Tramp holed #36301
08/01/04 10:58 AM
08/01/04 10:58 AM
Jensen Beach, FL
BlowMe Offline OP
BlowMe  Offline OP
Jensen Beach, FL
Does anyone have any ideas on how to easily and quickly repair a small hole in a mesh tramp? Tramp is on a N 6.0 w/diagonal mesh.
I'm trying to avoid removing it if possible.
Tramp was made by Sunrise.
Thanks,
AJ
Nacra 6.0 EX
Re: Tramp holed [Re: BlowMe] #36302
08/01/04 09:02 PM
08/01/04 09:02 PM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
I got a hole right in the middle, about an inch in diameter. I tried to grommet it, but it was too big and didn't hold. I just leave it alone, and it doesn't get any larger.
F-18 Infusion
#626- SOLD it!
Re: Tramp holed [Re: BlowMe] #36303
08/01/04 09:49 PM
08/01/04 09:49 PM
Gainesville, FL 32607 USA
dacarls Offline
dacarls  Offline
I've "fixed" several holes, cigarette burns, cuts, etc. I used "Marine Goop", and it works very well. I was careful to smush it up from underneath as well as on top to make sure everything around the hole is covered, even in FLorida sun and heat. Lasted 5 years so far, on 3 different cats.
Dacarls:
Re: Tramp holed [Re: BlowMe] #36304
08/02/04 12:10 AM
08/02/04 12:10 AM
Had a hole starting in a mesh tramp right next to a grommet - took it to a local canvas shop. They sewed in a patch for next to nuthin. Try your local guy for a couple of bucks. They did a square patch and double stitched it all the way around. It's been fine for three years.
Good luck -
Re: Tramp holed [Re: John Williams] #36305
08/02/04 10:13 AM
08/02/04 10:13 AM
Jensen Beach, FL
BlowMe Offline OP
BlowMe  Offline OP
Jensen Beach, FL
Thank you for the input!
I think I am going to go ahead and remove it. It is a pain in the butt...... But the tramp is still like new..... So it is probably worth the effort.
This hole is approx. 3/4 of an inch across....
Thanks again
AJ
Nacra 6.0 EX
0 registered members (), 311 guests, and 55 spiders.
