| Re: S-Bend in the mainsail
[Re: alutz]
#38358 09/22/04 09:36 PM 09/22/04 09:36 PM |
Posts: 851 US Western Continental Shelf | Andreas,
I think that you are saying that the "S shaped" battens are "S shaped" when viewed from above, or below; from a "plan view."
I have diagnosed this problem, three different times. In all cases the cause was attributed to batten cap ties that were too tight. Often, you may think that there is no batten tension when you hold the batten, but the batten may be bent while you are holding it.
I suggest that you untie the battens and leave them untied while you perform a test hoist, and test trim.
If you are in a place where you can capsize your cat with the main trimmed to maximum tightness, you can then tie the battens snug while the sail is sheeted tight. This will ensure that you are not over tightening your batten tension settings.
Please let us know what finally solves your problem. Also, if your description of "S-bend" is different than mine, please tell me your description.
GARY
Santa Monica Bay Mystere 6.0 "Whisk" <--- R.I.P. | | | Re: S-Bend in the mainsail
[Re: alutz]
#38363 09/23/04 08:08 PM 09/23/04 08:08 PM |
Posts: 284 S. Florida | Hello Andreas, It sounds like you have a sailmaking 101 problem. The luff curve made on your sail is more shallow than the luff curve your mast bends to in the upper part of your mast. When and where this happens,like at the first or second horrizontal batten down from the head for example, the sail goes flat here. The mast bend tries to pull the sail to a shape that is greater in width, luff to leech, than the sail is actually made to. Now the mainsheet load that was traveling up the leech of the sail migrates forward prematurely to the luff of the sail across this flat and tight sail area. This flat and tight area of the sail, one or two battens down from the top of the sail, takes the mainsheet load and delivers it to the mast one or two battens down from the top of the sail. Now the leech sail area above this point has very little tension in it and it falls off to leeward. If you take line of max leech tension from the clew to the second batten down from the top, for example, this line acts like a hinge. The sail area aft of this line falls off to leeward because the upper end of the leech at the square top is now falling off and it takes the leech with it. This will put an "S" shape into the sail. To correct this problem, your sail needs more luff round especially near the top. I would suggest you move the headboard aft about 2cm and refair the luff curve back into the original luff curve at the forward end of the gaff batten. This will put more luff round in the sail near the top of the luff curve and stop the sail from going flat prematurely at the second or third batten down from the top. Now the mainsheet/leech load will stay in the aft leech area of the sail until this load reaches the square top area of the sail where it will finally come forward and pull aft and down on the top of the mast. The leech will stand and the "S" shape in the sail will be gone. The hinge line has been eliminated. Good luck, Bill | | | Re: S-Bend in the mainsail
[Re: BRoberts]
#38364 09/24/04 06:32 AM 09/24/04 06:32 AM |
Posts: 267 Switzerland | Hello Bill
Thanks allot for responding! I understand your theory and it sure makes sense to me. But why is the S-Bend only at the 2 lowest battens? Should not all the battens bend, until to the top?
[Re: alutz]
#38365 09/24/04 09:04 AM 09/24/04 09:04 AM |
Posts: 284 S. Florida | Hi Andreas, Draw a picture of your sail plan from the side view, luff,curved leech, square top head and foot. Now draw a dotted line form the forward end of say the second horrizontal batten down from the top, the very flat area of the sail, to the clew corner. This dotted line is the hinge axis. Aft of this line the sail falls off and in cross section the sail forms the "S" shape. The battens higher in the sail will have a greater percentage of their length aft of this dotted line, the hinge axis, and the fall off will be more pronounced here. The bottom batten or two down close to the foot of the sail will show very little fall off or "S" shape because such a small percentage of the batten length is aft of the hinge line. Does your sail have tapered battens in it? Are they very stiff in the aft 1/3rd of their length and soft in the front 1/3rd? Or are your battens of constant cross section and bendy everywhere? Constant cross section battens, untapered pultruded fiberglass battens for example, are too bendy in the leech area of the sail and often proper control of the leech is lost. Sometimes the leech can fall off, other times it can hook back to windward. Good luck, Bill | | | Pictures and review
[Re: BRoberts]
#38368 10/02/04 05:08 AM 10/02/04 05:08 AM |
Posts: 267 Switzerland | Here is the picture of the sail with the s-bend. Pic of sail with s-bend 300kB first I have to say that the sail is specially designed for light winds. it has not allot of luff curve and allot of shape build in. It really seemed to me, that the luff curve didn't match the bending characteristics of the mast. We experimented with the prebend of the mast. we started with 7 cm prebend after the recommandations of the sail maker. the more prebend, the more the mast will bend at the spreaders. the more we tightened our diamonds the worse the s-bend. we finally found the right setting, with only 3-4 cm prebend, witch is not much for a mast with 10m lenght. the hinge, bill was talking about, was there, but not to the top of the sail, it wend from the clew to the spreaders. that is wy the upper part of the sail looked good. thank you all, for the usefull tip's! It really helped us thinking! Pic of sail without s-bend 300kB | | | Re: Pictures and review
[Re: BRoberts]
#38370 10/02/04 10:26 AM 10/02/04 10:26 AM |
Posts: 3,528 Looking for a Job, I got credi... | Tie the halyard to the end of the boom and sheet the mainsheet in firmly Don't do this. It will result in one or more of the following 1, Minimum the halyard will just streach and not really bend the mast 2, The halyard will streach a little and then break, possibly causing your mainsheet blocks to impact each other and (poss) crack, and or boom shattering after the shock of the release. Do this. Shackle one trap wire to the mainsheet via the boom and sheet in having set the mast rotation at the required level.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Pictures and review
[Re: BRoberts]
#38372 10/02/04 01:52 PM 10/02/04 01:52 PM |
Posts: 267 Switzerland | Dear Bill Thanks a lot for studying my pictures! The mast bend down low can be reduced by moving the mainsheet attachment point to the boom or clew of the sail forward, toward the mast.
You are right! I have to move the attachmentpoint of the mainsheet. I had a boombreakage this summer and the position of the boom attachmentpoint is not at the same place as before. I moved it a little back because, I was looking for more mast rotation, witch was successfully achieved. the interactions between the sails and mast/rigging are complex! thanks again for your help! | | | Re: Pictures and review
[Re: scooby_simon]
#38373 10/02/04 01:54 PM 10/02/04 01:54 PM |
Posts: 267 Switzerland | Hi scooby thanks for that warning! I think your are right about my block on the top of the mast  . I think the best way to measure the mast bending, is using the sail without inserting it into the leech but attaching the head of the sail at the top of the mast as normal. then connect the cunningham and the mainsheet with the free hanging sail and pull them both tight. To measure, use a small chord tied to the top and to the gooseneck, and go on as bill described before. thanks all for sharing your knowledge! | | |
1 registered members (vasil),
386
guests, and 25
