Do you cleat ? #48905
05/09/05 05:11 AM
05/09/05 05:11 AM
scooby_simon Offline OP
Just been watching a few cat sailing video's that are going around on the web and it strikes me that so many people are cleating the main !
The only times I cleat the main sail is if I am sailing down wind with the kite up or when it is fairly light and I'm moving around doing something else - mast rotation, plates etc. I always un-cleat after this as I feel that it gives you that vital 1/2 second. When it is windy, I never cleat the main upwind.
Do you cleat your's much ?
Re: Do you cleat ? [Re: scooby_simon] #48906
05/09/05 07:30 AM
05/09/05 07:30 AM
Northfield,NH USA
bullswan Offline
bullswan  Offline
Northfield,NH USA
NEVER. Except in those rare instances, like you, when I have something else to do. I have been having a hell of a time stopping my son from cleating the jib too. I think you loose that 1/2 second that is sometimes vital to going over. He doesn't see it that way. I was showing my wife some of those videos and she commented, "Why are they always flippin' the sheet?"
Good thread question Scooby.
Re: Do you cleat ? [Re: bullswan] #48907
05/09/05 07:47 AM
05/09/05 07:47 AM
St Croix Virgin Islands
vicatman Offline
vicatman  Offline
I do after comming in off the trap..or downwind...thats about it...the wind here gets really puffy at times...and that 1/2 sec can make a big difference
Re: Do you cleat ? [Re: scooby_simon] #48908
05/09/05 08:18 AM
05/09/05 08:18 AM
Neb
flounder Offline
flounder  Offline
Neb
I cleat all the time. Just watch the wind...
Using cleats is part of single-handing when you fly more than one sail.
Re: Do you cleat ? [Re: vicatman] #48909
05/09/05 08:22 AM
05/09/05 08:22 AM
South Florida
SOMA Offline
SOMA  Offline
South Florida
Interesting, You don't cleat the main OR the jib?? I assume you sail with crew otherwise you must be steering with your toes.
Fred F (ex Hobie 18)
Re: Do you cleat ? [Re: SOMA] #48910
05/09/05 08:25 AM
05/09/05 08:25 AM
Which is why I said "except when the kite is up down wind"
Sail single handed, Don't have a Jib.
Re: Do you cleat ? [Re: scooby_simon] #48911
05/09/05 09:14 AM
05/09/05 09:14 AM
Single-hand on the 4.3, so in light air, I cleat everything (jib and main), get way forward and focus on steering. In moderate air, I'll cleat the jib and hold the main. In big air, I cleat jib and main, keeping the mainsheet in hand with no slack, and pinch like the heavy-air wuss that I am. I need more and better practice skippering in 15 knots and up - my results show it, too. In one regatta, I went from seconds and thirds in light to moderate, to DFL when the wind picked up - proof that cleating and pinching is slow.
Re: Do you cleat ? [Re: John Williams] #48912
05/09/05 09:38 AM
05/09/05 09:38 AM
Palm Harbor, FL, USA
L
Lance Offline
Lance  Offline
L
In moderate to heavy air I don't cleat but always wrap the mainsheet around my hand 3-4 times. If I have to let the sheet out quickly I just straighten out my hand and let the sheet out 1 loop at a time or several loops if need be.
Lance
Taipan 5.7 USA 182
Palm Harbor, FL
Re: Do you cleat ? [Re: scooby_simon] #48913
05/09/05 09:47 AM
05/09/05 09:47 AM
Neb
flounder Offline
flounder  Offline
Neb
I hardly ever worry about the jib. I adjust the slot more than the jib sheet.
??? I don't think it really matters whether someone uses a cleat or not.
Re: Do you cleat ? [Re: flounder] #48914
05/09/05 10:20 AM
05/09/05 10:20 AM
Valencia - Spain
aestela Offline
aestela  Offline
Valencia - Spain
Which boat are we talking about?
I for my self, on a HC16, can't bear more than 10 minutes uncleated when upwind two-trapped. It's much too physical demanding.
Re: Do you cleat ? [Re: flounder] #48915
05/09/05 10:21 AM
05/09/05 10:21 AM
I cleat the mainsheet, the majority of the time.
Now how about self tacking jibs? I cleat that as well. I really do not see how a self tacking jib can make a huge diference if you are going under or not.
Re: Do you cleat ? [Re: Robi] #48916
05/09/05 10:50 AM
05/09/05 10:50 AM
Self tacking jib - always cleated, obviously.
Main - never cleated above about 5mph of wind. I've even adjusted the cleat position up out of the way so that it can't be cleated accidentally. It's still possible to cleat it if I have to (say, to sort out a rudder or adjust something) but I would have to move in off the hull to do it.
Re: Do you cleat ? [Re: Jalani] #48917
05/09/05 12:48 PM
05/09/05 12:48 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
Not cleating the main on my Tornado has saved me from capsize countless times. It is the single reason I have never had a capsize in 20+ years of sailing/racing. Now that I run a spinny, I do cleat the main off-wind, and hold the traveller line at the ready to depower in gusts. This has gotten me out of some tense moments.
