Here comes another one #37495
08/30/04 10:45 AM
08/30/04 10:45 AM
Jake Offline OP
Jake  Offline OP
I'm sure you are all already aware, but there's another huge Hurricane preparing for a stike at the South Eastern US coast. It's too early for a landfall prediction but without a doubt the Bahamas are going to get some serious weather. Huricane Frances already has winds sustained near 120mph and is expected to get stronger. From www.noaa.gov
Re: Here comes another one [Re: Jake] #37496
08/30/04 11:12 AM
08/30/04 11:12 AM
Because of what happened with Charley -- the last-minute change in direction -- do you think the Hurricane Center is being much more conservative in their projected path predictions for Frances? Or are they showing such a huge range of possibilities just because it is too far away for them to predict right now?
Bob Curry, what do you think? Where is she going to go?
Re: Here comes another one [Re: Mary] #37497
08/30/04 11:42 AM
08/30/04 11:42 AM
Jake Offline OP
Jake  Offline OP
From my perspective (and I have no training on the matter) this prediction is pretty consistent with their predictions in the past. It doesn't appear to be much broader. The NOAA "Discussion" gives you insight as to what they are thinking. Note the last paragraph...
WTNT41 KNHC 301425
TCDAT1
HURRICANE FRANCES DISCUSSION NUMBER 23
NWS TPC/NATIONAL HURRICANE CENTER MIAMI FL
11 AM EDT MON AUG 30 2004
THE LAST RECON MISSION HAD 107 KT WINDS OUTBOUND IN THE NORTHWEST
QUADRANT EYEWALL. THIS DOES NOT QUITE SUPPORT A MAXIMUM SURFACE
WIND OF 105 KT....BUT ON THIS MORNING'S SATELLITE IMAGERY...THE
HURRICANE IS LOOKING A LITTLE BETTER ORGANIZED...SO THE INTENSITY
IS KEPT AT 105 KT. UPPER-LEVEL OUTFLOW APPEARS TO BE INCREASING...
AND ANALYSES FROM THE UNIVERSITY OF WISCONSIN CIMSS AS WELL AS THE
SHIPS GUIDANCE INDICATE DECREASING VERTICAL SHEAR. THEREFORE
STRENGTHENING IS FORECAST AS IN THE PREVIOUS ADVISORY. FRANCES HAS
THE POTENTIAL TO INTENSIFY MORE THAN INDICATED HERE.
THE FORWARD SPEED HAS INCREASED AND INITIAL MOTION IS NOW ABOUT
275/11. FRANCES IS ON THE SOUTH SIDE OF A SUBTROPICAL RIDGE AND
THE TRACK MODELS SUGGEST THAT THE EASTERLY STEERING CURRENT WILL
STRENGTHEN SOMEWHAT DURING THE NEXT 24 HOURS. GLOBAL MODELS
INDICATE SOME WEAKENING OF THIS RIDGE AFTER 72 HOURS. HOW MUCH
THIS RIDGE WILL WEAKEN IS CRITICAL FOR THE LONGER-RANGE TRACK OF
THIS HURRICANE. THE OFFICIAL FORECAST TRACK IS SIMILAR TO THE
PREVIOUS ONE AND VERY CLOSE TO THE MODEL CONSENSUS AND THE LATEST
FSU SUPERENSEMBLE FORECAST. ONE CONCERN IS THAT THE GFDL MODEL
FORECAST TRACK HAS GENERALLY BEEN SHIFTING MORE WESTWARD WITH EACH
SUCCESSIVE RUN.
IT IS EXTREMELY IMPORTANT NOT TO FOCUS ON THE EXACT TRACK...
ESPECIALLY AT 96 AND 120 HOURS...BECAUSE THE HURRICANE IS NOT A
POINT AND FORECASTS AT THESE EXTENDED TIME RANGES CAN EASILY HAVE
ERRORS OF SEVERAL HUNDRED MILES.
FORECASTER PASCH
FORECAST POSITIONS AND MAX WINDS
INITIAL 30/1500Z 19.3N 58.7W 105 KT
12HR VT 31/0000Z 19.4N 60.7W 105 KT
24HR VT 31/1200Z 19.9N 63.5W 110 KT
36HR VT 01/0000Z 20.6N 66.2W 115 KT
48HR VT 01/1200Z 21.5N 68.8W 115 KT
72HR VT 02/1200Z 23.5N 73.5W 115 KT
96HR VT 03/1200Z 25.5N 76.0W 115 KT
120HR VT 04/1200Z 27.5N 78.5W 115 KT
Re: Here comes another one [Re: Jake] #37498
08/30/04 12:28 PM
08/30/04 12:28 PM
brobru Offline
brobru  Offline
Jake and all,
Yep, we are watching this one real close in the Virgin Islands...
...It had slowed down,..which in the storm business is bad news,......because that means, it is building in intensity...
