| Always
[Re: scooby_simon]
#48925 05/10/05 10:09 AM 05/10/05 10:09 AM |
Posts: 851 US Western Continental Shelf | When sailing solo and when sailing with crew, my mainsheet is nearly always cleated. The few occasions when it is uncleated are during a screaming broad reach with main and jib set (no spinnaker).
GARY
Santa Monica Bay Mystere 6.0 "Whisk" <--- R.I.P. | | | Re: it depends on alot of things
[Re: hobiegary]
#48926 05/10/05 02:18 PM 05/10/05 02:18 PM |
Posts: 390 | There are several issues which affect when or how much the skipper cleats the main.
Along with the varying courses, water conditions, and wind strengths, there are some fixed differences.
Different skipper sizes and strengths. A bigger/stronger skipper would be able to play(grind) more often than a weaker one.
Different size mainsails. A Hobie 16 is easier to play than a Hobie 20.
Different mainsheet purchases. A 10:1 is easier to play than an 8:1, with the same size main.
So an average strength sailor who plays the 10:1 mainsheet on an A Class would probably have to do alot of cleating on a 7:1 Hobie 20.
Ideally, in flat water and steady breeze, you could set the downhaul, outhaul, mast rotation, traveler and cleat the main and just steer the boat.
The only reasons not to cleat are needing to work(pump, grind) the main for more speed in gusty, shifty conditions and fear of flipping. | | | Re: Do you cleat ?
[Re: brobru]
#48928 05/10/05 05:00 PM 05/10/05 05:00 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen
Posts: 1,037 Central California | As I recall, there is a very in depth posting by an Aussie T4.9 Uni champ with tremendous and detailed settings. I believe he sails with the mainsheet cleat taken OFF the boat and he sets up his mainsheet blocks differently. If I have this correct, you would have to check, his exit block ( where the mainsheet exits the pully system to your hand) is set up at the boom,......not the traveller! And Glenn Ashby is his name
| | | Re: Do you cleat ?
[Re: scooby_simon]
#48929 05/10/05 08:45 PM 05/10/05 08:45 PM |
Posts: 264 Long Island, NY | I handle the main on my Prindle 19 according to the situation at hand. Is my crew experienced? Is it very gusty? Am I tired after a long time in the wire fighting the heavy air? Concentrating on reading the gusts coming across the water and having an attentive crew cranking on the downhaul at the appropriate times goes a long way to allowing me to keep the main cleated when I need to give my arm a rest. However, there have been times when I wished I had arms like Hulk Hogan.
G Gove
Blade #728
Long Island, New Yawk
| | | Re: Do you cleat ?
[Re: wyatt]
#48931 05/12/05 05:17 AM 05/12/05 05:17 AM |
Joined: Feb 2004 Posts: 3,528 Looking for a Job, I got credi... scooby_simon OP Hull Flying, Snow Sliding.... |
Posts: 3,528 Looking for a Job, I got credi... | I've always used 7:1 or 8:1 and always play the main. Just cannot feel that I can sail may fastest without the feel of uncleated - also, it gets you fit and strong quick
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Always
[Re: hobiegary]
#48933 05/19/05 08:58 AM 05/19/05 08:58 AM |
Posts: 3 | I had always sailed my Prindle 18 with jib and main cleated bearing off or heading up in gusts or lulls. Sunday I went out single handed on the Barnegat Bay in 10 knots with ocassional sudden gust to 15 + knots. I played the main sheet the whole time instead of altering course when the wind speed changed. I noticed a big increase in boat speed. Thanks to all for the tip. Doug
Doug Kilgore
Prindle 18 # 0073
| | | Re: Always
[Re: Robi]
#48935 05/19/05 01:48 PM 05/19/05 01:48 PM |
I just upgraded my mainsheet from 1:6 to 1:7 and it does make a difference. However I have also tapered my mainsheet before that and that made a bigger difference. Now I have both and I think I will stay at that. To be precise I used a swiftcord hollow line as mantle and ran a 3 mm dyneema (spectra ?) line as core through it. Only partly. Than I stitched it and tapered it. Now I have 500 kg high tensile and flexible 3 mm line running through my blocks and a 8 to 9 mm soft comfortable section that runs over the ratchet and that you hold on you hand. I'm pretty happy with that.
