| Nacra F18, Sol Cat 18, daggerboards #44768 02/20/05 05:57 PM 02/20/05 05:57 PM | Anonymous
| Anonymous
Unregistered | Hi there, while still trying to shape daggerboards, I "heard" that I could use the Nacra F18 daggerboards on my Sol Cat 18. As I don't have any of those available near me, I would appreciate any expertise on this. I made a "sample" for my Sol Cat out of foam, that at least fits into the pontoon slots. Its a little less then 12.1/2 inches at the top, a little less then 11 1/2 on the bottom, 39 inches long (I looked at some pictures to get that length. The daggerboard at many cats seem to "stick out" on the bottom the same length as the rudders going down.) Its a little less than 3/4 inch at the thickest part, only 1/4 at the small end (back). The sample fits in "snuggly", so could obviuosly be a little smaller in size. How's that in comparison the Nacra F18 ? I had the cat in the water today for the 1. time, but without daggerboards I was just drifting to leeward  Thanks and have a great holiday. Michael | | | Re: Nacra F18, Sol Cat 18, daggerboards
[Re: carlbohannon]
#44770 02/21/05 10:57 PM 02/21/05 10:57 PM | Anonymous
| Anonymous
Unregistered | Thanks carlbohannon. that was quite a journey thru the RC airplane world. Seems that more links are dead there than in cat sailing ? Now I know how to build a foam cutter in 4 days from HomeDepot parts, sanding, vac bagging with a 40$ pump, getting stringer in with an iron etc.  But I rather prefer to use a somekind smaller daggerboard if I can get one ready made, before I start that adventure. At this moment, I just try to plane and sand down some plywood and put some epoxy around it. But anyway, thanks for the insight into the foam wing world. May come in handy later. What was that part of you making those things ? Michael | | | Re: Nacra F18, Sol Cat 18, daggerboards
[Re: carlbohannon]
#44772 02/22/05 11:10 AM 02/22/05 11:10 AM |
Posts: 851 US Western Continental Shelf | Carl,
As Michael has said, the RC world seems to have more dead links than even catsailing. Could you offer some suggestions as to where to find the prefabricated foam foil sections?
Thanks,
GARY
Santa Monica Bay Mystere 6.0 "Whisk" <--- R.I.P. | | | Re: Another way to fabricate
[Re: Rolf_Nilsen]
#44776 02/22/05 07:48 PM 02/22/05 07:48 PM |
Posts: 1,253 Columbia South Carolina, USA | Sorry Rolf, I sold the G-Cat, never glassed the board, and never got to the foam board. I did get uniformity(close) by using calipers, but that was still only close. Pretty sad huh? Had I laid up the board with glass, it may have been totally different. But it worked well to get a decent shape. David
| | | Re: Daggerboard fabrication
[Re: pitchpole]
#44777 02/23/05 12:13 AM 02/23/05 12:13 AM | Anonymous
| Anonymous
Unregistered | Very good pictures pitchpole, thanks for the link And thanks Dave for the tip with the router, haven't thought about that.
One question do I have still:
If you use foam and put a layer of fiberglass on that, isn't that too weak ? Aren't you supposed to stand on those daggerboards with all your weight if you want to right the cat after capsizing ???
