| Re: What would you like to see in a 26 ft. trailer tri
[Re: lnh]
#43970 02/21/05 07:04 PM 02/21/05 07:04 PM |
Posts: 13 | We begin CAD drafting of my concept sketches tommorow. I will be able to make better predictions later on but am looking for a weight of about 3000 lbs. as built with no personal gear or stores on board. As always though less would be better. Remember though there are a bunch of light race boats already being built. I'm looking for something that will carry enough stuff to live on for a time (2 weeks or so). And where you can stand up to do the dishes. Most of the boats that I have sailed and worked on have been much heavier than their advertized weight. For the last two years when ever I have gotten a chance I have weighed the boats that I have been working on at a scale near us. Very informative. Those that I could not weigh I took careful measurments of load water line and worked out weight from advertized Displacement and PPI calcs. Thanks for taking the time to comment. Dave
[Re: DaveLaux]
#43983 05/01/05 09:30 AM 05/01/05 09:30 AM |
Posts: 17 | Hey Dave, i've been out of the loop for awhile. I would like to see the interior set up on the boat, very curious as to how you plan to get the head room in the cabin area. drop me an email at sailboat33@hrtc.net Go getem Larry | | | Re: What would you like to see in a 26 ft. trailer
[Re: lnh]
#43985 05/23/05 06:53 AM 05/23/05 06:53 AM |
Posts: 13 | The engine that I am using weighs 216 lbs plus about 20 for shaft and prop. Its about 5 feet from the CG of the boat for 1200 ft lbs moment. A 9.9 Yamaha with bracket is about 140 lbs and would be 12 ft from the CG for 1680 ft.lbs. This means that if the boat was in the water without the engine and you set the engine into it it would trim 1.5 times as much by the stern from the outboard than from the diesel, though it would sink a small amount more overall with the diesel(a few hundredths of an inch) For equivelent range under power the Yamaha would need ~1.5 times as much fuel so the weights are even closer than I've stated.
Dave
673
guests, and 186
