Page 3 of 5 1 2 3 4 5
Re: Jibs & Spinnakers [Re: scooby_simon] #41264
12/17/04 07:39 PM
12/17/04 07:39 PM
Dublin, Ireland
Dermot Offline
Dermot  Offline
Dublin, Ireland
How did my Hobie 20 post jump to Wouter's "Mouse Trap" thread It is listed in both
Dermot
Catapult 265
Re: Excelsheet available to all who want it [Re: scooby_simon] #41265
12/17/04 07:46 PM
12/17/04 07:46 PM
Quickly spotted one slight error, the weigh od the Inter 17 is 161 with the Spi rigged (and it makes a difference of one point on rating)
Also, I dont really think an Inter 17R(spi) is quicker than an F18 in light and the same in heavy.
But it is a start
Good work
I'm think that may actually be acurate...or close to it. The I17R carries less crew weight and points higher.
Re: Excelsheet available to all who want it [Re: Jake] #41266
12/17/04 07:47 PM
12/17/04 07:47 PM
But it is a start
Good work
But also less righting moment and less pairs of hands
Re: Excelsheet available to all who want it [Re: Jake] #41267
12/17/04 07:48 PM
12/17/04 07:48 PM
Which rating sys will bring the SC20 rating down to a realistic level? That's the one I'm for.
JC
Scooby, read CAREFULLY ! [Re: scooby_simon] #41268
12/17/04 07:59 PM
12/17/04 07:59 PM
Wouter Offline OP
Wouter  Offline OP
-1- I used the Texel core so all weights are excluding the spi gear, take a look at the F18, F20, F16 weights as well It is something I want to take out of the system as well as stated in the "Potential other mods" post, but I haven't done it yet. You can pretty much 1 point to all spi boat ratings if you use the weights including spi gear and then subtract 1 point because I will lower the spi hit to compensate. End result ? Zilch. That is one reason why I haven't implemented it yet. I'm waiting on some feedback from others.
-2- I-17R, this is an identified problem point, see the post publicizing the numbers. I'm hoping that US data and Mark Schneider can help me here. I don't have good I-17R with spi data. There is one thing to say for the NMBR rating for the I17R. This boat has almost the same mainsail and mast as the F18's on a lighter platform with less crewweight and a considerable spi. If the fundamental Texel formula is right (Not entirely sure here see post) than the I-17R should be faster in light air ! However I think NMBR makes it too much faster. I feel the cause for this is found in the Texel rating formula itself. Hence my suggestion to do a new regression on the data. In summary; we are working on it.
Also please correct the wrong width for the I-17R ; the sheet says 2.60 mtr. but it should be 2.50 mtr I believe.
>But it is a start,
I would say look at the other things, these seem to work pretty well. Of course it is a bit much to ask to get it right the first time. Some tweaking is required.
Re: Scooby, read CAREFULLY ! [Re: Wouter] #41269
12/17/04 08:04 PM
12/17/04 08:04 PM
I(F)17R should be 2.5 wide (same as I17)
F17 press release
Hey Jake ! [Re: Jake] #41270
12/17/04 08:23 PM
12/17/04 08:23 PM
Wouter Offline OP
Wouter  Offline OP
Hey Jake,
You can help me here. (either via the forum or in private)
I don't have much data on these singlehanders and I'll need that in order to tweak the single handers. You as a F18 sailors may help us out here.
How often have you sailed against these singlehanders and how did they compare to your F18 ?
I'm particulary interested in the I-17R as that is such a clear example and I can cross reference it with I-17 data. These are great setups; Identical setups with only a small of differences. Makes for great tweak keys.
How about a NMB rating for the SC20 of .... [Re: ] #41271
12/17/04 08:41 PM
12/17/04 08:41 PM
Wouter Offline OP
Wouter  Offline OP
How about a NMB rating for the SC20 TR with spi of
Light weather 88
heavy weather 92
SC20 TR no spi :
light 91
heavy 96
Compare to US I-20
Light 92
heavy 95
Seems a whole lot better doesn't it ?
I used the following specs (please give me the correct one if they are wrong)
weight 200 kg (441 lbs)
length 6.10 mtr (20 foot)
width 3 mtr (10 foot)
Mast 11.5 mtr (38 feet)
Mainsail 22 sq. mtr. (236 sq. ft.)
Jib 6 sq. mtr. (65 sq. ft.)
And I only needed 60 seconds to acquire a rating and that included looking up estimates of the specs via internet
Is that satisfactory ?
