| Re: Formula class rules yearly review ! READ !
[Re: Mary]
#41005 02/08/05 11:21 AM 02/08/05 11:21 AM |
Joined: Jun 2001 Posts: 9,582 North-West Europe Wouter OP
Posts: 9,582 North-West Europe | What is your pole length ?
What is the overall area of your spi/hooter ?
What is your spi hound height (gate height) on your mast ?
What is your mid-girth measurement ?
That are the only 4 limits that are set on the use of any headsail. Be it either a spi, a gennaker, a hooter, or an (as you wrote) hour glass shaped headsail.
With regard to the Hobie Wave I need to know the specs that are ruled upon in the F16 class rules. Things like mastheight, width, length, weight, combined sailarea, luff lengths, etc.
If the Wave fails on any of these accounts than it is not Full F16 Compliant HOWEVER you can appeal to sections 5 and 6 of the class rules that allow the grandfathering of your Wave:
This is defined as :
7.26 Grandfathering
The allowing of non Formula 16 compliant designs to race against fully compliant Formula 16 designs
In summary it comes down to showing that your boat has a rating equal or slower than F16's (and implicitly F18's as well) under BOTH the ISAF and TEXEL handicap systems and requesting a dispensation for your non complaince with the local F16 class head. That is when officially accepting to race "First-in-wins" with any and all other F16 and dispensated F16 designs.
Up till now we haven't refuse anyone. And I suspect that the Wave may just be on the right side of the ISAF/TEXEL rating threshold even with a non-compliant F16 headsail.
[Re: Wouter]
#41006 02/08/05 11:42 AM 02/08/05 11:42 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Wouter, I still don't know what you mean by "level racing with the F18's, the biggest class around." Since they are the biggest class around, aren't they racing as a class? They don't allow the F16's to race with them in the class, do they, since you don't fit their class weightwise?
And if you are racing against them on handicap, what difference does it make what sails anybody wants to use and what kind of rating they want to use. I just don't understand this interest in the handicap rating. Must be something different about how you do handicap racing in Europe. Please explain that (briefly). | | | Differences
[Re: Mary]
#41007 02/08/05 12:17 PM 02/08/05 12:17 PM |
Posts: 9,582 North-West Europe | Mary,
I do very much understand your confusement.
The answer is twofold :
-1- F16 class is a class with the largest portion of its weight localized outside of the USA
-2- Racing outside of the USA is 80 % single fleet - open class racing, In Europe this is over 90 % or all cat racing.
The F16-racing-level-with-F18's aspect may not be that important for US sailors but it is for non-US sailors. In Europe all our club races, Cup races and regatta's are single fleet - open classes. If you have the same handicap as the F18's then you effectively race them first-in-wins for all trophies whether they like it or not. Same applies to racing the A-cats and they dislike it with a passion; that spinnaker does make a huge difference !
Even at (rare) events that contain designated class events, like point regatta's, the open-class single start fleet contains a multiple of unmeasured and unaffiliated F18's and F20's. These are crews without membership or without valid measurement forms. Even at these RARE events the open fleets range in size from 20 to 35 boats of which 70 % is still F18 and F20's. In Europe at least, realtively small classes like the A-cats as good as always share a start with another fleet and their score is then later filtered out of the larger score. In Europe we hardly ever give classes their own start and it is only seriously considered when the class requesting it takes care of all its own [censored] and when you can garantee that 15 boats of more are racing. But still 90 % of the races/events is "single fleet - open class" even if you come with more than 15 boats. Sometimes if a event attracts more than 80 boats in total a split is made between slow and fast boats and each is given their own start/course (completely seperated) but only is each class has at least 30 boats or more. It is regarded that this is more fair to the smaller boats out there as these are more often then not owned by recreational sailors. Makes racing for them more interesting.
In the Netherlands even the H16 doesn't get more than 2 events per year with their own start. Often it is only one event, their own nationals.
It is very different outside the US and as the F16 class is building herself up in all regions we target all local strongpoints together. For some regions this may seem strange, but it is all very easily explained. And it is actually very logical as well. If you want to be a true international class then you just have to do these things.
Australia isn;t much different, nor Asia. South Africa is somewhat different but even they do mingle fleets quite often. Pretty much sailors in all regions are positive about it. The more boats and crews you have beaten (even on handicap) the more glory you have gained. And people come out to events as they always race in a sizeable fleet. I truly think this is a contributing factor that cat sailing in Europe is on a sizeable level.
And it is difficult to explain to US sailors that a 4 or 5 boat fleet is not regarded as a class earning their own start outside the US. You REALLY have to put some high number of boats on the water in order to be regarded as a class that possible could entertain such thought and then still, most events won't give you your own start anyway.
