N6.0 battens ??? #44810
02/21/05 09:52 PM
02/21/05 09:52 PM
Chicago, IL
Krisu13 Offline OP
Krisu13  Offline OP
Chicago, IL
Currently I’m looking for the main sail battens for my N6.0.
I found this company www.rbsbattens.com they make epoxy and carbon tapered battens.
The manufactures told me that their battens were used for Nacra 450, 500, 570.
Any suggestions whether they are good battens for N6.0
Thanks
Kris
I20
Re: N6.0 battens ??? [Re: Krisu13] #44811
02/21/05 11:06 PM
02/21/05 11:06 PM
Ohio
Jamie Diamond Offline
Ohio
Talk to Randy Smythe. He spec'd out some after market battens for my 6.0 a few years back. They significantly improved the performance of the mainsail. They middle 3 were somewhat similar to the stock battens. The top 3 were somewhat more flexible. The bottom 3, particularly the bottom 1, were much stiffer.
Or send me an email if you still have questions.
jamie.diamond(at)sailocra.com
Re: N6.0 battens ??? [Re: Krisu13] #44812
02/21/05 11:20 PM
02/21/05 11:20 PM
Charleston, SC
NCSUtrey Offline
NCSUtrey  Offline
Charleston, SC
I have Jamie Diamond's battens for his 6.0 right here in my room.......
Trey
I-20 314
Trey
Re: N6.0 battens ??? [Re: Krisu13] #44813
02/22/05 07:53 AM
02/22/05 07:53 AM
I would recommend that you consider going to your nearest performance cat dealer....I can't remember the brand name on the battens, but you could run into some one-design issues if you're concerned about it (not sure if that is in the rules or not).
With all reality, however, I've been really impressed with the latest battens that Performance catamarans are using. I had an old, 1997 set in my 6.0 sails and ordered new battens when I replaced the sails (I think about $330 for the battens?) and they're tough and well made. The F18 sails use the same brand.
Re: N6.0 battens ??? [Re: Jake] #44814
02/24/05 08:31 AM
02/24/05 08:31 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Our local sail maker spec'd RBS for our new main and jib. He has sailed with us three times to tune them, customer service! The first set were to stiff in the front third or so of the batten. The set we have now look great. We have the epoxy model for all of them except the diagonal batten for the square top which is carbon. If you would like to talk with him, PM me and I'll give you his number.
Chris Allen
Nacra 20 Gertie
www.wrcra.org
0 registered members (), 2,643 guests, and 287 spiders.