..plus, it was tracking North-ish, and harmlessly into the Atlantic, but now has done a due west....bringing it into the Bahama chain and ??...we had a Hurricane do a 90% right turn once to hit St. Croix dead center,...anything can happen.
..our boats are up, stripped and secure,...this next 30 days are the peak 'hit' times......so I just keep the boat packed away.....
...the warm waters feed these storms,...if Francis makes it to the shallow warm Bahama waters,..
...this storm should be past St. Croix early Wed morning,.....the wind is up above the normal 15 mph and we had rain lines come in this morning...
..a certian sea bird, the big Petrel,..is seen alot before a big storm,......I saw them out today,...they soar so high, almost out of sight,..they are like little specks in the sky..
..so, time to prepare
regards,
Bruce
St. Croix
USVI
Re: Here comes another one [Re: Mary] #37499
08/30/04 12:35 PM
08/30/04 12:35 PM
Yardley PA
DanWard Offline
DanWard  Offline
Yardley PA
I'll defer to Bob on your question Mary. I did see on the NOAA site that the potential tracks indicated represent the the area the storm will be in 60% to 70% of the time. So I guess we can expect the storm to go outside the area indicated 30% to 40% of the time.
Re: Here comes another one [Re: Jake] #37500
08/30/04 01:55 PM
08/30/04 01:55 PM
Fort Loramie, Ohio
jmhoying Offline
jmhoying  Offline
Fort Loramie, Ohio
My daughter and her family are not a happy people at this time. They have reservations at Daytona Beach on Friday through Sunday and then are heading to Disneyworld, etc. on Monday. Looks like the first part of the vacation is going to be cancelled. At least the Grandkids are young enough that they won't figure out if the trip is delayed a couple days.
Jack
Fort Loramie, Ohio
Re: Here comes another one [Re: jmhoying] #37501
08/30/04 04:13 PM
08/30/04 04:13 PM
It's funny,
To the day 8 years ago, Hurricane Fran was in exactly the same spot! It recurved out into the Atlantic. All eyes are on the building ridge to the north and where the upper low in the lower Bahamas is going to track. Keep your shorts on folks!
Bob Curry
Meteorologist
Re: Here comes another one [Re: Jake] #37502
08/30/04 04:29 PM
08/30/04 04:29 PM
RickWhite Offline
RickWhite  Offline
Hey, Bob, Isn't this about the same track and layout as Andrew? As I recall you were stationed in Homestead at the time and warned the AF that it would hit here and they didn't believe you.
Rick
Rick White
www.onlinemarinestore.com
Re: Here comes another one [Re: RickWhite] #37503
08/30/04 07:12 PM
08/30/04 07:12 PM
The ridge building to the north (forecast) is what is troubling me. This would keep it on a more westward track and would have a HUGE impact again on South Florida. However, it's still too early to tell. Everyone with an interest from Miami to Hatteras should be prepared to seek shelter early as roads will obviously become clogged by those who wait until the last second. This is assuming the worst. I'll do my best to keep everyone informed with the "insider" information.
Bob
Re: Here comes another one [Re: brobru] #37504
08/31/04 10:51 AM
08/31/04 10:51 AM
brobru Offline
brobru  Offline
11 am update from St. Croix
The winds are out of the SW here around 20-ish. Francis is north of us and the eye should pass , going westward, this afternoon. There are cloud bands covering the sky.
The North shore here is a tremendous site, like Hawaii 5-0, with 7-8 foot rollers on a calm sea, the tops being blown off by the wind as they break on shore.
The tide is up about 5 ft and St. Thomas, BVI and Puerto Rico, being 40 miles closer to the eye, will hae more waves, wind and rain.
The Hurricane Hunters are stationed here and they come and go. I see that Francis is dropping to 948mb, which is a not-good sign.
So, the good report is that it missed us. However, be warned, it is coming your way.
Bruce
St. Croix
USVI
Re: Here comes another one [Re: Jake] #37505
08/31/04 11:06 AM
08/31/04 11:06 AM
Fort Loramie, Ohio
jmhoying Offline
jmhoying  Offline
Fort Loramie, Ohio
The noticed that the image in the first post is linked to the National Hurricane Center website and is updated when they update their projections. Looks like they are guessing that it'll turn a little North now.
Jack
Frances Update: 31 August ,1715L CST [Re: jmhoying] #37506
08/31/04 05:48 PM
08/31/04 05:48 PM
The next 24 hours are crucial as to where and when it will begin the northward turn. Today, the upper low began to move westward and the ridge began to build. The latest satellite images showed a NW wobble but then a more westward march. Movement is 280 degrees. Think of it as a top, it won't spin on it's axis but wobble around in a circle. So, tomorrow at this time I might be able to clue everyone in to where she might go.
The NHC discussion this afternoon was very sit on the fence-ish. There is a lot of model conflict at the 72hr point. And, 4 models did flip flops on their respective paths. Folks in Florida south of Cocoa Beach should begin some type of plan for evacuation. However, everyone along the Atlantic coast south of Hatteras should be ready!! That's my first hint/guess as to where she might go! Hope it curves out to sea like Fran did 8 years ago.