Michael | | | Re: Another way to fabricate
[Re: dave mosley]
#44779 02/23/05 04:49 AM 02/23/05 04:49 AM |
Posts: 4,451 West coast of Norway | Oh well, Dave, I bet you had fun building the foil anyway. If the surface was not 100% after glassing.. thats what bog and elbow grease is for. If I am to build another set of rudders, I want to try foam/glass. But I am not competent to calculate the glass layup. "Guesstimating" the layup will be costly in the long run, as some sets are bound to break.. It's tempting to do a female 'pirate mould' off some fabricated rudders I have, but that avenue is also full of problems (getting the mould flange correct, internal flange for joining, layup, legal/moral issues etc.). I guess most production foils have their foam CNC cut like Phil's foils does, or uses CNC'ed female forms. Michael, you are correct in assuming that just one layer of glass is not enough. How much glass, weight of glass and orientation are issues you need to calculate before building. You also have to calculate how thick the glass will become after laminating, so you can get an exact fit. That is one of the reasons female moulds are so much easier to work with in a production environment. You probably will get a better result with spruce strip planking and a thin layer of glass for abrasion resistance, wood is so much nicer to work with as compared to fiberglass and epoxy (probably cheaper also). Using hot wire technique to make the foam core is pretty much standard today for homebuilders. Perhaps some of the really experienced homebuilders (or pro's) here will share some experience on layups for foils. I think what Carl says about buying what you can is good advice if you want to get on the water fast, with a good result. The seller of the core can probably spec out the glass layout and weight for you to achieve the 1/8" skin Carl mentions. I would forget plywood without serious glass reinforcement. We have personally broken two centerboards of plywood without glass reinforcement.. Strip planking is much stronger than plywood, as half the wood fibers in plywood lies in the wrong direction and does not add to strength/stiffness. | | | Re: Another way to fabricate
[Re: Rolf_Nilsen]
#44780 02/23/05 04:01 PM 02/23/05 04:01 PM | Anonymous
| Anonymous
Unregistered | Nils, you guys keep me working. Looking for "strip planking" (of course I had no idea what it is) I now found letter to the journal "Watercraft", saying that strip planking is "Time consuming and hard to repair"  . Anyway, I think it's beyond my capabilities and time. Thanks for the insight concerning plywood. Slowly but steadily, I start to think about throwing the cat away and buying a sailboat with everything on it  before I spend more nights on the PC and days with planer and sander | | | Re: Another way to fabricate
[Re: jollyrodgers]
#44783 02/25/05 09:41 AM 02/25/05 09:41 AM |
Posts: 778 Houston | Hello, styro core foils for a cat are a pipedream in my opinion. Most foils on production cats(NACRA's and Hobies) are foam core. Marstrom carbon foils are foam core (Tornado's are hollow core), Mine are are foam core. The techniques used to determine the shape and size of the core is very similiar to the techniques used to calculate ribs for aircraft wings, it dates to 1910-1920 You do have to taper the trailing edge | | | Re: Another way to fabricate
[Re: carlbohannon]
#44785 02/28/05 05:33 PM 02/28/05 05:33 PM |
Posts: 307 maui | Hello, styro core foils for a cat are a pipedream in my opinion. Most foils on production cats(NACRA's and Hobies) are foam core. Marstrom carbon foils are foam core (Tornado's are hollow core), Mine are are foam core. The techniques used to determine the shape and size of the core is very similiar to the techniques used to calculate ribs for aircraft wings, it dates to 1910-1920 You do have to taper the trailing edge well, i wrote styro core not foam core. they were talking about hotwiring stro like they do with remote control glider wings for a solcat daggerboard. regular styro soaks water. extruded styro is very hard to bond to with any longevity. Most all of the strength would be in the skin so you would have to calculate that thickness and subtract that from the shape of the core. you would end up with a pretty thin core which would leave alot of leaway for the shape to change as the blade got laminated. the foam that is inside of molded blades is pretty strong and doesn't soak up water. Also it can be difficult to obtian, and use effectively. Maybe that's why some are hollow. hollow blades have to be molded because you wouldn't be able to laminate a foil made of air like you could with wood. if you are making you own foil in your garage, shaping it in wood as perfect as possible and putting a very thin coating to seal out the water is the way to go. | | | Re: Another way to fabricate
[Re: jollyrodgers]
#44786 03/01/05 05:24 AM 03/01/05 05:24 AM |
Posts: 4,451 West coast of Norway | While we are talking about hollow foils buildt in moulds. How do they go about joining the two shells? I imagine they add a a stringer at 30% to take large loads, and the aft part can be routed flat while it is in the mould. But what do they do to make a bonding surface able to take the load at the forward part (front glue line/seam)? A word about styrofoam. I have seen it used as partial bulkheads and distance material in different boats. Ref: http://homepages.paradise.net.nz/garyd/quikama.htmlhttp://thebeachcats.com/modules.php?op=modload&name=News&file=article&sid=49According to the builder of the A class referenced above, the polystyrene foam bulkheads was quite OK. I tought styrofoam was a closed cell structure, that did not draw moisture? Michael: Dont worry about the stripping process, that is easy. Just glue spruce staves together parallel before you begin to shape it. Look at Dave Mosley's page again, the whole process is documented very nicely there. Just get to it, and get on the water. Buying a new cat just becouse you miss the centerboards sounds expensive. Dont listen to the us technophiles, wood is a perfectly good material, and very nice to work with. | | | Re: Another way to fabricate
[Re: Rolf_Nilsen]
#44787 03/01/05 09:46 AM 03/01/05 09:46 AM |
Posts: 545 Brighton, UK | There are companies around that have computer controlled hot wire foam cutters, they are relativley cheap to use, and can give some fantastic results. If you are clever you can get some quite complicated shapes out of them. We used one to build a hull plug. See picture below. All the best Gareth www.fourhulls.com | | |
1,306
guests, and 22
