| Re: Nacra Jib Sheet Set Up
[Re: Zailing]
#46266 03/22/05 12:41 PM 03/22/05 12:41 PM |
Posts: 12,310 South Carolina | Sounds correct. The solution to this problem is to mount a bunji chord in one of two possible configurations.
Configuration A) mount a small eyestrap (if not already) to the front of the mast approximately 12 to 18" up from the base. Tie a 1/8" to 1/4" bunji from this eyestrap forward to the meeting point of the bridle wires and the forestay. It should be taught enough to form a straight line but you want to leave it plenty of room to spring. Your jib sheets should go overtop of this bunji with one on each side. During sailing, the bunji will not interfere with the sail and during tacking, the sheets and sail must go up over the bunji which prevents them from hanging out around the mast base and rotator bar.
Option B you can take a bunji mounted to the front of the front beam at one hull, up through the bottom of the diamond wires, around the front of the mast, back through the other side of the diamond wires, and finishing at the opposite outboard end of the front beam. This forms a triangle and does the same thing by keeping the sheets elevated during tacking and away from the mast base.
Jake Kohl | | | Re: Nacra Jib Sheet Set Up
#46267 03/22/05 12:52 PM 03/22/05 12:52 PM |
Posts: 829 Charleston, SC | Yeah, what Jake said works great. I had the same problem on my Hobie 18sx a few years back. The bungee solution is the best way to go. Trey N20 314 Layline Rigging www.velocitysailing.com
Trey
[Re: Zailing]
#46269 03/23/05 05:27 PM 03/23/05 05:27 PM |
Posts: 81 Chicago, IL | Hmm--that happens to us all the time with our Nacra 5.8na. Is there an illustration somewhere on how to do this correctly?
CatWoman
[Re: CatWoman]
#46270 03/24/05 08:03 AM 03/24/05 08:03 AM |
Posts: 371 Michigan, USA | CatWoman, The CRAM N5.8NA fleet all seemed to use Jake's "Plan B". By attaching the end of the bungie at the hull, going through the diamond wires (around the front of the mast) and to the other hull forms a triangle above the main beam with the peak at the mast. CRAM has lots of sailors that own or have owned the N5.8NA. Bring yours to Benton Harbor July 23 - 24 and ask for help. There will be lots of people who can help. If you can't wait 'til July, CRAM's first regatta is at Higgins Lake May 21 - 22. For sure, don't miss the Cat Fight August 19, 20 and 21 at Muskegon State Park. Racing on Friday, Saturday and Sunday, legendary parties, and near 100 boats! If you only did one regatta a year, make it the Cat Fight! BTW, Mark Biggers of the Cathouse (cathouse1 at speednetllc dot com) attends and races at CRAM's regattas, has great advice, and usually the parts you want. He is probably the reason there are so many Nacras in CRAM. It has been nice having the dealer at regattas. When I break something (way too often  ), he can usually get me back on the water quickly and the weekend of racing is not lost.
Les Gallagher
#46274 03/29/05 11:13 AM 03/29/05 11:13 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | On our Hobie 18 I always used Jake's Plan B, but I didn't attach the bungie to the beam at each side -- I attached it to the dolphin striker on each side with a clove hitch, about a third or quarter of the way in from the hull. That seemed to be the best positioning for the bungies to keep the jib sheets from catching on the mast rotation bar. When the bungies were all the way to the hulls, that left the triangle too wide open, and the jib sheets could still sneak in there.
The reason for using a bungie instead of a cord is because the bungie gives -- if your jib clew blocks or pigtail or bowlines or whatever you use at the clew gets hung up on a cord instead of a bungie, it may stay hung up.
And even in the unlikely case where it might stay hung up on the bungie, it is very lightweight bungie cord, so it will stretch enough so you can still sheet in your jib on the new tack, and the process of sheeting will end up making the bungie let go. | | |
2,424
guests, and 182
