| Rebuilding an A-cat for double trapeze and spi #39353 10/23/04 11:03 AM 10/23/04 11:03 AM |
Joined: Jul 2001 Posts: 256 North Europe, Sweden, Uppsala Hakan Frojdh OP
Posts: 256 North Europe, Sweden, Uppsala | BACKGROUND After Booth successfull rebuilt of the M18 I'm thinking about adding a second trapeze, a bigger mainsail and spi to my Marstrom A-cat. I know that Booth didn't win but my interest was focused on the fact that the boat could handle the extra loads without any failures!
Booth used the M18 with 150kg+ of on the wire and used a main beam that had a weight of 50 kg instead of 5kg. The reason for the heavy mainbeam was to reach the minimum weight of 130 kg. Booth used a cut down M20 mast, I will try to use the A-cat mast as it is.
Should I do it?
THE PROJECT
Crew It will not be designed for "Team beef" but for teams around 130-140 kg, same as Hobie 16.
Sail The area can be increased from 13.9 to maybe 16.5 m2 by adding more roach area to the main sail. The spi should be around 17 m2.
PROBLEMS Mast The top of the mast may be to bendy for the bigger roach and increased loads. The performance to windward in medium winds could suffer from this. Increased compression of the mast by 30%, reason higher sheet load and another crew on the trapeze.
Main beam Increased load on the mainbeam by 40%, reason higher sheet load and double trapeze. Booth had 50-60% more load on a WIDER main beam.
Hull The hull needs to support 220 kg instead of 165 kg which means that the hull will be 4 cm lower in the water. The hull on Booth F18ht supported at least 280 kg and that hull was probably 10 cm lower in the water.
Performance The boat is narrower than the F16 and 25 kg lighter but the sail area will be lower, 16.5 m2 instead of the F16 18 m2. The lower sail area will be compensated a bit by a 1 meter higher mast and uni rigg instead of main+jib.
/hakan | | | Units in pounds and feet
[Re: Hakan Frojdh]
#39354 10/23/04 04:17 PM 10/23/04 04:17 PM |
Booth used the M18 with 330+ lbs of on the wire and used a main beam that had a weight of 110 lbs instead of 11 lbs. The reason for the heavy mainbeam was to reach the minimum weight of 286 lbs. Booth used a cut down M20 mast, I will try to use the A-cat mast as it is.
Should I do it?
THE PROJECT
Crew It will not be designed for "Team beef" but for teams around 286 - 308 lbs, same as Hobie 16.
Sail The area can be increased from 148 sq.ft to maybe 176 sq.ft by adding more roach area to the main sail. The spi should be around 180 sq.ft.
Hull The hull needs to support 480 lbs instead of 363 lbs which means that the hull will be 1.5 inches lower in the water. The hull on Booth F18ht supported at least 616 lbs and that hull was probably 4 inches lower in the water than normal.
Performance The boat is narrower than the F16 and 55 lbs lighter but the sail area will be lower, 176 sq.ft instead of the F16 192 sq.ft. The lower sail area will be compensated a bit by a 3 feet higher mast compared to the F16 and uni rigg instead of main+jib.
/hakan | | | Re: Rebuilding an A-cat for double trapeze and spi
[Re: billrob]
#39356 10/24/04 09:57 AM 10/24/04 09:57 AM | Anonymous
| Anonymous
Unregistered | Hakan, I might suggest (if you haven't already done so) you contact Goran on this project with your concerns. Since he built your boat, he is the one who can tell you the reality of your project. Good luck!! Bob | | | Re: M18 website
[Re: samevans]
#39360 10/24/04 05:38 PM 10/24/04 05:38 PM |
Posts: 3,528 Looking for a Job, I got credi... | The Marstrom A Class hulls are famous for their strength.
According to the Marstrom website: The M18 uses the same hulls from the A Class, Is 2.5m wide, instead of 2.3m, The mainsail is 15sm instead of 13.94sm, The boat weighs 78kg instead of 73 kg, And of course it has a 15sm gennaker.
I doubt if Booth would even have tried to build his boat without checking every single modification with Goran Marstrom. Supposedly the ICCT boat was made fron the same hulls and hardware with an M20 mast. The hulls didn't break. The mast didn't break. The daggers didn't break. The rudders didn't break. The hardware didn't break.
I think the issue of strength has been resolved. To all the above.........Yet...... The boat was used for a couple of weeks max and it has not broken yet. I would urge caution and contact Goran Marstrom and discuss it with him. And while you are talking to him, ask why they have not responed to my enquiries about the M18
F16 - GBR 553 - SOLD I also talk sport here | | | Re: M18 website
[Re: scooby_simon]
#39361 10/25/04 08:11 AM 10/25/04 08:11 AM |
Posts: 9,582 North-West Europe | >>The Marstrom A Class hulls are famous for their strength.
