| Re: mast step
[Re: schobiedoo]
#40035 11/12/04 09:17 AM 11/12/04 09:17 AM |
Posts: 1,884 Detroit, MI | Not only does the head of the mast go crashing down when the person holding the base lets go - the base comes up!  You don't want to get up close and personal with the base of the mast as it comes up. People have lost teeth and worse. That's why Hobie invented the mast step link. People were getting hurt when the hook slipped out or broke off. You can retrofit old castings to accept a link, but it may be easier just to buy a used casting from a dealer or from eBay. | | | Re: mast step
[Re: JonandOliver]
#40037 11/15/04 02:14 PM 11/15/04 02:14 PM |
Posts: 152 Central Texas | Mast stepping... Hmm, guys... he is planning on stepping the mast once and than keeps the thing sitting outside.  Besides the fact that I would not keep the boat outside over the winter I would give it a shot. You could rig a rope connecting mast and front cross bar - limiting the mobility of the mast - reducing the risk for the person who is positioning the mast. Main Halyard... depending on the type of mast tip, you have one or two pulleys guiding your halyard. These pulleys are designed for small diameters (wires). It might be possible to find some small diameter rope (3/16 might work with some type of high tech core - vectran) that would do the job but the price might be close to the amount of the wire halyard and some cheap 1/4 polyester rope. A disadvantage of the all rope halyard would be more stretch (double mast length - about 50 feet of rope). You would have to estimate here a bit - the high tech stuff does not stretch a lot. You might be out of compliance in case you want to race the old thing. The advantage of this type of setup would be the ease of use - that you do not have to deal with the hook which is often a PITA when you have no time or space to deal with it. Patrick
Patrick, Hobie 16 '85
3,175
guests, and 228
Mod | | Forums35 Topics22,989 Posts268,931 Members8,150 | Most Online23,979 Sep 24th, 2025 | | | |