Wait a minute ! [Re: scooby_simon] #41272
12/17/04 08:55 PM
12/17/04 08:55 PM
Wouter Offline OP
Wouter  Offline OP
Wait a minute. You can't use the righting moment excusse here ! In light winds (NO TRAPEZING group) righting moment is not an issue as all crews can then generate more rigting moment then they need.
And in the strong wind rating the righting moment was calculated and used to compensate the rating. The I-17R received a swing of 6 rating points (3 minutes and 36 seconds) while the F18 good a swing of nothing ! By this the I-17R is rated slower than the F18 in the heavy weather rating (trapezing group)
You may think the swing is still not enough but you can't say that NMBR doesn't take "less righting moment" into account because it does.
>> less pair of hands.
Well yes, that is another matter although in the light stuff this may not be much more of a factor than 1 or 2 rating points. I mean how much longer do you need as a singlehander to set or take down a kite in race. A few second. Will 36 to 72 second compensation be good enough for that ?
By any account this is only a small offset.
In strong winds I say "less pair of hands" is a bigger factor.
Again guys please look at the other things as well. The single hander with spi was already identified as an point of attention in the post giving the NMBR table. The spi hit to singlehanders seems to be a bit harsh, I'm contemplating what to do with it already.
What do you guys think of the H16's versus F18 for example or the evert recurring Curacau US I-20 to EU I-20 issue ?
The provisional NMBR sheet can now be viewed here [Re: Wouter] #41273
12/17/04 09:06 PM
12/17/04 09:06 PM
Wouter Offline OP
Wouter  Offline OP
Re: The provisional NMBR sheet can now be viewed here [Re: Wouter] #41274
12/18/04 02:16 PM
12/18/04 02:16 PM
Hey Wout,
The SC20 is 12' wide, but i'm not sure about the wt and sa. What does the change in beam do to the #?
New rating for sc20 because of 12 feet width ... [Re: Wouter] #41275
12/19/04 09:47 AM
12/19/04 09:47 AM
Wouter Offline OP
Wouter  Offline OP
Here is the rating correction for the 12 foot wide SC20 over the earlier presented 10 feet wide numbers
New specs
width 3.66 mtr (12 foot) (This is some mightly wide boat)
Mainsail 22 sq. mtr. (236 sq. ft.) luff being 11 mtr
Jib 6 sq. mtr. (65 sq. ft.) luff being 5.5 mtr.
+ spi
New ratings SC20 at 3.66 mtr width
Light weather 88
heavy weather 89
Compare this to :
SC20 at 3.05 mtr width
Light weather 88
heavy weather 92
And the US I-20
Light 92
heavy 95
If we take the spi off the SC20 than :
Light 91
heavy 93
I think this reflects the (scarce) real life data well. At least heaps better then PN of 64.1 vs that of 59.2 to the US I-20
Notice how the new width didn't change any off the light weather ratings (No trapezing group); only the strong wind ratings (Trapezing group).
Again we needed only a few seconds to get the new numbers.
Also interesting is to compare the "sc20 at 12 feet width" numbers tot the ones of the M20
M20
Light 86
heavy 90
So the M20 is expected to be 2 points faster in the light stuff and a fraction slower (1 point) in the heavy stuff.
The M20 has a 4 point rating swing from light to strong and the SC20 only 1 point. This all due to the ratio between rig and width. The Hobie 16 (L = 116 ; H = 114) of course has a opposite swing (getting faster) of 2 points. So the difference between the M20 and the H16 reduces from 30 points to 24 points when the wind conditions transitions from no trapezing conditions (light winds) to Trapezing conditions (heavy winds). The difference between the SC20 and the H16 only swings from 28 points to 25 points. To go one further US I-20 (L92-H95) vs H16 : difference goes from 24 points to 19 points. However the difference between the H16 and a nacra 5.0 remains about the same (0 point differnce to 1 point difference). Both of these speed up equally due to changing wind conditions.
Isn't this reflecting what we see on the race course ?
Re: New rating for sc20 because of 12 feet width ... [Re: Wouter] #41276
12/19/04 04:45 PM
12/19/04 04:45 PM
Annapolis, MD
Mark Schneider Offline
Annapolis, MD
Hi Wouter
I have been rescoring our buoy's regattas with the new rating scheme and the results look pretty good in that the elapsed time differences needed to win are pretty close for what I would argue are sailors of equivalent ability.
I had to guess at numbers for the Hobie 20 and the Shark is there any data in texel that can be used to compute a pair of ratings.
Mark
crac.sailregattas.com
Answers for Mark [Re: Mark Schneider] #41277
12/19/04 09:36 PM
12/19/04 09:36 PM
Wouter Offline OP
Wouter  Offline OP
Thanks alot Mark for your first report on running the numbers on your race data.
