creaky boat #36668
08/10/04 08:10 PM
08/10/04 08:10 PM
Thunder Bay ON CAN
M
mmadge Offline OP
mmadge  Offline OP
M
Thunder Bay ON CAN
Boat is making lots of creaking noise.seems to be comming more from side bars.tramp is very tight,and boat sails relativly stiff.Is this noise usual and/or can it be fixed?
Re: creaky boat [Re: mmadge] #36669
08/10/04 08:48 PM
08/10/04 08:48 PM
Flensburg, Germany
Fritz Offline
Fritz  Offline
Flensburg, Germany
There are 2 options for this:
A. if your boat is older than 5 years, it is time to replace it because the beam will break ;-)
B. if your boat is new, this is normal sound of the boat that enjoys sailing. Nothing to worry about.
Fritz
Re: creaky boat [Re: Fritz] #36670
08/10/04 09:11 PM
08/10/04 09:11 PM
Thunder Bay ON CAN
M
mmadge Offline OP
mmadge  Offline OP
M
Thunder Bay ON CAN
Beam will break?
not sure what you mean
where should I be looking for stress points
the hull has no soft spots
Re: creaky boat [Re: Fritz] #36671
08/11/04 01:23 PM
08/11/04 01:23 PM
beaufort, sc
dannyb9 Offline
dannyb9  Offline
beaufort, sc
i doubt your beam is about to break, my boat is an 81, its always been creaky and ive never had a prob. the annoying sound is probably friction between a beam and a corner casting. some of us glue our boats together with epoxy, i glued my 16. its quieter now.
marsh hawk
Re: creaky boat [Re: dannyb9] #36672
08/24/04 08:55 PM
08/24/04 08:55 PM
Thunder Bay ON CAN
M
mmadge Offline OP
mmadge  Offline OP
M
Thunder Bay ON CAN
Found the problem.The shock cord for the righting system,which I had tied off on the dolfin striker,was way too tight.When I losend it off the creaking from the side rails disappeared.
0 registered members (), 230 guests, and 45 spiders.
