MOB procedures for a Cruising Catamaran???? #43930
02/05/05 02:53 PM
02/05/05 02:53 PM
RichardS Offline OP
RichardS  Offline OP
I am looking for information (references, articles, or experiences) on the best (most realistic short handed) procedures for Man Overboard in a (40ft – 50ft) cruising catamaran.
I recently moved from chartering monohulls in the Caribbean to chartering multihulls (wished I did it a lot earlier). I sail with my family (wife and 8 year old daughter), and sometimes with another non sailing family. On our next trip down I plan (at the behest of my wife) to do some practice runs (which I should have done on the first trip). In preparation for the trip I have been thinking about procedures that I would use (and have practiced) on a monohull. I have a few issues with, questions about those procedures.
The figure eight: It seems to me that the speed at which a cat moves would put you uncomfortably far from the MOB. And then (if I am thinking this through properly) jibbing twice without adjusting sail seems more difficult (or more dangerous) then it would be on a monohull.
That leaves the quick stop. The quick stop seems like the better choice however in a monohull you tack without adjusting sails to make your circle around the MOB, which would be very unlikely on a multihull. This would not be a problem if I am still on board. However, I keep on getting asked the “what if” question (which is usually followed by a question about insurance).
Any direction would be appreciated.
Richards
Re: MOB procedures for a Cruising Catamaran???? [Re: RichardS] #43931
02/05/05 04:43 PM
02/05/05 04:43 PM
RickWhite Offline
RickWhite  Offline
You might get the book that American Sailing Assn. has out on on multihulls.
Personally, I would ease the sails some and do a jibe right back to the MOB. Some of the bigger multis do not tack all that easy, so the jibe really does not take much in the way of sail handling.
You might even be able to leave the jib so you proceed in a heaved-to setting. Or just release it and let if flutter.
Rick
Rick White
www.onlinemarinestore.com
Re: MOB procedures for a Cruising Catamaran???? [Re: RickWhite] #43932
02/05/05 06:30 PM
02/05/05 06:30 PM
Rick neglected to mention that we have those American Sailing Association books, "Multihull Fundamentals," right here in our office, and you can order them directly through our on-line store. He also neglected to mention that the book was written by Rick White.
Re: MOB procedures for a Cruising Catamaran???? [Re: Mary] #43933
10/24/05 11:57 PM
10/24/05 11:57 PM
WA
Diane Offline
Diane  Offline
WA
I participated in MOB practice onboard an F-31R trimaran a couple months ago. Kirby, a member of our North West Multihull Association, volunteered to jump into chilly Puget Sound (Seattle) and let club members rescue him. It was good practice and I want to practice it again to become quicker.
Here's Kirby's point of view, as posted (with photos)in http://www.nwmultihull.org/newsletter/Sept05.pdf
"Man Over Board Practice is a Success, Kirby is Saved!!
By Kirby Jacobson
I’m in Puget Sound with a green camouflage free dive suit on, what a beautiful view from the water of the low afternoon sun through the sails and the dancing sun dots on the water. They have plenty of time to get me. I can stay all day in this suit with a big yellow inflated life vest on. But the only way I can swim anywhere is to float on my back. The chambers of the life vest prevent me from reaching forward at all. When I float on my back I can’t see the Life Sling on the water. Around they go. Hmm….the Life Sling isn’t getting much nearer. It appears that the it is content to follow the boat rather than circle inwards toward me. We are clearly finding out all kinds of things with this MOB practice.
Multihulls appear to require a little different handling during MOB. The first order of the day is to kill speed, and then begin to maneuver. We also have to be very sensitive about picking up speed when we come around to the swimmer.
They throw. Well, it is a bit of a scramble trying to swim anywhere but I figure out an approximate sidestroke and get over to the ring. With the Life Sling around me I am at the side of the boat.
Linda is trying to clip a halyard into the harness rings on my fancy life vest. This is pretty tough. Even in calm water it is hard to bend over to water level, dig under the inflated life vest and the Life Sling, and clip the rings. Lets crank it and get me out of here. Yikes, that hurts my lower back. When the force pulls at the level of the life vest D rings it is about 6 inches under my rib cage and
bends me over backwards as I get pulled out of the water. Yeow, we have got to work out something better than that.
Another run and jump into the water for the next round. By the way, this is a blast. One unheralded advantage of multihulls is that you can get a great run before you jump. I bet mono-hullers never thought of that!
So here we are, once more circling with the Life Sling. Well, one lesson learned is that these boats are a little fast for the “circle the sling to the center” plan. This time when I get the Life Sling it is traveling at about 5 knots. It is easy to hang on with one hand but the lifejacket and water pressure make it difficult to put the sling on. And I have to be careful not to let the angle of my body pull me under with the pressure generated by the speed. Now they reel me in and this time the halyard is hooked to the Life Sling. Now this works pretty good. And I flip around so I am facing outward and the same force pulling in toward the mast now sits me right down instead of arching my back.
So where to go from here? More practice that is for sure. We will be going out again. I can hardly wait until we do a true storm MOB practice. Or maybe a night drill. That is when you need it the most. I will make sure to wear bright clothes."
0 registered members (), 252 guests, and 521 spiders.
