| New F-14 in West Florida #38539 09/28/04 05:19 PM 09/28/04 05:19 PM |
Joined: Sep 2004 Posts: 2 St. Petersburg, Florida, USA sailwriter OP
Posts: 2 St. Petersburg, Florida, USA | The deck was epoxied on a very strange craft today. While it measures to the latest Formula 14 rules I can find, it is different enough to ruffle some feathers. I hope. Thus far, with everything loaded on the boat except the foils that are yet to be built and the paint, it weighs 98 pounds without sails. Probably will come in at about 115 when done. In a nutshell: mild surface piercing bows, planing aft five feet, Carbon A-frame supports a 12.2 square meter Windsurfing sail on a full carbon mast. Foot of mast articulates to leeward and forward to lift bows. a very small bubble-inducing step 8 feet aft of the bow where the hull transferrs from piercing to planing. Canting hulls. Conventional boards, small chord, well aft. Rudders with a small (non hydrofoil) 'end plate' to maybe keep the bows from diving if the lifing sail is overcome. I'll sail it in the 14A configuration. Dave Ellis St. Petersburg, Florida | | | Re: New F-14 in West Florida
[Re: sailwriter]
#38540 09/29/04 01:55 PM 09/29/04 01:55 PM |
Posts: 591 Bradenton, FL | Would you mind if I come take a look at it this weekend? I'll be in your area anyhow.
Hobie 14T
[Re: sailwriter]
#38542 10/31/04 09:51 AM 10/31/04 09:51 AM |
Posts: 3,293 Long Beach, California | Hey Dave - I am unhappily missing the Clearwater race - any chance you'll have some pictures to share? Sounds like you've done what everyone else was talking about - a light homebuild with an attitude!
[Re: sailwriter]
#38543 10/31/04 03:01 PM 10/31/04 03:01 PM |
Posts: 591 Bradenton, FL | I know a guy selling a NACRA 5M with trailer for ~$1500. I'd be a cheap way to get beams, mast, rudders, trailer, blocks, etc. It has some spinnaker gear, too, but the spin is the older, fuller design. He's near me, not far south of the bridge.
Hobie 14T
[Re: writer]
#38545 01/17/05 02:10 PM 01/17/05 02:10 PM |
Posts: 591 Bradenton, FL | Why not go with a stiffer mast? Sailboard rigs are meant to automatically de-power in a puff since they're working with lighter weights and less leverage. Perhaps you can sleeve the inside of the mast with something (foam?) to stiffen it up a bit.
Hobie 14T
[Re: sailwriter]
#38547 01/22/05 07:01 PM 01/22/05 07:01 PM |
Posts: 24 Florida west coast | Launched the F-14 hybrid this morning at Florida's Dunedin Causway at the IceBreaker regatta. The boat really tries to go fast. I have left it with some issues that makes this tough. Canted hulls are not necessary. The canting 12.2 windsurfing rig/sail lifted the LEEWARD hull enough that there was no heeling of the hulls even at 17 - 20 kts of breeze on a close reach. There is no trapeze. I just sat to windward, aft. Sweet! But with the hulls canted, both the boards and rudders are angled. Broke both boards, and the rudders were cutting a three-inch groove through the water, causing a pretty, but slow, rooster tail. Just as I figured out to take off the tiller bar and use the windward rudder on each tack, letting the other rudder follow, the rig came crashing forward. More strain on the "shrouds" of the A-frame than I had calculated. So from here we make more modifications. The hulls are going to be made upright, not canted. New rudders with sharper leading edges and upright, not canted. I have to open up the hull and fashion wider daggerboard slots to allow a thicker board to be used. Wonder if I should cant them for lift, since I'm making them stronger. Or how about leaving the existing wells using a shorter, windsurfing-style blade and putting in new canting board wells. Hmmm. Also, I'll allow the mast to swing forward more when it is canted all the way to the lee hull. Was upright this time. The surface-piercing bows did not dig, but neither did they lift for planing. Oh, and there was too much hull-racking going on. A different,(gasp)heavier forward beam will be fitted. I think the canting rig and piercing/planing cat project has promise. Probably the next test will be in April. | | |
21,922
guests, and 1,500
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online23,433 7 seconds ago | | |
