Always [Re: scooby_simon] #48925
05/10/05 10:09 AM
05/10/05 10:09 AM
US Western Continental Shelf
hobiegary Offline
hobiegary  Offline
When sailing solo and when sailing with crew, my mainsheet is nearly always cleated. The few occasions when it is uncleated are during a screaming broad reach with main and jib set (no spinnaker).
GARY
Santa Monica Bay
Re: it depends on alot of things [Re: hobiegary] #48926
05/10/05 02:18 PM
05/10/05 02:18 PM
samevans Offline
samevans  Offline
There are several issues which affect when or how much the skipper cleats the main.
Along with the varying courses, water conditions, and wind strengths, there are some fixed differences.
Different skipper sizes and strengths.
A bigger/stronger skipper would be able to play(grind) more often than a weaker one.
Different size mainsails.
A Hobie 16 is easier to play than a Hobie 20.
Different mainsheet purchases.
A 10:1 is easier to play than an 8:1, with the same size main.
So an average strength sailor who plays the 10:1 mainsheet on an A Class would probably have to do alot of cleating on a 7:1 Hobie 20.
Ideally, in flat water and steady breeze, you could set the downhaul, outhaul, mast rotation, traveler and cleat the main and just steer the boat.
The only reasons not to cleat are needing to work(pump, grind) the main for more speed in gusty, shifty conditions and fear of flipping.
Thass pretty wacky [Re: scooby_simon] #48927
05/10/05 04:22 PM
05/10/05 04:22 PM
Gulf Coast
tami Offline
tami  Offline
Gulf Coast
My ol' man and I both cleat our mains and play the traveller. That is to say, I may or may not cleat the traveller, but yeah I'll whang in on the main.
Advice was taken from a very experienced sailor who suggested that 'should shackle the main to the traveller and just play the traveller.'
sea ya
tami
Re: Do you cleat ? [Re: brobru] #48928
05/10/05 05:00 PM
05/10/05 05:00 PM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
As I recall, there is a very in depth posting by an Aussie T4.9 Uni champ with tremendous and detailed settings. I believe he sails with the mainsheet cleat taken OFF the boat and he sets up his mainsheet blocks differently. If I have this correct, you would have to check, his exit block ( where the mainsheet exits the pully system to your hand) is set up at the boom,......not the traveller!
And Glenn Ashby is his name
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: Do you cleat ? [Re: scooby_simon] #48929
05/10/05 08:45 PM
05/10/05 08:45 PM
Long Island, NY
gregP19 Offline
gregP19  Offline
Long Island, NY
I handle the main on my Prindle 19 according to the situation at hand. Is my crew experienced? Is it very gusty? Am I tired after a long time in the wire fighting the heavy air? Concentrating on reading the gusts coming across the water and having an attentive crew cranking on the downhaul at the appropriate times goes a long way to allowing me to keep the main cleated when I need to give my arm a rest. However, there have been times when I wished I had arms like Hulk Hogan.
Re: Do you cleat ? [Re: scooby_simon] #48930
05/11/05 03:31 PM
05/11/05 03:31 PM
Western New York
wyatt Offline
wyatt  Offline
Western New York
I sail alone most of the time, but even if I have someone else on the boat, I'll always have the jib (oschen blocks) cleated and will play the main (cleated) with the oschen blocks in the puffs. I'm fairly strong, but if I tried to hold my TheMightyHobie18 magnum with a 6:1 uncleated all the time in anything over 12 k, I'd be exhausted.
I'd rather concentrate on the driving and get my head out of the boat.
Re: Do you cleat ? [Re: wyatt] #48931
05/12/05 05:17 AM
05/12/05 05:17 AM
scooby_simon Offline OP
I've always used 7:1 or 8:1 and always play the main. Just cannot feel that I can sail may fastest without the feel of uncleated - also, it gets you fit and strong quick
Re: Do you cleat ? [Re: scooby_simon] #48932
05/17/05 03:55 AM
05/17/05 03:55 AM
Brisbane Queensland- Australia
Q
Qb2 Offline
Qb2  Offline
Q
on both my 14 and 18 foot cats when going to windward, jib and main both cleated, when reaching main/jib cleated, play the traveller and go for the mainsheet when things get dicey, uncleat the main for downwind in moderate to heavy air. The Aussie 14 foot Maricat was sudden death downwind if you buried a bow and couldn't unsheet in a hurry.
