Page 1 of 3 1 2 3
Hobie 16 / 18 vs Nacra 5.2 #46331
03/24/05 01:46 PM
03/24/05 01:46 PM
Hermosa Beach, CA
gregspittle Offline OP
Hermosa Beach, CA
I'm about to buy my 1st cat. Thinking of either a Hobie or a Nacra 5.2
Which would be the better option?
Re: Hobie 16 / 18 vs Nacra 5.2 [Re: gregspittle] #46332
03/24/05 03:51 PM
03/24/05 03:51 PM
Depends on what you're into... if you want to race against others with boats like yours, find out what boats are around you. 99% going to be the Hobies, and more likely to be the 16 over the 18. If this is a boat just for fun or you don't mind racing on a handicap system, go for the best deal. All three boats you named have devoted followings, some more nostalgic than others.
Let us know what you get and how it goes! Good hunting!
Re: Hobie 16 / 18 vs Nacra 5.2 [Re: gregspittle] #46333
03/28/05 03:13 PM
03/28/05 03:13 PM
Western New York
wyatt Offline
wyatt  Offline
Western New York
I agree with John:
I have a Hobie 18 magnum and it's a terrific boat to be sailing because it's stable and I can easily single handle it. But, they're not making the H-18 anymore because of the transition to the Hobie Tiger, which seems to be for experts only if you intend to take advantage of all the adjustments and the spinnaker.
Racing the H-16 is a sure way to really get a lot of experience fast because you'll be able to race one-design and really find out what works and what doesn't. The Nacra 5.2 is a great boat if you don't intend to race. Kind of hard to get back on the trailer single handed, though.
Wyatt
Re: Hobie 16 / 18 vs Nacra 5.2 [Re: wyatt] #46334
03/28/05 07:29 PM
03/28/05 07:29 PM
BobG Offline
BobG  Offline
If you want to show the Hobies where the marks are than take the 5.2....This boat will be absorbed into the 17 formula eventually...........if not already..........
Re: Hobie 16 / 18 vs Nacra 5.2 [Re: gregspittle] #46335
03/29/05 08:14 AM
03/29/05 08:14 AM
Rockledge Cay, FL
Fearless_Rider Offline
Rockledge Cay, FL
Greg,
I have owned all 3 boats that you are considering, H16, TheMightyHobie18 and currently the N5.2. There are many considerations when choosing the right boat for you, such as where you are sailing (water depth). If you are going to be in a shallow area, go for the H16 due to no dagger boards. I would also shop around for a very good condition boat. Its worth the extra money to buy a nice used boat for $2K rather than buying a "fixer upper" for half that price. You will spend more time fiddleing around with problems when you could be on the water. I think you will find most sailors started out on a H16. The TheMightyHobie18 is a good boat, but very heavy and I found difficult to move around by myself. A couple years ago I bought a N5.2 from Jake Kohl and its way awesome! I would highly recommend this boat over the H16 if you have decent water to sail in so that you dont have to worry about hitting the dagger boards on a sandbar. I consistantly sail this boat solo, and have no problem moving it around. Replacement parts are plentiful too. Ive also added an I-17 spinnaker set up for the thrills.... but thats a different story!
BTW, my BBQ Rocks!
Re: Hobie 16 / 18 vs Nacra 5.2 [Re: Fearless_Rider] #46336
03/29/05 03:59 PM
03/29/05 03:59 PM
Hermosa Beach, CA
Hermosa Beach, CA
Many thanks to you all for your advice. I've bought a Nacra 5.2 & intend to get out on it this weekend........
I'm sure I'll have more questions in the near future!!
Thanks again.
Re: Hobie 16 / 18 vs Nacra 5.2 [Re: gregspittle] #46337
03/30/05 09:25 AM
03/30/05 09:25 AM
Rockledge Cay, FL
Rockledge Cay, FL
Greg, I'm sure you'll love the N5.2 Let me know if you ever need the steps to raise and lower your 5.2 mast single handed... It's fairly easy and safe. I have to do it quite often to sail by myself too...
BTW, my BBQ Rocks!
