| Re: open cruising cat??
[Re: johannes]
#39315 10/21/04 03:53 PM 10/21/04 03:53 PM |
Posts: 591 Bradenton, FL | A beach-cat will not take the extra weight of gear and supplies, especially for three to four people! The Reynolds 21 or Stiletto 23 are closer to what you'd need and can be found a reasonable prices. The Seawind 24 is a boat designed for "expedition" style sailing and might be the best production boat you could buy for this purpose. Otherwise, look at www.sailingcatamarans.com especially the Janus and Strider. These are boats you can build out of plywood and fiberglass.
Hobie 14T
[Re: johannes]
#39318 10/21/04 09:05 PM 10/21/04 09:05 PM | Anonymous
| Anonymous
Unregistered | James Wharram's designs are generally well-regarded for their sea-going capabilities: http://www.wharram.com/ Mark. | | | Re: open cruising cat??
[Re: Mary]
#39322 10/22/04 09:55 AM 10/22/04 09:55 AM |
Posts: 12,310 South Carolina | The Hobie 21 can do it. The same guy who did the Drake Passage also sailed from Miami to South America, island-hopping through the Caribbean. Four guys on two Hobie 21 Sport Cruisers. The boats were brand new out of the box and not modified. Semp Toshiba's (Roberto and Duncan) Hobie 21 was a very custom boat - I think they built it from scratch using modern high tech methods... From http://www.edge-ventures.com/antarctica.htm"The vessel choice was a custom built Catamaran based on the HOBIE 21 hull shape; construction and engineering of which was carried out by Barracuda Technologies, Rio de Janeiro. Kevlar and Carbon Fibres surrounding a 12mm Divinycell PVC Foam core were infused with epoxy, producing a bulletproof platform. Further modifications included - foam filled "crash boxes" and a total of 5 watertight compartments in each hull. A powerful rig including a 24m2 spinnaker and a 9.6-meter tall mast complemented the 3-meter beam to produce a fast and stable vessel. "
Jake Kohl | | | Re: open cruising cat??
#39323 10/22/04 10:27 AM 10/22/04 10:27 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Jake, you are talking about the one for the Drake Passage. The ones they used for their Caribbean trip to South America were, as I said, brand new and right out of the box. We were there when they were getting ready to go at Miami Yacht Club.
By the way, Duncan was not involved in that Caribbean trip.
[Re: basket.case]
#39324 10/23/04 06:33 AM 10/23/04 06:33 AM |
Posts: 3 Switzerland | hi syncho, Thanks for your message. I looked up those boats you mentioned. They´re however not exactly what I´m looking for. I really am looking for a boat where you can sleep on deck.. like in a small tent. The hulls are simply for material. The stiletto 23 looks quite interesting.. I also found a nice sturdy beach-cat the shark. It can take quite some extra weight. thanks johannes
[Re: johannes]
#39332 02/11/08 10:23 AM 02/11/08 10:23 AM |
Posts: 778 Houston | I´m want to build the boat myself. .... There were several small British and Austrialian designs in 20-30ft range. The only one I can think of was the Strider. Remember the hulls are the cheapest and easiest part to build. If you find an old boat in the right size and type with good rigging and beams, buy it for parts. | | |
232
guests, and 24
