Hobie 16 Jib Cars... #38042
09/14/04 09:32 PM
09/14/04 09:32 PM
jeffrey Offline OP
jeffrey  Offline OP
Does anyone have a used set of Hobie 16 Jib Cars that will fit the standard external track from 1985? The plastic rollers within the old blocks have cracked. Thanks...
Jeffrey
horn.jeffrey@medstudent.pitt.edu
Re: Hobie 16 Jib Cars... [Re: jeffrey] #38043
09/15/04 08:50 AM
09/15/04 08:50 AM
DrPeteG Offline
DrPeteG  Offline
I had the same problem. I cut off the old blocks from the Traveler car. I used Harken 40mm air blocks. You can get them with becket or without(lower profile by tying jibsheet through center) Pick up the block spring to keep it upright when the line is slack. The line runs smoother through the air block then the standard jib block
0 registered members (), 2,517 guests, and 326 spiders.