Mike.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: Do you cleat ? [Re: Tornado] #48918
05/09/05 08:43 PM
05/09/05 08:43 PM
Bob_Curry Offline
Bob_Curry  Offline
On the F17, I cleat the main upwind only to let my hand take a break from the grinding. On distance races, cleat for 5 minutes with 5 minutes of grinding following that sequence until the angles change. It's called pacing and the older I get the more "pacing" I do. Downwind, cleat the main and provide small inputs to either twist the main or tighten the leech. Of course when it's windy, it's never cleated except for downwind! Cleats are your friend!!(and your crew!)
Bob
Re: Do you cleat ? [Re: Bob_Curry] #48919
05/09/05 08:57 PM
05/09/05 08:57 PM
North Carolina
hrtsailor Offline
hrtsailor  Offline
North Carolina
I always cleat the main and jib. I even cleat while I am out on the wire but the second the hull starts to rise I uncleat. The main sheet has to be across my legs or in my hand. The adjustment of the angle of the cleat is very important. I set it so when on the wire, I have to raise the line pretty high to cleat and a straight horizontal pull will uncleat it. Since I single hand a lot I leave the jib cleated. I seldom go over and have been sailing this boat for 20 years.
Howard
Re: Do you cleat ? [Re: hrtsailor] #48920
05/09/05 09:00 PM
05/09/05 09:00 PM
North Carolina
hrtsailor Offline
hrtsailor  Offline
North Carolina
I forgot to add on the above post that I sail a Hobie 16.
Howard
Re: Do you cleat ? [Re: scooby_simon] #48921
05/09/05 09:17 PM
05/09/05 09:17 PM
Panama City, Florida
Redtwin Offline
Redtwin  Offline
On my NAcra 5.2 I very very rarely will cleat the main. If I am singlehanding, which is most of the time, I will actually let the main luff if I have a second task that needs to be done. Of course, I wouldn't be able to do this racing, but on a daysail, I just allow the boat to slow up.
Rob
Nacra 5.2
Panama City
Rob V. Nacra 5.2 Panama City
Re: Do you cleat ? [Re: Redtwin] #48922
05/10/05 07:01 AM
05/10/05 07:01 AM
Dublin, Ireland
Dermot Offline
Dermot  Offline
Dublin, Ireland
I race most of the time and always cleat the main. As Howard said, I have the angle adjusted so that I have to raise my hand quite a bit to cleat it. Then as the gust hits I uncleat (the slightest tug does it) - I do not ease the main unless I have to, just uncleat - then cleat again when the danger is past. If you do not have your main in tight, you will not point to well. The same with the jib - my crew would always have it cleated and only release it if a very strong gust hits, or to re-adjust it if the wind strength changes.
I always have the mainsheet in my hand, except when using the traveller downwind. I pitchpole once or twice a year, but cannot remember when I last capsized on a beat.
Dermot
Catapult 265
Re: Do you cleat ? [Re: Dermot] #48923
05/10/05 07:34 AM
05/10/05 07:34 AM
Bradenton, FL
Sycho15 Offline
Sycho15  Offline
Bradenton, FL
I single-hand a sloop-rigged G-Cat 5.7M. I keep pretty much everything cleated most of the time. The Main and Traveler are on the same sheet, which gets draped over my rear leg when trapezing. The jibsheet gets draped over my forward leg. Sometimes I'm adjusting everything and trying to steer at the same time, while flying, and that gets pretty interesting. I do have the cleats adjusted pretty high so they uncleat with just a little tug..
I mostly daysail and am not as concerned with getting every fraction of a knot out of my boat as I am with having fun and flying it high along the beach for the girls to see
Re: Do you cleat ? [Re: Dermot] #48924
05/10/05 09:38 AM
05/10/05 09:38 AM
brobru Offline
brobru  Offline
Hello All,
What works best for me, as a Uni -solo sailer in the Trade Winds is CLEAT AND NEVER TOUCH IT.
I was coached to do this, and it works! The technique told me, on this forum, was 'take the mainsheet with both hands, arch your back,bend your knees, pull till it hurts, cleat it'
This is after one sets the formula of downhaul,mast rotation, d-board height and traveller.
Of course, your diamond wire adjustment has been set on the beach, for the general wind condition of that day.
There are some involved discussions on the F-16 forum about this stuff.
As I recall, there is a very in depth posting by an Aussie T4.9 Uni champ with tremendous and detailed settings. I believe he sails with the mainsheet cleat taken OFF the boat and he sets up his mainsheet blocks differently. If I have this correct, you would have to check, his exit block ( where the mainsheet exits the pully system to your hand) is set up at the boom,......not the traveller!
..whatever works for you and makes you a winner!
regards,
Bruce
St. Croix
I-17 normal
ps. The exception is the extreme life threatening condition...then anything goes to save yourself and your boat.
0 registered members (), 582 guests, and 43 spiders.
