| Traveler and heel #41437 12/17/04 04:05 PM 12/17/04 04:05 PM |
Joined: Aug 2003 Posts: 351 Santiago, Chile Andinista OP
Posts: 351 Santiago, Chile | A read from a cat site that the position of the mainsheet traveler effects the gite. Is that true? Physical explanation is not evident to me
| | | Re: Traveler and gite
[Re: Andinista]
#41441 12/17/04 05:33 PM 12/17/04 05:33 PM |
Posts: 12,310 South Carolina | Well, it moves the sail force in a more forward direction and depowers the sail depending on the angle of the wind. So yes, it does decrease the heeling angle. If it's very windy and you find yourself overpowered, easing the traveler will help make the boat more managable too.
Jake Kohl | | | Re: Traveler and gite
#41445 12/18/04 12:33 AM 12/18/04 12:33 AM |
Posts: 18 Richmond, Virginia | Yes, I think this is true, but I think more important is that when releasing the traveler, you are likely taking the main out of proper trim. This will decrease the overall power generated by the mainsail and therefore decrease the heel.
Gordon
[Re: gordon]
#41446 12/18/04 09:12 AM 12/18/04 09:12 AM |
Posts: 351 Santiago, Chile | What is the correct use of the traveler anyway, up to my understanding, its is to improve the trimming of the sail depending on wind direction, moving it downwind as the wind moves further aft. If the traveler is two short, the leech would make a bigger curve and the foot would go up a bit (at least on mine that is boomless), which in my opinion depowers the sail, not the opposite, it also would produce more heel. (I understand what jake says, but I was thinking of easing the traveler and at the same time pulling the mainsheet, so the sail angle would be the same) | | | Re: Traveler and gite
#41447 12/18/04 09:24 AM 12/18/04 09:24 AM |
Posts: 1,911 South Florida & the Keys | Boyz,
The way I understand it is this; always start with the traveler in the center, then start shifting gears. First apply downhaul to keep the boats attitude correct. If that is not enough, trapeze, if that is not enough, double trap. If at this point you are still having to dump armfuls of the mainsheet to keep control then you should begin to travel out. Travel out a few inches at a time until you can magage the heel by adjusting the main only a few inches and avoid having to repower after every gust. (?)
Eric Arbogast ARC 2101 Miami Yacht Club | | |
2,362
guests, and 286
