To de-mast or not to de-mast #3829
11/14/01 02:15 PM
11/14/01 02:15 PM
Anonymous OP
Anonymous OP
I need to change my tramp for the first time. Do I need to de-mast to get the side-stays out of the way to slide rope-bolt through front cross bar, or can this be done easily with stays in place? All advice is appreciated.<br><br>
Re: To de-mast or not to de-mast #3830
11/14/01 02:34 PM
11/14/01 02:34 PM
Anonymous OP
Anonymous OP
I had no problem removing and installing mine with the mast up.
<br>JGraves P18<br><br>
3860- (14 downloads)
Re: To de-mast or not to de-mast #3831
11/14/01 03:39 PM
11/14/01 03:39 PM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
What kind of boat are you talking about.
<br>
<br>I had no problem changing mine out on my H20 with the mast up.
<br>
<br>Mike Hill
<br>H20 #791
<br><br><br>
3864- (12 downloads)
Mike Hill
N20 #1005
Re: To de-mast or not to de-mast #3832
11/14/01 04:42 PM
11/14/01 04:42 PM
I suppose the boat type would play a large role in the answer to this question. There's no way you could do this on a Nacra 5.2 with the stick up.<br><br>[color:blue][b]Jake
<br>[color:blue][b]Nacra 5.2 (2112)
<br>[color:blue][b]Hobie 18 (mutt)
3867- (12 downloads)
anything's possible [Re: Jake] #3833
11/14/01 07:44 PM
11/14/01 07:44 PM
Anonymous OP
Anonymous OP
I did it on the 5.0 I used to have, but it involved a drill and a grinder. Just make a little groove.
<br>But Jake's right, if it's a Nacra that you are interested in keeping whole, you gotta take the beam off.
<br>Michael<br><br>
Re: anything's possible #3834
11/15/01 12:59 PM
11/15/01 12:59 PM
Anonymous OP
Anonymous OP
Thank you for all your resposes. I guess it would have helped if I indicated boat. Duuh. Prindle 18 - Based on JGraves' experience, I'll give it a try with mast up. Thanks.<br><br>
3892- (14 downloads)
Re: anything's possible #3835
11/15/01 03:08 PM
11/15/01 03:08 PM
Anonymous OP
Anonymous OP
NO PROBLEM WITH MAST UP. ONLY NACRA AS FAR AS I KNOW HAS TO BE DEMASTED. DOUG KLEM<br><br>
0 registered members (), 517 guests, and 100 spiders.
Posts267,056
