| Furling jib on N6.0na ??? #40351 11/22/04 03:56 PM 11/22/04 03:56 PM |
Posts: 99 Chicago, IL | I’m thinking of adding furling jib on my N6.0na. Is it safe to use Harken 435? (That is the one that I have) or should I buy Harken 436. The Harken website suggests that 435 is for catamarans 18 feet and smaller.
Also, I will be flying a spinnaker.
Anybody have any experience with those? I would appreciate any input.
Thanks
Kris
I20
| | | Re: Furling jib on N6.0na ???
[Re: Krisu13]
#40353 11/22/04 04:44 PM 11/22/04 04:44 PM |
Posts: 12,310 South Carolina | I know some folks that used the 435 on the 6.0NA to furl the jib. When I had set out to do it on mine, I had purchased the 436 - just to be sure! If you use the 435 - make sure you have the hi-load bearings installed. I believe they're brown instead of greenish.
Note that while the furler is nice and convenient, unless you do some really creative rigging, you loose the ability to actively adjust the jib luff tension...which is not good for any kind of racing.
Jake Kohl | | | Re: Furling jib on N6.0na ???
[Re: Krisu13]
#40355 11/22/04 07:43 PM 11/22/04 07:43 PM |
Posts: 99 Chicago, IL | Thank you all for your input. I guess I will sale my Harken 435 set and look for 436.
If you have one let me know.
Kris
I20
[Re: Krisu13]
#40356 11/22/04 08:48 PM 11/22/04 08:48 PM |
Posts: 1,200 Vancouver, BC | I used to use a Ronstan upper swivel and a Hobie 18 style lower drum furler on a tornado. Worked good for many years in many high wind conditions and high rig loads (side stays loaded pretty good and 8:1 mainsheet tension to the max). I even worked out a sweet jib luff tension that worked through the lower drum. Here are some pics: Jib Luff Tension #1 Jib Luff Tension #2 In this shot, look to the lower right of the pic on the mainbeam...there is a 3:1 purchase micro cleat...doubles the 2:1 at the drum for 6:1 total. Luff Tensioner Adjuster Mike.
485
guests, and 650
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online7,715 Sep 13th, 2025 | | | |
