| Floating Mast? Anything Else? #37150 08/21/04 12:37 PM 08/21/04 12:37 PM |
Posts: 106 NW Washington | Well...
Next thing on my agenda is to drag the cat to the lake and toss the mast in the water. I meant to ask Performance Cat if the 2001 Nacra 450's have a sealed mast. If they don't, or if mine leaks, I'd probably get a 'baby bob' hobie mast float. I've heard of stuffing the mast full of foam, but that seems like a lot of work.
Any suggestions to do before or during my maiden voyage? I'm still cutting my teeth in sailing in general; a dozen times out in a Force 5 earlier this summer.
In case of capsize, I've got a righting line that's tied to the rod underneath the mast step. Swim bows to wind, throw line over hull, sheet out, lean out until upper hull hits water (not head), climb onboard and sail away, right? Maybe I'll get a righting bag first.
Danno
Danno
| | | Re: Floating Mast? Anything Else?
[Re: Danno]
#37151 08/25/04 04:45 PM 08/25/04 04:45 PM |
Posts: 591 Bradenton, FL | The mast should be sealed. All catamaran masts should be sealed. If not, you can seal it youself with a nice bedding compound (NOT 3M 5200!).
Doubt you'll need a righting bag for the 450. Purposely capsize it near the beach with an onshore breeze and try righting it a couple times. You can also capsize it in waiste-deep water and have someone hold the bow to keep the boat from drifting around while you try righting it.
Hobie 14T
[Re: JohnFolds]
#37155 08/27/04 04:24 PM 08/27/04 04:24 PM |
Posts: 12,310 South Carolina | The TheMightyHobie18 does not have an internal halyard - unless you've got something that's been modified. The Hobie 18 halyard should run in the luff grove behind the main sail and it should be possible to seal the mast. The halyard shouldn't actually enter the closed extrusion of the mast.
The TheMightyHobie18 locking system can be a bit tricky but once you figure out the right ring and knot combination for the sail hook, it actually works quite easy. Almost all catamarans use the same style mainsail hooks now.
Jake Kohl | | | Re: Floating Mast? Anything Else?
[Re: JohnFolds]
#37157 08/28/04 06:30 AM 08/28/04 06:30 AM |
Posts: 12,310 South Carolina |  I'm glad I could be of service! Seriously, the TheMightyHobie18 is a great boat. You might want to look around at some other boats to see how they handle the mast hook thing. Even something as simple as tying a different kind of knot at the ring could make a huge difference. While I too wrestled with my 'sky hook' on the one I had, I know plenty of folks that don't give mast hooking and unhooking on their H18s a second thought. Oh...and another thing to look for. The older TheMightyHobie18's had a latch on the top of the hook that was supposed to make unhooking easier (probably did when it was new and moved freely). It is a piece of metal that's held in place to the hook with a rivet (or screw). It's designed to get in the center of the ring and cover the hook if you raise the ring above it. This is 'supposed' to cover the hook and let the ring slide right down over it without rotating the mast. However, everyone I know took their 'latch' off because it made hooking the main almost impossible at times. If you've got one of these, you might try to remove it and see what happens.
Jake Kohl | | |
352
guests, and 35