This is not a correct conclusion from this test. As a matter of fact Booth made skilled use of how the design parameters behave when loading up a platform.
Let me run through the points
>>Is 2.5m wide, instead of 2.3m, : Does not seriously increase loads on the platform. the increases are accompanied by equal magnitude reductions.
>>The mainsail is 15sm instead of 13.94sm, ; Doesn't matter ; righting moment determines the laod on a platform not the sail area. Amount of sailarea only determines how much more you need to depower a rig at the same high wind conditions
>>The boat weighs 78kg instead of 73 kg, ; This is neglectable
>>And of course it has a 15sm gennaker. Spinnaker does not introduce higher loads on the sidestay than when sailing upwind. It does not load the hulls up more than a jib does on the same upwind course. I haven't done the calcs on mast compression yet. Mast foot and beam however are unimpressed by a spinnaker. The increase in load is simply to small when compared how much a beam is overdimensioned to get the optimal beam stiffness. Beam is never in risk of breaking only flexing to much.
>>The hulls didn't break. : The hulls are build to resist shock and point loads this make the hull alot stronger than necessary for the sailing loads. Only serious point of concern are the sidestay chainplates. These do experience increasd loads to 170% to 200 %
>>The mast didn't break. : It was a M20 mast ; it was designed for double trapeze spi use.
>>The daggers didn't break. : This is interesting, These see increased loads to again 170% - 200 %
>>The rudders didn't break. : Rudders are less critical than the daggerboards. so if the dagger hold ..
>>The hardware didn't break. : Yes well, that is because for small open boats there is pretty much one line of breakstrength used on all boats from 14 foot to 22 ft.
Yet but the issue of flexing hasn't. For example It is not difficult to design a mast thatwon't break but it is difficult to design a mast that won't break and flexes in the right way and to the right amount to make a boat well behaved.
This is also interesting as indeed damage to beams and other stuff is nearly always the result of metal fatigue and low tension ruptures. These two do require above anything else "time". Still I trust Goran to design his products in such a way that both failing mechanism are unlikely to occure on his boats. Mostly these tow failing mechanisms are the result of lapses in design.
| | | extra draft
[Re: Hakan Frojdh]
#39364 10/25/04 07:19 PM 10/25/04 07:19 PM |
Posts: 9,582 North-West Europe | You estimate 40 mm extra draft when putting some 140 kg (double) - 75 kg (single)= 65 KG extra on it.
My estimate would be at least 50 mm, probably more. (When sailing on one hull, the other just lifted clear of the water)
Typically I use as "an rough extra draft" estimate the following formula :
(Length hull * width at widest point deck * 2/3 * 1/1000) * extra draft in mtr = kg's extra
or
5.49 * 0.30 * 2/3 * 1/1000 * X = 65 This leads to an increase in draft of 59 mm. 50 % more than your 40 mm estimate.
Even when using a shape factor of 3/4 (instead of 2/3) I arrive at 53 mm Increase in draft. Theoretically the shape factor of 3/4 is linked to a hull that is rectangular in crossection and that from the top looks like it is made up of 1 rectangle of halve the hulls length and one triangle of the halve the hulls width. It can easily be argued that this is the most extreme case with the lowest increase in draft. Real draft figures MUST be higher than any estimate this 3/4 approach produces.
P.S. The 2/3 approach compensates for the roundings of the hull from the 3/4 basic shape but still can be regarded as a underestimating approach.
| | | Re: extra draft
[Re: billrob]
#39367 10/26/04 08:59 AM 10/26/04 08:59 AM |
Posts: 1,226 Atlanta | billrob
Your arguement leaves out the rear beam slap factor. When a lightweight, tall rig boat, like the HT (or a modified 2 man A cat with a spin) is sailing in chop downwind the rear beam will hit the chop and cause the boat to pitch forward. Read Bob's discussion above, he witnessed this in action. The PUR boat was pitching in the chop and the crew had a hard time staying on board. If the boat is slapping and pitching in the waves, you are slowing the boat dramatically and if the crew doesnt have his wits about him, he will get thrown forward and then you are swimming. So your arguement is flawed unless you have flat water, which usually doesnt happen with higher winds.
A two man spin boat needs more freeboard, not less. The rear beam needs to be up out of the chop. Most the HT's have raised the rear beam and this solved the problem.
So I would argue that a wider hull - like the Bimare HT Hull would work better than a finer hull in practice.
