Additive Welding to Rudder Castings... #44336
02/14/05 01:56 AM
02/14/05 01:56 AM
Minnesota
Jeff Peterson Offline OP
Minnesota
My rudder castings are wearing way down, where the tiller castings rub against it. Has anyone tried adding wire feed aluminum welding to this spot, to build it back up? (I know a good welder who is cheap, cheap, cheap!)
Jeff Peterson
H-16 Sail #23721
Big Marine Lake, MN
Re: Additive Welding to Rudder Castings... [Re: Jeff Peterson] #44337
02/17/05 10:18 PM
02/17/05 10:18 PM
arlington tx.
dunebug Offline
dunebug  Offline
arlington tx.
Hey same thing I got mine welded today he used a tig welder I filed the outside flat first and plan to do a rubbing of my 16 casting to get the original contour back on the lower I will get the contour back on the upper but plan to leave it wide instead of tapering like original to promote longer life if increased friction is a problem I will try reducing spring tension. Inclosed si a pic.
Re: Additive Welding to Rudder Castings... [Re: dunebug] #44338
02/18/05 03:28 PM
02/18/05 03:28 PM
Minnesota
Minnesota
WOW!
It looks like you are well on your way to completing the project. I wasn't probably going to get to this until March or April. (I got snow and cold here, so there is no rush.) Do you live somewhere warm,to be able to try out your repairs soon? I imagine the additive welding is the easy part. The shaping of the groove is where the real challenge is. Who knows, maybe the "Hobie design" shape can actually be improved, but it is probably best to stick to the original shape. --Keep us informed!!!
Jeff Peterson
H-16 Sail #23721
Big Marine Lake, MN
0 registered members (), 370 guests, and 37 spiders.