You may want to consider going the same way it.
Also I do cleat the main when conditions allow. I prefer a crew working the mainsheet and hold the traveller line as a safety.
WOuter
| | | Sorry, can you rephrased that for me ?
[Re: Robi]
#48937 05/19/05 03:46 PM 05/19/05 03:46 PM |
Posts: 9,582 North-West Europe | Sorry, can you rephrased that for me ?
I really have no idea of what you are talking about.
| | | Re: Always
[Re: Wouter]
#48938 05/19/05 04:03 PM 05/19/05 04:03 PM |
Posts: 2,718 St Petersburg FL | I just upgraded my mainsheet from 1:6 to 1:7 and it does make a difference. However I have also tapered my mainsheet before that and that made a bigger difference. You are talking about tapering your mainsheet. How long was the taper? and where did you taper from? | | | Re: Sorry, can you rephrased that for me ?
[Re: Wouter]
#48939 05/19/05 04:28 PM 05/19/05 04:28 PM |
Posts: 3,906 Clermont, FL, USA | You said you tapered your mainsheet. He is asking how much cover you removed. For example, I remove 11 feet of cover when I taper my mainsheet for my N20.
Dave
| | | Okay ...
[Re: David Ingram]
#48940 05/19/05 04:53 PM 05/19/05 04:53 PM |
Posts: 9,582 North-West Europe | Okay. One point though, in my first post I wrote :"To be precise I used a swiftcord hollow line as mantle and ran a 3 mm dyneema (spectra ?) line as core through it. Only partly. Than I stitched it and tapered it"
So I didn't remove any cover. I bought two different lines. One section of swiftcord line (this had no inner core); and some 3 mm high tensile line (Dyneema/spectra). I then ran the 3 mm line through the "tube-like" line that swiftcord (D12) is. I then stitched it in place on both ends but after letting the swiftcord grip itself along the inner 3 mm line. I than cut away individual strands of teh swift cord weave and stitched the remaining strands in place. This will give you a nice taper over about an inch. I think I left some 2.5 mtr of 3 mm line un-swiftcorded; thinking that I could always trim it. It turns out that this was about the right length for a 1:7 system on my boat. However, guys, each boat/sail combo can be different so you just have to measure what you need and give yourself some margin that you may trim of later.
Pretty much I rigged my mainsheet system at home and from memory moved the blocks apart to the minimum distance that they would have when fully sheeting my mainsail. I then measured the distance used up in the system when the taper was just past the ratchet wheel. This ratchet doesn't grip 3 mm line very well so wanted to have the 9 mm line there, especially when fully sheeted = max load. Best advice I can give you is to rig your boat sheet it to the max, mark you sheet line, take the line out and use this measured distance as the require length of line after the taper.
I also got another idea. Next time I will buy a full length Swiftcord line of 6 mm (mainsheet and traveller system combined) and run the 3 mm line ( as a core) only through the first 2.5 mtr of the swiftcord. Than sticht the end into place. Now I will have a continiously line that goes from a 3 mm section that runs through most of the blocks to 9 mm sections that you hold in your hand when sheeting the main to 6 mm section that runs through the traveller system which in turn will have a 3 mm line insert in its end to make up the spit tail that will help centre the traveller better. I found these diameters give the best handling of the named systems, with a comfortable grip and for the lowest weight. My mainsheet line is noticeably lighter then the standard 9 to 10 mm lines manufacturers use. I'm think about doing a similar thing for my spi halyard and spi sheet. Here the intend is to thicken the line locally where it must hold in a cleat or ratchet block while keeping the remainder of the line flexible and small/light.
I'm think about using 4 mm swiftcord for the spi halyard and only thicken the halyard to 5 or 6 mm at the points were you need to pull hard on it (the last bit) and where you cleat it.
Tricks like these you can perform with lines where you can only remove the outer mantle. Mostly because the cores are to slippery to hold.
I will try to make a few digital pictures and post them.
[Re: MauganN20]
#48942 05/20/05 11:43 AM 05/20/05 11:43 AM |
Posts: 12,310 South Carolina | We need pics of Jake's "gauntlet" It's still under development and the design is a bit unprotected at the moment...no pics yet - give me another month....I promise more details then.
Jake Kohl | | |
1 registered members (basket.case),
483
guests, and 25