Re: Hobie 16 / 18 vs Nacra 5.2 [Re: Fearless_Rider] #46338
03/30/05 03:56 PM
03/30/05 03:56 PM
Chicago, IL
CatWoman Offline
CatWoman  Offline
Chicago, IL
I also know all three boats and would in a heartbeat go for a nice Nacra 5.2 in a heartbeat.That is, if you don't want to racein a Hobie fleet.
Great to single-hand and less chance to pitchpole that a H16 (I think this is my hang-up of which I'm deadly afraid, having gotten "killed" a few times in pitchpoling H16s and H18s).
Maintenance is also less on a Nacra 16, especially the simple rudder system. I think it's just more stable--also less chance of breakage. Older H16s have broken at the stanchions (or is it spelled "stantions"?).
CatWoman
Re: Hobie 16 / 18 vs Nacra 5.2 [Re: CatWoman] #46339
03/30/05 05:18 PM
03/30/05 05:18 PM
Santiago, Chile
Andinista Offline
Andinista  Offline
Santiago, Chile
Nice to hear that comment about pitchpoling. What about the Nacra 5.0 (which I have)? I thought it was very vulnerable to pitchpoling, because I see the tip almost sinking quite often, but I havn´t had the chance to compare with other cats.
Re: Hobie 16 / 18 vs Nacra 5.2 [Re: Andinista] #46340
03/30/05 05:44 PM
03/30/05 05:44 PM
Chicago, IL
CatWoman Offline
CatWoman  Offline
Chicago, IL
Actually, I did not phrase this right: the H16 and H14 are more prone to pitchpoling, the TheMightyHobie18 much less so, although we did on a couple of occasions pitchpole the H18sx on really windy days, with 2 people on the wire and the skipper on the wing. Gusty winds of up to 35mph--and the skipper's momentary inattention did the trick. It is NO FUN to fly into the rigging of a H18sx!!
The Nacra 5.2 has slightly longer and straighter hulls than the H16.
CatWoman
Re: Hobie 16 / 18 vs Nacra 5.2 [Re: CatWoman] #46341
03/30/05 06:12 PM
03/30/05 06:12 PM
The resistance to pitchpoling also has to do with rounded foredecks. They can go under the water at a slight angle and still pop back up. On a boat with a flat foredeck, it acts like a plow once it submerges causing the front of the boat to decelerate (while the back stays at the same speed!) and pitch downward even more. That's not to say that you can't pitchpole a boat like the 5.2 but it is a little more forgiving.
Re: Hobie 16 / 18 vs Nacra 5.2 [Re: Jake] #46342
03/30/05 06:34 PM
03/30/05 06:34 PM
Santiago, Chile
Andinista Offline
Andinista  Offline
Santiago, Chile
I've always managed to stay out of pitchpoling, but many times I had the leeward hull sinking up to the front crossbar. From what Jake says, I understand that on Hobbies the point of no return would come before. But the possibility to get the frontdeck underwater might be less on the hobbie than on the Nacra? The shape of the hulls give that impression
Re: Hobie 16 / 18 vs Nacra 5.2 [Re: CatWoman] #46343
03/30/05 07:27 PM
03/30/05 07:27 PM
Branford, CT
rhodysail Offline
rhodysail  Offline
Branford, CT
Gavin Colby: “The Hobie 16 doesn’t forward capsize [aka pitchpole] any more than a Formula 18.” Gavin Colby Interview Y&Y
Re: Hobie 16 / 18 vs Nacra 5.2 [Re: rhodysail] #46344
03/30/05 07:49 PM
03/30/05 07:49 PM
Don't misinterpret my intentions because I truely believe that the Hobie 16 is a terrific boat for beginners to serious racers. I also think it may be better suited to someone entering the sport than the Nacra 5.2 because there's a much broader support base...Pitchpolling really shouldn't be that big of a consideration. Then again, I did start sailing on a Nacra 5.2.
Although I'll admit to not having sailed a Hobie 16 since I've been experienced enough to make a comparison I CAN tell you that the Tiger F18, which has a flatter foredeck, is a lot less forgiving with the bow submerged than the Nacra F18 with it's more rounded foredeck. Galvin certainly has more qualification than me though ...but he does sail a Tiger.
We have done the following submarine act on multiple occasions on the Nacra ... and survived, pointy side up, quite easily as we did just after this photo was taken. Will a H16 come back from this?
P.S...I'm under that white water somewhere.