[Re: Wouter]
#41008 02/08/05 12:39 PM 02/08/05 12:39 PM |
Posts: 13 Scotland | Having finally got round to reading the yearly review ans especially all the "Hoo - Ha" regarding carbon mast tip weights etc i've decided to ad my bit. I've owned a Stealth for 4 years and in all that time and with considerable amount of "mis-treatment" i've had NO problems. In fact the thing i like most about my Stealth mast is its light weight when rigging it. When i bought my boat the F16 class either didnt exist or was dormant but i've been prepared to go along with it on the understanding that my boat was fully legal to compete in F16 class racing but if this latest example of petulance and a need to show off one's engineering expertise is going to take place often then you can shove the class association where the sun doesnt shine ! I bet the other class associations must be laughing at us and our antics. And as for the wit who said we wont run out of alloy try telling that to the Hurricane owner who hasnt had a mast for 6 months because there are no sections available and a minimum order that would be enough for 50 masts - he's trying to get a carbon mast as we speak ! STOP the petty point scoring and get on with something more constructive - PLEASE
Keen Cat Sailor
| | | Re: Differences
[Re: Rolf_Nilsen]
#41011 02/08/05 02:44 PM 02/08/05 02:44 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | With danger of hijacking the thread, do you need ISAF aproval to hold a World Championship in a non ISAF international approved class? According to ISAF, you do. We already held a Worlds with our Wave Class. We were threatened that everybody who participated in or helped with the event would be punished by losing their eligibility to sail in major ISAF-sanctioned events like Olympics, Pan American Games and ISAF World Championships. We were also told that the host country would never be allowed to become a National Governing Body for sailing and would never be able to put a boat in the Olympics. ISAF claims to control sailing in all its forms throughout the world, racing and non-racing, and claims possession of the words "World" and "International." I guess the answer to your question is that, No, you do not need ISAF approval to hold a world championship if you are not an ISAF Class and if nobody in that class cares whether they get punished by ISAF or not. But ISAF can make things very difficult for you by threatening the host country and threatening race officials and by scaring away people who might want to participate but are afraid of the sanctions because they DO want to be eligible for major ISAF events. That is the only way ISAF can "control."
| | | Re: Differences
[Re: Darryl_Barrett]
#41017 02/08/05 09:25 PM 02/08/05 09:25 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Darryl, It's not quite that simple. You cannot call it anything that even implies or gives the impression to anybody that it is a world championship. I like your ideas, but I don't know whether they would be acceptable.
Even the Caribbean Championships are not technically "legal" under ISAF because that would constitute a regional championship, which would have to be approved by ISAF. I was told that ISAF is letting that happen because that region is in the process of applying for status with ISAF.
Based upon what I was told, technically any class that is not an ISAF International or Recognized Class cannot hold North American Championships, because they involve more than one country. So far this has not been enforced here.
The International C-Class Catamaran Championship (Little America's Cup) was just as illegal as the Wave Worlds was, because the C-Class is no longer an ISAF international class and is not allowed to use the word "International" for its event or in the name of its class. ISAF will be looking into this, I was told. | | | Re: Differences
[Re: Mary]
#41020 02/08/05 11:50 PM 02/08/05 11:50 PM | Anonymous
| Anonymous
Unregistered | I realize that the following would not move the ISAF one bit, but...
IMO, by excluding sailors on grounds other than ability (e.g. those who have sailed in a non-ISAF "world championship"), just on principle the ISAF forfeits the legitimacy of any claim that an event they sanction is in fact a real world championship. It no longer provides a defensible determination of the best willing and able competitor in that class.
So much for protecting the integrity of the sport.
Mark. | | | Re: Differences
[Re: Mary]
#41023 02/09/05 12:38 AM 02/09/05 12:38 AM |
Posts: 9,582 North-West Europe | Wouter, am I right in assuming that you are planning to ask for ISAF Conditional or International status for the F-16?
I'm not planning things to go in either way at this time. Everything you are doing seems to point in that direction.
That is not the reason I'm doing them. Currently we are just making sure that we're surrounded by friends by not kicking into an shins. The actions that you see have all to do with internal class structures and the fact that we are preparing ourself for what is to come. If so, are the manufacturers in favor of that? ISAF International Class status can be a burden on them and also raise the prices of the boats.
Builders have not given me their final take on this. What are the benefits of having International Status, beyond being "allowed" to hold a World Championship?
Good question. We need to pay some 3000 Euro's entry fee as well and we simply don't have that as a class. So for now the issue is in the refrigerator by necessity. Wouter
| | | Re: Differences
#41024 02/09/05 12:41 AM 02/09/05 12:41 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Darryl, When sailors violate ISAF regulations, I think it would be rare for their eligibility to be suspended more than a year or two, depending upon the offense. The threat against the host country sounded like it was forever, though. And if any ISAF race officers, judges, measurers, etc. happened to help with the event, they were threatened with losing their certifications. | | |
11,362
guests, and 381
