Traveler and heel #41437
12/17/04 04:05 PM
12/17/04 04:05 PM
Santiago, Chile
Andinista Offline OP
Santiago, Chile
A read from a cat site that the position of the mainsheet traveler effects the gite. Is that true? Physical explanation is not evident to me
Re: Traveler and gite [Re: Andinista] #41438
12/17/04 04:48 PM
12/17/04 04:48 PM
Richmond, Virginia
gordon Offline
gordon  Offline
Richmond, Virginia
huh?
Gordon
Re: Traveler and gite [Re: Andinista] #41439
12/17/04 04:53 PM
12/17/04 04:53 PM
Andinista: Could you explain what you mean by "gite" ?
Re: Traveler and gite [Re: Rolf_Nilsen] #41440
12/17/04 05:17 PM
12/17/04 05:17 PM
Santiago, Chile
Santiago, Chile
oops.. that was the french dictionnary.. excusez-moi
I was talking about HEEL !!
Re: Traveler and gite [Re: Andinista] #41441
12/17/04 05:33 PM
12/17/04 05:33 PM
Well, it moves the sail force in a more forward direction and depowers the sail depending on the angle of the wind. So yes, it does decrease the heeling angle. If it's very windy and you find yourself overpowered, easing the traveler will help make the boat more managable too.
Re: Traveler and gite [Re: Jake] #41442
12/17/04 06:31 PM
12/17/04 06:31 PM
I don't understand what you mean.
Re: Traveler and gite [Re: Mary] #41443
12/17/04 07:03 PM
12/17/04 07:03 PM
Santiago, Chile
Santiago, Chile
If I get your point, supposing that the traveler is pulled in excess, if you move it downwind and then you pull the mainsheet, to get the same sail angle as before, the sail will be better trimed for that direction, taking out part of the perpendicular (to the boat directio) component of the force.
Re: Traveler and gite [Re: Mary] #41444
12/17/04 07:41 PM
12/17/04 07:41 PM
Very crudely drawn...this is what I refer too. As the traveler is eased, the driving force from the sails points more forward which results in less heal. The force is directed more towards pulling the boat forward than trying to lean it over. However, this also means that the boat will probably not point quite as well because of the angle of the sail. It also gives an indication why there is so much more pressure on the bows while reaching.
Re: Traveler and gite [Re: Jake] #41445
12/18/04 12:33 AM
12/18/04 12:33 AM
Richmond, Virginia
gordon Offline
gordon  Offline
Richmond, Virginia
Yes, I think this is true, but I think more important is that when releasing the traveler, you are likely taking the main out of proper trim. This will decrease the overall power generated by the mainsail and therefore decrease the heel.
Gordon
Re: Traveler and gite [Re: gordon] #41446
12/18/04 09:12 AM
12/18/04 09:12 AM
Santiago, Chile
Santiago, Chile
What is the correct use of the traveler anyway, up to my understanding, its is to improve the trimming of the sail depending on wind direction, moving it downwind as the wind moves further aft. If the traveler is two short, the leech would make a bigger curve and the foot would go up a bit (at least on mine that is boomless), which in my opinion depowers the sail, not the opposite, it also would produce more heel.
(I understand what jake says, but I was thinking of easing the traveler and at the same time pulling the mainsheet, so the sail angle would be the same)
Re: Traveler and gite [Re: Jake] #41447
12/18/04 09:24 AM
12/18/04 09:24 AM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
Boyz,
The way I understand it is this; always start with the traveler in the center, then start shifting gears. First apply downhaul to keep the boats attitude correct. If that is not enough, trapeze, if that is not enough, double trap. If at this point you are still having to dump armfuls of the mainsheet to keep control then you should begin to travel out. Travel out a few inches at a time until you can magage the heel by adjusting the main only a few inches and avoid having to repower after every gust. (?)
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Traveler and gite [Re: arbo06] #41448
12/18/04 09:50 AM
12/18/04 09:50 AM
Santiago, Chile
Santiago, Chile
Basically you mean to ease the traveler to loose wind when you can´t handle it.
When off wind or on the reach, if the traveler is moved forward it helps to do the job of a boom-vang. Isn´t that a good use too?
0 registered members (), 16,525 guests, and 861 spiders.
Most Online22,490
Yesterday at 08:14 AM