It makes me feel very good that the initial test shows some encouraging performance.
I'm looking forward to the report after you have run it all. You know some tweaking can still be done.
You what's funny, there are some points I think to be remarkable but it may well be that my own prejudice is unwilling to believe what the formula's are saying. So again, I'm looking forward to your commment and or report after you've run the data on it.
Texel data :
http://www.texelrating.knwv.nl/
Hobie 20 :
Best look up the Miracle 6.0 in the Texel rating and use that data. It is my believe that this boat is the same as the US Hobie 20 Miracle. One point of note though, Hobie NEVER officially imported the H20 Miracle to Europe. So these are "privately" imported boats and may have undergo some modifications with respect to the US versions. Never the less it is a good place to start.
Shark :
There is a shark catamaran in the listing but I'm sure wether that is the same Shark that you use in the USA. ONly way to know for sure is to contact the Shark class association and ask them about the specs.
I can tell you however that IF the Texel listing doesn't have the numbers on a boat that NO other rating system has them. Not ISAF and certainly not the Yardsticks. The Texel listing is by far the most extensive data base on catamarans around.
If a boat is still not named in the listing that the following rule of thumb works pretty well.
Length : Take the length overal or waterline length. The rating is not very dependent on which one you use.
weight : Often this is easy to guess. 14 ft = often about 100 kg, 16 ft = often about 135 kg, 18 ft = about 160 kg 20 ft = about 190 kg
Sail area = Take an F18 sailarea and scale this area in height to the mast area and in width to the hull length.
Luff length main = mastlength - 0.5 mtr. (a very good estimate)
Luff jib = nearly always between 4.25 and 5.5 mtrs. depending on the overal size of the boat. A rought guess will do here
Shark catamaran part deux [Re: Wouter] #41278
12/19/04 10:04 PM
12/19/04 10:04 PM
Wouter Offline OP
Wouter  Offline OP
mark,
This is what I found after some 60 seconds on the internet and thanks to a post by Same Evans.
http://www.sharkcatamaranclass.org./WHAT.HTML
Shark specs
Length 20 ft (= 6.10 mtr)
Width 10 ft ( = 3.05 mtr)
Weight 450 lbs (= 204 kg)
Mast Height 28.5'= 8.69 mtr => give mainsail luff estimate of 8.19 mtr.
Sailarea total 275 sq ft. = 25.6 sq. mtr. => lets divide that into 18.6 sq.mtr. main and 7 sq.mtr jib
Jib luff should be about 5 mtr with a mastlength and boat width like this.
daggerBoards
No spi
These estimates (and facts) give the shark a provisional rating (we had to guess at some specs) off
Light 99
Heavy 98
I ran the numbers on the Hobei 20 as well (the number that I know or estimate)
specs
Length waterline = 5.82 mtr.
width = 2.5 mtr (?)
weight = 201 kg
main = 17.97 sq. mtr. by 8.81 mtr luff
jib - 6.34 sq. mtr. by 5.74 mtr
Boards
No spi
NMBR ratings
light 100
heavy 102
Mark I send you an excelsheet so you can punch in the numbers of some other boats you need yourself
Shark part 3 [Re: Wouter] #41279
12/19/04 10:14 PM
12/19/04 10:14 PM
Wouter Offline OP
Wouter  Offline OP
I appears that the Texel rating listed Shark is about the same boat. Only texel lists a shorter mast and less overall sailarea.
On these texel specs the shark get the following NMBR numbers
light 101
heavy 99
If we have to guess at it a number around 99 seems to be right. Only this design is pretty old and arguable less efficient. I'm not to sure wether the NMBR rating gives a very accurate prediction here. Afterall NMBR estimates potential for a given box of specs. It is up to the skills of the designer to bring out that potential in real life. ONE-Design classes of 40 years are arguably at a disadvantage here. They can grow with the new developments.
But I anxious to hear how these numbers come out of your tests
Re: Shark part 3 [Re: Wouter] #41280
12/20/04 01:52 AM
12/20/04 01:52 AM
The Shark was originally designed to fit into the IYRU B-Class specifications, with 235 square feet of sail. But the Sharks that were exported to the United States (and those that were subsequently built in North America) had the higher sail area of 275 square feet because the United States, in general, has lighter wind conditions than Europe.
So any Sharks sailing in Europe may have the original sail area of 235 square feet. (I don't recall ever hearing anything about a difference in mast height between the Sharks in Europe and those in the U.S.)
Plus, the Shark has centerboards, rather than daggerboards, and the maximum depth is 3'6".