Bob
Another tidbit..... #37507
08/31/04 06:56 PM
08/31/04 06:56 PM
A landfall on the United States mainland is appearing more and more imminent as Frances continues to move to the west. Residents in the Bahamas and Florida should begin to take the necessary precautions to prepare for this major storm. As of Tuesday afternoon, Frances was located approximately north of Puerto Rico and was headed toward the west. A gradual turn toward the northwest is expected over the next couple of days. Frances will pass to the north of the Dominican Republic Wednesday, and approach the eastern Bahamas Wednesday night. This dangerous storm will hit the U.S. coast this weekend. (Thanx to AccuWeather)
Bob
Re: Here comes another one [Re: jmhoying] #37508
08/31/04 07:41 PM
08/31/04 07:41 PM
Long Island, NY
gregP19 Offline
gregP19  Offline
Long Island, NY
What if you go out with main only and really crank on the downhaul??
Re: Here comes another one [Re: gregP19] #37509
08/31/04 07:56 PM
08/31/04 07:56 PM
Bradenton, FL
Sycho15 Offline
Sycho15  Offline
Bradenton, FL
Greg-
That might work in Tampa Bay with my 5-batten Hobie 14. You're welcome to try if you want to borrow the boat.
Re: Here comes another one [Re: gregP19] #37510
08/31/04 09:15 PM
08/31/04 09:15 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
I think you could fly with only the mast, boards and rudders faster than you have ever gone before!
Eric Arbogast
ARC 2101
Miami Yacht Club
Been there (sort of) [Re: arbo06] #37511
08/31/04 10:10 PM
08/31/04 10:10 PM
Got caught in a pretty stiff blow during a race. Winds could have been around 40. Broke a spreader, which made the mast flex so much I actually got the sail down with the downhaul still cranked.
Long and the short of it, I made 6+ kts with just the bare pole in that breeze. I could probably fly a hull trapped out in a hurricane if I were so inclined to end up in the obituaries....
Re: Been there (sort of) [Re: waterbug_wpb] #37512
09/01/04 06:31 AM
09/01/04 06:31 AM
South Florida
SOMA Offline
SOMA  Offline
South Florida
waterbug, in this type of a hurricane you may fly two hulls!!
I've got to start making preparations. I wonder if those screw-in anchors would be enough to strap the catamaran to the ground
Fred F (ex Hobie 18)
Re: Been there (sort of) [Re: SOMA] #37513
09/01/04 06:48 AM
09/01/04 06:48 AM
No.
Take the mast down, take the tramp off. Take it home.....
Re: Been there (sort of) [Re: scooby_simon] #37514
09/01/04 08:38 AM
09/01/04 08:38 AM
brobru Offline
brobru  Offline
Florida Cat Owners,
After being in St. Croix 13 years, with many 'big' storm hits, here is some suggestions.
1. Take care of your boat today( Wednesday).
As the storm comes closer, more priority items appear and time grows short. Plus easy access to stuff becomes a very hard job. A friend, Brother, Mother , Son, etc. may call any moment for help,..and you gotta go!
-strip EVERYTHING off the boat, mast, rudder system, tramp, lines, everything.
-tie boat down or 'hide it' somewhere.
..if it gets airborne, consider it destroyed.
- If you can dissassemble the crossbars, better yet.
...this way, you can make the cat 'compact', slid in a garage wall, whereever.
- water in the hull, at 8 pounds a gallon ( 20 gallons = 160 pounds) is great, easily removable, weight.
- tie mast down somewhere.
...yes, these 'fly' too, and usually, cannot take much of a 'hit' before they are worthless.
Non Boat tips!
1. Fill bathtub full!
- it is amazing how little water it takes to shower, adults and kids.
- plus, this will be used to work toilets
2. DO ALL YOUR LAUNDRY!
-before Hurricane Marilyn, 1995, my wife was doing laundry, I was a little unhappy as I was on the roof securing stuff, she said' you will see', [ her being through Hugo in St. thomas].
...sure enough, no power for 2 weeks, man, you will be happy for clean clothes and bedsheeets after a hard day.
3. Non Refrig FOOD
4. Camper stove w/ fuel!
5. Camper Lantern, non battery
6. Non battery Board Games ( you will need them, especially if you have kids)
7. Small Radio
8. Rechargable drill ( many a story about saving a house by refastening a board on a window in the midst of a storm)
9. Plastic Garbage bag everything! Double Plastic Bag the important stuff.
HOW bad is the wind driven water?
Well, I have witnessed water blown through the cement block walls of my house.
Not thru the roof, not thru a opening,...but thru pores in the stucco,the block and the cement, so that the inside of the wall is wet, weeping water.
Get Ready.
Bruce
St. Croix
0 registered members (), 20,780 guests, and 1,475 spiders.
Most Online22,490
Yesterday at 08:14 AM
