sticking daggerboard on H20 #4420
12/01/01 01:14 PM
12/01/01 01:14 PM
Paul Offline OP
Paul  Offline OP
One of my daggerboards is difficult to lower and raise on my 1998 H20. The top of the daggerboard trunk has a velcro-like material that causes friction. Do I have to replace this, or is there an easier solution?
<br>
<br>Paul
<br>H20 #714
<br>
<br>
Re: sticking daggerboard on H20 [Re: Paul] #4421
12/01/01 10:30 PM
12/01/01 10:30 PM
South Louisiana, USA
Clayton Offline
Clayton  Offline
Paul, Sight down the length of the daggerboard. It may have a bow in it. I've seen it happen before. Try switching the boards in opposite slots. If the problem follows that is probably it.
<br>
<br>Clayton
<br><br><br>
Re: sticking daggerboard on H20 [Re: Clayton] #4422
12/04/01 02:12 PM
12/04/01 02:12 PM
Florida
rquesada Offline
rquesada  Offline
Florida
I have a 1993 H-20 and had the same problem with the daggerboards; it was a real workout to pull or push them; the solution is very simple; once a month or so, spray a thing coat of silicone on each side of the boards and they will work "like a violin"
<br>
<br>Do not touch or remove the piece of carpet you have in the trunk of the boards or you will regret it and the boards will be really loose and the water will push them up when you are sailing.
<br>
<br>Good luck
<br>
<br>Rafael
<br>
<br>H-20 / CABB
<br>Miami <br><br>
4493- (16 downloads)
Re: sticking daggerboard on H20 [Re: rquesada] #4423
12/04/01 02:41 PM
12/04/01 02:41 PM
Paul Offline OP
Paul  Offline OP
Thanks a lot for the tip! What type of silicone do you buy? Is if for waterproofing shoes?
<br>
<br>Paul<br><br>
4496- (17 downloads)
0 registered members (), 680 guests, and 38 spiders.