NMBR is easily adjusted to distance racing handica [Re: Wouter] #41281
12/23/04 07:38 AM
12/23/04 07:38 AM
Wouter Offline OP
Wouter  Offline OP
NMBR is easily adjusted to produce distance racing handicaps.
The idea behind it is quite simple and yet simply copying the same approach to Texel / ISAF and Yadstick systems will not result in the same accuracy.
Here an explanation of how it works
Pretty much we can devide any race over three main courses.
-1- Pure upwind sailing (as high as one can)
-2- Pure down wind sailing (as low as one can)
-3- And the widened area of reaching (anything between the regions of -1- and -2-)
-1- is most impacted by righting moment and pointing ability.
-3- is most impacted by having a spinaker or a jib
-2- is mostly impacted by good hull design and efficiency of the traditional sailarea (only main and jib)
Right at this moment both the spi hit and the righting moment correction are implemented as follows. (I only give part of the equation, only the working core.
(0.5 * spi hit + 0.5 * righting moment corr) / 1
The 0.5 is actually a course distribution factor. We have currently taken 0.5 as most data I have right now suggest that a non-spi boat takes about roughly 50% of the time to go upwind. Some tweaking can be done here.
By changing this course ratio to say 100 % upwind and 0 % downwind we can produce custom handicap numbers for races like the Tybee 500 and steeple chase. Of course any ratio between 0 % upwind work and 100 % upwind work is possible. By changing these ratio's one can see that the impact of both the spi hit and limited righting moment hit are forced to influence the ratings proportionally to the sailed course.
Smart people will notice how the reaching leg in not implemented yet but by adjusting this formula too :
(Downwind portion * spi hit + (1 - downwind portion - upwind portion) + upwind portion * righting moment corr) / 1
and use 2 percentages to defined the course. Portion upwind and portion downwind. The reaching portion is then the remainder.
This way we can modify the framework by including the reaching legs. On these legs no spi hit or righting moment corrections are taken and so the pure speed potential under traditional sails (main and jib) is taken and assumed to be fully powered up all the way over the conditions.
The framework is simple to implement and by adjusting just two input variables the excel sheet will produce ALL the new custom handicaps for a distance race within a blink of an eye.
It can be proven theoretically that the accuracy of the rating is somewhat less than those for a well layed out bouy race (for which the rating were optimized) HOWEVER, the same proof shows that the NMBR custom rating will be noticeably more accurate than all other systems in use today. Simply because it DOES compensate for the different course shape of the distance race AND because it does so in a way that is SIMILAR to what happens in real life. To how real life physical processes determine the performances under the different distance racing conditions. Ex. We all understand how sailing 90 % of the time upwind and 10 % of the time downwind under spinnaker proportionally impacts on the benefit of having a spi. The shown framework does compensate in exactly the same way.
The same framework can not easily be copied and used with Yardstick systems as in Yardstick systems the distribution between upwind, downwind and reaching performance is simply not known. One needs this in order to have them impact on changing course distributions.
Texel nor ISAF can easily use this setup untill they change the way that they implement the spi hit. By this I mean that they can't use it untill they have decoupled the spinnaker and jib related performance on the downwind legs. This is pretty fundamental stuff and many important people unquestionably want to discuss such a thing at great length.
So distance race organisers !
There is also a better mouse trap for you guys.
The plan to get the NMBR system accepted [Re: Wouter] #41282
12/23/04 08:24 AM
12/23/04 08:24 AM
Wouter Offline OP
Wouter  Offline OP
The plan to get the NMBR system accepted.
The first conclusions by some reviewers (independent from my person) are that the NMBR system, in its current stage, appears to produce more balanced scores and put crews of assumed equal ability closer to together. One comment was that it actually looks pretty good. I'm quite contend with that.
But this puts us to the next level.
There are two things that need to be done :
-1- additional testing on real life race results and possible tweak the system a little here and there for extra accuracy
-2- Start up a program to contact all the rating committees and get the system accepted.
Point 1 and point 2 can be executed simultaniously as more and more signs are coming in that NMBR is producing better results than its alternatives. So additional accuracy is welcomed but not necessary. Also the largest gains of NMBR are to be found in its ease of use. It involves much less work than a yardstick system. For the ISAF/Texel corner the NMBR system solves a few claring issues and produces much more realistic results for the same effort in maintaining it as the ISAF/Texel systems currently in used. Also it is more flexible as it can produce custom ratings for one-way handicapped races etc.
Right now, I'm working out a plan to tweak the system further; I'm in contact with a US party for that.
With regard to acceptance I propose to go about it in the following way.
-1- Consolidate contacts with the USPN committee. Right now they are the party to most benefit from it and it will allow them to offer a remedy to RC considering breaking away from USPN in favour of Texel like rumour has that Tybee 500 is considering. In short the time appears to be right to expose the USPN to an alternative.