Bill
| | | Re: you never do read it right weezy
[Re: Wouter]
#39370 10/29/04 12:57 AM 10/29/04 12:57 AM |
Posts: 390 | AS USUAL WEEZY IS ARGUING ABOUT SOMETHING THAT WAS NOT SAID OR IMPLIED. HE JUST DOESN'T UNDERSTAND ENGLISH VERY WELL.
This is not a correct conclusion from this test. As a matter of fact Booth made skilled use of how the design parameters behave when loading up a platform. WHO SAID IT WAS FROM THIS TEST? THE MARSTROM HAS BEEN FAMOUS FOR MANY YEARS FOR STRENGTH. WHY DON'T YOU KNOW THIS?
>>Is 2.5m wide, instead of 2.3m, : Does not seriously increase loads on the platform. I DIDN'T USE THE TERM "SERIOUS", YOU DID. BUT YOU AGREE THAT LOADS ARE INCREASED. the increases are accompanied by equal magnitude reductions. ONLY IF NOTHING ELSE CHANGES.
>>The mainsail is 15sm instead of 13.94sm, ; Doesn't matter ; righting moment determines the laod on a platform not the sail area. WRONG! A SAIL IS SUBJECT TO INSTANTANEOUS LOADS FROM GUSTS AND OTHER SHOCKS. YOU NEED TO LEARN ABOUT "ACCELERATION". YOUR SIMPLETON STATIC CALCULATIONS DON'T DETERMINE MAXIMUM LOADS. COMPARE THE INSTANTANEOUS LOADS OF A SLOW FLIP TO A VIOLENT PITCHPOLE. Amount of sailarea only determines how much more you need to depower a rig at the same high wind conditions WRONG!! SEE ABOVE
>>The boat weighs 78kg instead of 73 kg, ; This is neglectable NO DUH!!! THAT IS MY POINT. THE ONLY WEIGHT GAIN IS CAUSED BY THE ADDITIONAL EQUIPMENT.
>>And of course it has a 15sm gennaker. ;Spinnaker does not introduce higher loads on the sidestay than when sailing upwind. I DIDN'T SAY "SIDESTAY". SUPPOSEDLY, WHEN SPINNAKERS HAVE BEEN TRIED ON SOME A CLASS BOATS THE SIDE LOADS RIPPED OFF THE WINDWARD BOW. It does not load the hulls up more than a jib does on the same upwind course. THE SIDE LOADS ON THE BOWS FROM A SELF-TACKING JIB ARE MICROSCOPIC COMPARED TO A SPINNAKER. I haven't done the calcs on mast compression yet. DON'T BOTHER, IT WILL BE WRONG. Mast foot and beam however are unimpressed by a spinnaker. The increase in load is simply to small when compared how much a beam is overdimensioned to get the optimal beam stiffness. Beam is never in risk of breaking only flexing to much. MARSTROM ALREADY CALCULATED THE LOADS AND BUILT THE BOATS AND THEY DIDN'T BREAK. WHO ARE YOU?
>>The hulls didn't break. : The hulls are build to resist shock and point loads this make the hull alot stronger than necessary for the sailing loads. NO DUH AGAIN!!! REMEMBER, I SAID "FAMOUS". Only serious point of concern are the sidestay chainplates. These do experience increasd loads to 170% to 200 % WRONG, WRONG, WRONG!
>>The mast didn't break. : It was a M20 mast ; it was designed for double trapeze spi use. NO DUH THREE!!!
>>The daggers didn't break. : This is interesting, WHAT DOES THAT MEAN? These see increased loads to again 170% - 200 %
>>The rudders didn't break. : Rudders are less critical than the daggerboards. so if the dagger hold .. WRONG!! YOU CAN'T RACE A BOAT VERY WELL WITH BROKEN RUDDERS.
>>The hardware didn't break. : Yes well, that is because for small open boats there is pretty much one line of breakstrength used on all boats from 14 foot to 22 ft. WRONG!! THAT IS YOUR MOST RIDICULOUS STATEMENT YET. IF YOU ATTENDED REGATTAS YOU WOULD SEE THE DIFFERENT SIZES OF HARDWARE ON THE DIFERENT BOATS.
Yet but the issue of flexing hasn't. WHO SAID THE MARSTROM HAD A FLEXING PROBLEM? EXCESSIVE FLEXING OF A COMPOSITE MATERIAL CAUSES EARLY STRUCTURAL FAILURES. WHEN HAVE MARSTROMS FAILED? For example It is not difficult to design a mast thatwon't break but it is difficult to design a mast that won't break and flexes in the right way and to the right amount to make a boat well behaved. DID YOU FIGURE THAT OUT YOURSELF OR DID YOU READ ONE OF THE HUNDRED DISCUSSIONS ABOUT THAT SUBJECT?
