what paint for comptip? #40388
11/22/04 10:09 PM
11/22/04 10:09 PM
South Florida
SOMA Offline OP
SOMA  Offline OP
South Florida
Any tips on what to use to repait the comptip on my TheMightyHobie18? The fiber is showing through all along the front edge. I thought I read somewhere that it has to be something that is non-conductive. Is there something special for this??
Thanks
Fred F (ex Hobie 18)
Re: what paint for comptip? [Re: SOMA] #40389
11/22/04 10:23 PM
11/22/04 10:23 PM
California
mmiller Offline
mmiller  Offline
California
The CompTip outer material is basically, Gel Coat. You should be able to use a rubbing compound or polishing compound to return some amount of black shine. Depends on how deeply oxidized it has become. Worst case the gel has worn thin and is showing fiber. That would require a paint. Epoxy or Vinyl paint.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: what paint for comptip? [Re: mmiller] #40390
11/23/04 10:40 AM
11/23/04 10:40 AM
catman Offline
catman  Offline
For a really good epoxy paint in a spray can go to your local motorcycle shop and look for a brand called PJ1. They make the black in gloss, satin and flat. To hide the fiber you might let the paint set and then wet sand the fiber areas and recoat. Make sure you follow the directions for weather conditions. The paint does take a while to fully cure.
Re: what paint for comptip? [Re: catman] #40391
11/23/04 02:49 PM
11/23/04 02:49 PM
South Florida
SOMA Offline OP
SOMA  Offline OP
South Florida
Thanks guys, I appreciate your input. I'll look for that product.
Thanks
0 registered members (), 377 guests, and 35 spiders.