Re: Hobie 16 / 18 vs Nacra 5.2 [Re: Jake] #46345
03/30/05 09:03 PM
03/30/05 09:03 PM
Branford, CT
rhodysail Offline
rhodysail  Offline
Branford, CT
I’ve survived having the forward beam underwater in my 16 more times than I would care to admit. The fact is you need to watch out for the pitchpole thing with all catamarans. Why? Because they go that fast and they generally do not create dynamic lift. If you’re afraid of a pitchpole get a keel boat. Then again why not stick a mast in the sidewalk.
Re: Hobie 16 / 18 vs Nacra 5.2 [Re: rhodysail] #46346
03/30/05 10:03 PM
03/30/05 10:03 PM
Good advice!
Re: Hobie 16 / 18 vs Nacra 5.2 [Re: rhodysail] #46347
04/01/05 07:29 AM
04/01/05 07:29 AM
Panama City, Florida
Redtwin Offline
Redtwin  Offline
I am about to buy a Nacra 5.2 and I am glad to hear all you have to say about it. I singlehand alot and this was a concern as to if my 150# rump could soloright a Nacra. I have sailed on a Hobie16 quite a bit this last year while trying to decide which boat to buy. I really didn't want the H16 because with two adults (<350) it would really want to pitchpole bad. We would usually end up literally sitting on each other at the back beam and dump air. I have heard that the Nacras aren't so prone. In defense of H16s, these boats weren't exactly tuned to their potential.
I have a 5 year old son that loves to go out with me. How well do these boats handle kids? He is pretty helpful. He trims the jib and can probably work the boards for me. I've never sailed a cat with boards before. I'm looking forward to doing a normal tack. I learned to sail on monohulls and I always hated how slow cats tacked. Again, this was probably due to tuning, but we basically had to tack with the sails, the H16 would go into irons if we just tried to pull through like a centerboard boat.
Rob V. Nacra 5.2 Panama City
Re: Hobie 16 / 18 vs Nacra 5.2 [Re: Redtwin] #46348
04/01/05 08:25 AM
04/01/05 08:25 AM
Rockledge Cay, FL
Rockledge Cay, FL
I think you'll find that the N5.2 is a great boat for you and your son! It won't be any more difficult than the H16 for both of you to sail, and should be a lot easier to change tacks. Of course it helps to have a good set of main sheet blocks to allow the line to run free during the maneauvers. Check out the main sheet systems for sail on this web site (Catamaran Sailor) in the on line store. I'm using the 8 to 1 carbo blocks with 5/16" diameter main sheet. Makes for very smooth tacks! For more accurate tips, ask the master himself, Rick White....
BTW, my BBQ Rocks!
Re: Hobie 16 / 18 vs Nacra 5.2 [Re: Redtwin] #46349
04/01/05 08:51 AM
04/01/05 08:51 AM
There are several posts on here about performing a proper roll tack (you may want to try a search). While a boat with boards is a little easier to tack, a properly performed tack on a Hobie 16 should still not involve backwinding anything.
Re: Hobie 16 / 18 vs Nacra 5.2 [Re: gregspittle] #46350
04/01/05 10:24 AM
04/01/05 10:24 AM
Neb
flounder Offline
flounder  Offline
Neb
***New to the sport: Hobie 16
***Have sailed a few years and have lots of friends that want to ride: Hobie 18mag
***Want a fast single-handed boat: Nacra 5.2
***Want to class race: Hobie 16
***Want to cruise: Hobie 18mag
I have had all three of these boats. The Hobie 18mag is a war-horse. Load it up and head out into the big wind and you will have an excellent time! The Hobie 16 is a simple, old boat. If you like to race and keep things simple, Hobie 16 is the way to go. The Nacra 5.2 is like a knife. Same level of complexity as a TheMightyHobie18, just 100lb lighter. Excellent boat for single-handing. Aftermarket sails can really improve performace. Just not that much deck space for two people.
Pitchpoling.... The H16 is easily the king of pitching. You have to be careful on any boat though. I haven't pitch poled hard enough to dump the TheMightyHobie18 or N5.2. I don't think it is important enough to worry about in the your buying process.
Page 1 of 3 1 2 3
0 registered members (), 21,871 guests, and 1,775 spiders.
17 minutes ago