-2- Next step will be to contact ISAF as I know they are looking to improof on their system for several years now. Not much is happening so I think they are at a dead lock. The medicine might well be to expose them to a fully operational system that US parties have tested for improved accuracy. Simply put we can use the US to break open the possible deadlock inside the ISAF committee. Afterall, ISAF would like to see a single system around the world and the US is very much an sizeable and important block in that. Also this is the most effective way for US sailors to influence ISAF into a system with wind dependent handicaps etc. In short to make them accept some of your wishes/demands. Of course ISAF is looking to stuff Texel as the more dominant system. So the US is the juicy bone and having a noticeably better system is the rewards for ALL OF US.
-3- Of course if USPN and ISAF go like domino's than we can really put some pressure on the Texel system and most likely get them to accept to NMBR system in it total without counter demands. I think I have the inroads to that already. I hope my former collegues at the Texel system will forgive me for this but the current make-up of the committee is in need of a make-over and nearly all parties cooperating with the Texel committee adhere to that view. So in short is the old committee holds out despite convincing arguments then I will contact the parties using the system directly and pry them of Texel that way. It will be their call to decide to co-opt or be made disfunct.
-4- Yardstick systems in general. Well Yarstick in the UK is already losing to ISAF at this moment. The transition is slow because of the large and known issues in ISAF. With NMBR these are as good as solved and so further resistance will be solely based on emotion and not on verifiable concerns. Asia, africa, and south america are largely to small to maintain their own independent yardstick systems. Alot of them already use ISAF or TEXEL because that is much easier for them, when the US and the EU are on the same line regarding a handicap system then surely they will all transition to that system over time as well.
-5- Australia and New Zealand. This will be tricky as these scenes tend to be very independedly minded. However right now several yardstick systems are still competing with eachother also the dominant VYC suffers from all the issues linked to yardstick systems and uses on 1 rating number for all conditions. Arguably for them a large improvement can be gained by using NMBR. The largest of all. It will probably take some massaging but also when US and EU are in agreement than such a thing must go a long way in presuading the Aussies.
As you can see ; USPN and it committee play an important role in all this. They are the first step and those are always very important. However I do plan to be in contact with several parties simultaniously.
I'm expecting a list of demands from several parties (or should I say whigs) however I will not accept any demand that are different from a general wishes regarding the use, shape or accuracy of the NMBR system.
Simple reason being that I see no point in sacrificing ease of use and accuracy simply because a whig wants to boast that he influences the development of the NMBR system.
I will give an example ; a party can demand that a rating should be adjusted when a carbon mast is used. I for one do not claim to know how strongly and in what way a carbon mast affects performance. Nor do I know of a easy and simply way to implement a fair correction. In addition I can't even proof that having a carbon mast impacts on a boats performance in such a significant way that it requires a handicap rating correction. To give an example ; the case for hitting wingmastswith prebend and spreaders when compared to a spreaderless teardrop shape mastsis ALOT stronger and yet NO-ONE ever felt the need to hit wingmast individually. I found that the mere mentioning of carbon makes alot of sailor skittish. This is an emotional response and in many cases it is not well founded in physical phenomena or even real life.
I do very much expect from the official that they make a profound effort to understand why certain things (factors) were included and others were not.
In general I compare this to the following example.
Double glassing.
Going from single glassing to double glassing for windows gives a 50 % reduction in loss of warmth and thus leads to fuel efficiency in the home and savings despite the extra expense linked to double glassing. We can repeat the trick of course a good for triple glassing or event quadriple glassing. The gains will be additional 17 % and 8 % respectively when going from one to another. Theoretically speaking additional gains are made however in reality triple and quadriple glassing doesn't make economical sense, the costs of these outweight the potential gains. It is therefor foolish to seek such windows.
Measurement ratings systems are much the same. After a certain minimal number of inputs the potential gains of adding another input will become very limited and more often then not the additional costs of such an addition will outweigth the potential gains. Carbon mast hits were just such and example and actually ISAF has done away with those in 2003.
Re: NMBR is easily adjusted to distance racing handica [Re: Wouter] #41283
12/23/04 09:56 AM
12/23/04 09:56 AM
When calculating downwind sailing, you say "as low as you can go." That means straight downwind. Is that what you mean?
Also is this the correct order of these three items? Well, I mean are the items in the right order but are the numbers on the wrong ones?
-2- is mostly impacted by good hull design and efficiency of sailarea
0 registered members (), 20,780 guests, and 1,475 spiders.
Most Online22,490
Yesterday at 08:14 AM
