltered waters in the San Juan Islands. Current and winds can get pretty rough at times, but one of the 172 islands is always within sight, usually a couple miles or so. Most shores are rocky.
I may have an option to learn on a real small cat, then trade in for something bigger. A lot will depend on what boats are available on the used market for under 3k, preferrably under 2k.
Take care, Danno
Danno
[Re: Danno]
#36110 07/26/04 05:29 PM 07/26/04 05:29 PM |
Posts: 69 San Francisco | Dan,
Look on the back(transom)of each hull where the rudders attach:
The format is as follows: CCMX0000X000
CCM = Coast Cat Manufacture (Corporate Name)
X = Model letter (typical... 18s are C, 16s vary, Wave X, H20 P etc)
0000 = serial number
X = Letter / Month of Mfg. (A is January, B is February etc. I is not used I don't think)
000 = year of mfg and year model (797 is '97 mfg. 97 model / 697 would be a boat built in year '96 but is a 97 model. Model year starts in July.
This article is taken from On The Wire - the eZine for Hobie Sailors
Great beginning catamaran for a lot reasons listed in this thread.
I had my first when I was 12 and my second when I was 35.
Tim S. Urfer
1984 Nacra 5.2
[Re: BRoberts]
#36111 07/26/04 05:36 PM 07/26/04 05:36 PM | Anonymous
| Anonymous
Unregistered | But Bill...
If you can master this little beasty you can sail any multihull. Even a SuperCat!!
Bob Hobie 14 = Pitbull of multihulls Greatest training boat on the planet. Period. | | | Re: Serial numbers #36112 07/26/04 06:53 PM 07/26/04 06:53 PM |
Posts: 1,252 California | The above serial number information is correct... here is a bit more detail. Serial numbers info from Hobie Cat is on the Hobie Cat Product support pages. Serial number location and translation | | | Re: Hobie 14 model year? Beginners boat?
[Re: Surabyakid]
#36115 07/27/04 12:17 AM 07/27/04 12:17 AM |
Posts: 106 NW Washington | Thanks, guys.
I looked in the right place, but guess I didn't look close enough. Now that I know for sure they're there, it'll be easier to find.
Danno
Danno
[Re: Danno]
#36116 07/27/04 04:57 AM 07/27/04 04:57 AM |
Joined: Nov 2002 Posts: 612 Cape Town, South Africa Steve_Kwiksilver
Posts: 612 Cape Town, South Africa | Danno, The Hobie 14 is a FANTASTIC beginners boat to learn catsailing on. Please ignore advice from people who have a gripe with boats that they did not design themselves. It`s a great boat because it`s difficult to tack, pitchpoles easily if you overpower it too much and is a little unforgiving. It teaches you how to identify the limits, and once you`ve learned the right technique of tacking it, you can`t be excused for blowing a tack. If you take a stock H14 & just add a trapeze (no jib) it can hold onto the Hobie 16 upwind when sailed right, and it`s not slow downwind either. If someone rents a cat for a day & gives up trying to sail after one small setback, they belong on a couch watching football anyway. Try windsurfing. Takes months to learn how to get sailing properly, with many embarrassing moments either swimming back to shore dragging the rig & board, or being "rescued". Learn to sail on a lake before trying the ocean, use common sense. I`m speaking from a South African perspective here, but I think it`s probably common to other sailing regions : All the top Catamaran sailors started with Hobie 14`s : Alan Lawrence : Hobie 14 world champ, then Hobie 16 National champ. Now sails Hobie Tiger. Sean Ferry : H14 National champ, then H16 National champ, then H16 World Champ, now sails Hobie Tiger. David Kruyt : H14 National champ, then H16 National champ, then H16 World Champ. William Edwards : H14 National champ, H16 National champ, H16 World Champ. (11th at last Worlds) Philip Du Toit : H14 National Champ, H14 World Champ ....watch this space. Both the Hobie 16 & Hobie 14 are challenging, fun boats to sail, are strong as rocks (heavy as them, too  ), and will last a long time if looked after. They teach you skills that will help you to sail any other catamaran. I`d recommend one any day. And the H14 will still be sailing when many other cat sailors have packed up for fear of damaging their boats. And no, I don`t sail a Hobie, or sell them. I`m just sick of people who constantly run down other boats just because they sail, sell or have designed something different. Good luck on whatever you decide to sail (even if it`s a sunfish  ) Cheers Steve | | | Re: Hobie 14 model year? Beginners boat?
[Re: Steve_Kwiksilver]
#36117 07/27/04 07:45 AM 07/27/04 07:45 AM |
Posts: 12,310 South Carolina | One other point on the pitch pole topic; I said earlier that ALL catamarans can pitchpole. I also want to point out that when the rounded top deck (i.e. pitch pole resistant cats) pitchpole, they do so at higher speeds with higher loads and higher deceleration. If I were starting all over again (I started sailing 5 years ago on a Nacra 5.2, also a great boat) I wouldn't hesitate to start on a H16.
Jake Kohl | | |
1 registered members (FredL),
2,799
guests, and 283
