| blocks for h14 #36254 08/01/04 12:17 AM 08/01/04 12:17 AM |
Posts: 56 | I have harken blocks set up on my h14 now but the bottom block does not grip the rope so im killing myself everytime i sail holding the line. Can i just buy a new bottom block that "grips" the line or a whole new setup? what are your suggestions..and i dont wanna go crazy on spending money would this work, http://www.murrays.com/archive/32.pdfdown on the right item:QQ its a 4:1 block
Anthony-----H14
| | | Re: blocks for h14
[Re: yankyfan2000]
#36256 08/01/04 06:17 AM 08/01/04 06:17 AM |
Joined: Aug 2003 Posts: 241 Largo, Florida papayamon2
Posts: 241 Largo, Florida | Not to state the obvious, but be sure (or course) that your current block doesn't have a toggle or slide switch which changes it from free-wheeling to "gripping" mode. OK, so I DID state the obvious...  Kevin Largo, FL | | | Re: blocks for h14
[Re: papayamon2]
#36257 08/01/04 11:59 AM 08/01/04 11:59 AM |
Posts: 56 | ya it does but its old and i think the grooves or teeth are worn so it doesnt grip the rope anymore. the guy that had the boat before me had no idea what he was doing...all the riggins was wrong. Also what is a good line from Murrays that i can buy.
Anthony-----H14
| | | Re: blocks for h14
[Re: h17racer]
#36259 08/01/04 11:31 PM 08/01/04 11:31 PM |
Posts: 56 | sry im a newb to pretty much all of this but thx for telling me that one wont work. YEs my current block does rachet when i pull in and locks when going in the other direction, but does not grip the rope at all. My upper block is just a freewheeling harken. I want a bottom block that clamps the line. What are my options? can anyone give me a link to a set up i can buy?
h17racer, where did you see the 6:1 main block? is that for both blocks, 70$?
Anthony-----H14
| | | Re: blocks for h14
[Re: yankyfan2000]
#36261 08/02/04 08:03 AM 08/02/04 08:03 AM |
Posts: 206 Virginia USA | Sounds like you lack a cam cleat for some reason. A cam cleat can typically be added to a double/triple block. What you need is a Harken H150 cam cleat with a H137 eyestrap and the mounting plate (? part number). (Ronstan et. al. make equivelent gear). Believe the bottom block on a H14 is a 2.25" triple. Class legal max. is 5:1. The setup looks like this: Harken bottom block w/ cam cleat The Cat Sailor on-line store has this. Their help line is 1-866-451-3287. Also, West Marine, or any marine store that caters to sailboats, stocks cam cleats. It may be easier to bring your existing block to the store to fit up the gear you need. I am very happy with 5/16" Yale Light as my main sheet (36 LF for H14). The Cat Sailor store has a similar product: Spectra-Lite Ask more questions if you need more help and a picture is always a good reference. | | | Re: blocks for h14
[Re: CMerrell]
#36262 08/02/04 09:04 AM 08/02/04 09:04 AM |
Posts: 56 | Yes i do want a cam cleat. Is there any way to put one on my 4:1 harken block? All i do is lite lake sailing so i dont want to spend all the money to get a whole new setup. I think the line might be the reason it is not locking in the block because it is to small. I think ill buy some of that Spectra-lite rope in 5/16. Hopefully that will solve the problem. How much should i buy for a 4:1 setup on a h14
Anthony-----H14
| | | Re: blocks for h14
[Re: h17racer]
#36265 08/03/04 10:13 AM 08/03/04 10:13 AM |
Posts: 56 | nope my digital camera is broken, i think im just gonna buy a new wrope and hope it holds in the blocks a little bit more. And is the spectra the line i should get? any suggestions thanks for all the help.
Anthony-----H14
| | | Re: blocks for h14
[Re: yankyfan2000]
#36270 08/04/04 09:41 PM 08/04/04 09:41 PM | Anonymous
| Anonymous
Unregistered | I use 50' of 5/16" yalelite. This allows the line to also be the traveler line. The length is a must for getting the sail completely out downwind. I use a 6:1 purchase; 2.25 hexaratchet and 29mm triple carbon. Bob | | | Re: blocks for h14 #36271 08/06/04 10:01 PM 08/06/04 10:01 PM |
Posts: 56 | anyone know where to get that item?^^^^^?
Anthony-----H14
| | | Re: blocks for h14
[Re: JaimeZX]
#36273 08/10/04 12:20 PM 08/10/04 12:20 PM |
Posts: 56 | ok well i got the blocks i want. Should i use 3/8 or 5/16 line? and how much do i need on a 4:1 set up? And what is the recomended length for the traveler?
Anthony-----H14
2,362
guests, and 286