This is also interesting as indeed damage to beams and other stuff is nearly always the result of metal fatigue and low tension ruptures. WHO SAID? WHAT ARE YOUR SOURCES FOR THIS STATEMENT? These two do require above anything else "time". Still I trust Goran to design his products in such a way that both failing mechanism are unlikely to occure on his boats. Mostly these tow failing mechanisms are the result of lapses in design.
Wouter PITIFUL, JUST PITIFUL!!! | | | Re: you never do read it right weezy
[Re: samevans]
#39371 10/29/04 05:50 AM 10/29/04 05:50 AM |
Well, I'm actually the guy that took a lightweight design of smaller dimensions and modified in almost every way as described in these posts.
This "fantasy boat" as you like to call it, is sailing and still very much in one piece, is now being used by AHPC as the blue print for their new Taipan F16 and has improved on the older design in stiffness among other things.
I didn't just guess at what would happen, I worked it out before applying the mods to the boat.
Having gone through all the stages from conception to completion and validation I think I can claim a little knowlegde in this respect and with regards to the mods considered by Hakan.
However, the question that remains is :
SO WHO THE *%#$@ ARE YOU in this little pissing contest ?
[Re: samevans]
#39372 10/29/04 07:57 AM 10/29/04 07:57 AM |
Posts: 1,884 Detroit, MI | What is a Troll? An Internet "troll" is a person who delights in sowing discord on the Internet. He (and it is usually he) tries to start arguments and upset people.
Trolls see Internet communications services as convenient venues for their bizarre game. For some reason, they don't "get" that they are hurting real people. To them, other Internet users are not quite human but are a kind of digital abstraction. As a result, they feel no sorrow whatsoever for the pain they inflict. Indeed, the greater the suffering they cause, the greater their 'achievement' (as they see it). At the moment, the relative anonymity of the net allows trolls to flourish.
Trolls are utterly impervious to criticism (constructive or otherwise). You cannot negotiate with them; you cannot cause them to feel shame or compassion; you cannot reason with them. They cannot be made to feel remorse. For some reason, trolls do not feel they are bound by the rules of courtesy or social responsibility.
Perhaps this sounds inconceivable. You may think, "Surely there is something I can write that will change them." But a true troll can not be changed by mere words. Why Does it Matter? Some people — particularly those who have been online for years — are not upset by trolls and consider them an inevitable hazard of using the net. As the saying goes, "You can't have a picnic without ants."
It would be nice if everybody was so easy-going, but the sad fact is that trolls do discourage people. Established posters may leave a message board because of the arguments that trolls ignite, and lurkers (people who read but do not post) may decide that they do not want to expose themselves to abuse and thus never get involved.
Another problem is that the negative emotions stirred up by trolls leak over into other discussions. Normally affable people can become bitter after reading an angry interchange between a troll and his victims, and this can poison previously friendly interactions between long-time users.
Finally, trolls create a paranoid environment, such that a casual criticism by a new arrival can elicit a ferocious and inappropriate backlash.
The Internet is a wonderful resource which is breaking down barriers and stripping away prejudice. Trolls threaten our continued enjoyment of this beautiful forum for ideas. What Can be Done about Trolls? When you suspect that somebody is a troll, you might try responding with a polite, mild message to see if it's just somebody in a bad mood. Internet users sometimes let their passions get away from them when seated safely behind their keyboard. If you ignore their bluster and respond in a pleasant manner, they usually calm down.
However, if the person persists in being beastly, and seems to enjoy being unpleasant, the only effective position is summed up as follows:
The only way to deal with trolls is to limit your reaction to reminding others not to respond to trolls.
When you try to reason with a troll, he wins. When you insult a troll, he wins. When you scream at a troll, he wins. The only thing that trolls can't handle is being ignored. What Not to Do As already stated, it is futile to try to "cure" a troll of his obsession. But perhaps you simply cannot bear the hostile environment that the troll is creating and want to go away for a while.
If you do that, then for the sake of the others on the system, please do not post a dramatic "Goodbye!" message. This convinces the troll that he is winning the battle. There is, perhaps, no message you can write on a message system that is as damaging as an announcement that you are leaving because of the hostility that the troll has kindled.
If you feel you must say something, a discreet message to the system operator (and some of the others users, if you have their email addresses) is the best course of action. Incidentally, if you are writing the letter in an agitated state, it is a good idea to wait an hour and then give it one last review before you actually send it. That might spare you the pain of saying things that you don't really mean to people you like. | | |
2,534
guests, and 340