A comment about a previous post where the skipper wraps the mainsheet around his hand, letting loops off to ease it. A colleague fell off trapeze on his 18 footer at speed and got dragged behind the cat for some distance with the sheet severely injuring his forearm. He didn't break anything, it just felt like it. I think he got one loop over the other which effectively tied him to the cat until it stopped. I never looped the sheet around my arm as a result, but had it ready to run out through my fingers.
Re: Always [Re: hobiegary] #48933
05/19/05 08:58 AM
05/19/05 08:58 AM
windwardrail Offline
I had always sailed my Prindle 18 with jib and main cleated bearing off or heading up in gusts or lulls. Sunday I went out single handed on the Barnegat Bay in 10 knots with ocassional sudden gust to 15 + knots. I played the main sheet the whole time instead of altering course when the wind speed changed. I noticed a big increase in boat speed.
Thanks to all for the tip.
Doug
Doug Kilgore Prindle 18 # 0073
Re: Always [Re: windwardrail] #48934
05/19/05 10:33 AM
05/19/05 10:33 AM
Yes, this thread has made me double think my technique. Now I am considering upgarding my 6:1 to a 7:1 mainsheet. Just to ease the load a bit.
Re: Always [Re: Robi] #48935
05/19/05 01:48 PM
05/19/05 01:48 PM
I just upgraded my mainsheet from 1:6 to 1:7 and it does make a difference. However I have also tapered my mainsheet before that and that made a bigger difference. Now I have both and I think I will stay at that. To be precise I used a swiftcord hollow line as mantle and ran a 3 mm dyneema (spectra ?) line as core through it. Only partly. Than I stitched it and tapered it. Now I have 500 kg high tensile and flexible 3 mm line running through my blocks and a 8 to 9 mm soft comfortable section that runs over the ratchet and that you hold on you hand. I'm pretty happy with that.
You may want to consider going the same way it.
Also I do cleat the main when conditions allow. I prefer a crew working the mainsheet and hold the traveller line as a safety.
WOuter
Re: Always [Re: Wouter] #48936
05/19/05 03:29 PM
05/19/05 03:29 PM
How far out did you taper a 7:1 from the very tip of the inside section of the mainsheet?
Sorry, can you rephrased that for me ? [Re: Robi] #48937
05/19/05 03:46 PM
05/19/05 03:46 PM
I really have no idea of what you are talking about.
Re: Always [Re: Wouter] #48938
05/19/05 04:03 PM
05/19/05 04:03 PM
You are talking about tapering your mainsheet. How long was the taper? and where did you taper from?
Re: Sorry, can you rephrased that for me ? [Re: Wouter] #48939
05/19/05 04:28 PM
05/19/05 04:28 PM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
You said you tapered your mainsheet. He is asking how much cover you removed. For example, I remove 11 feet of cover when I taper my mainsheet for my N20.
Dave
F18 USA 242
http://www.solarwind.solar
Okay ... [Re: David Ingram] #48940
05/19/05 04:53 PM
05/19/05 04:53 PM
Okay. One point though, in my first post I wrote :"To be precise I used a swiftcord hollow line as mantle and ran a 3 mm dyneema (spectra ?) line as core through it. Only partly. Than I stitched it and tapered it"
So I didn't remove any cover. I bought two different lines. One section of swiftcord line (this had no inner core); and some 3 mm high tensile line (Dyneema/spectra). I then ran the 3 mm line through the "tube-like" line that swiftcord (D12) is. I then stitched it in place on both ends but after letting the swiftcord grip itself along the inner 3 mm line. I than cut away individual strands of teh swift cord weave and stitched the remaining strands in place. This will give you a nice taper over about an inch. I think I left some 2.5 mtr of 3 mm line un-swiftcorded; thinking that I could always trim it. It turns out that this was about the right length for a 1:7 system on my boat. However, guys, each boat/sail combo can be different so you just have to measure what you need and give yourself some margin that you may trim of later.
Pretty much I rigged my mainsheet system at home and from memory moved the blocks apart to the minimum distance that they would have when fully sheeting my mainsail. I then measured the distance used up in the system when the taper was just past the ratchet wheel. This ratchet doesn't grip 3 mm line very well so wanted to have the 9 mm line there, especially when fully sheeted = max load. Best advice I can give you is to rig your boat sheet it to the max, mark you sheet line, take the line out and use this measured distance as the require length of line after the taper.
I also got another idea. Next time I will buy a full length Swiftcord line of 6 mm (mainsheet and traveller system combined) and run the 3 mm line ( as a core) only through the first 2.5 mtr of the swiftcord. Than sticht the end into place. Now I will have a continiously line that goes from a 3 mm section that runs through most of the blocks to 9 mm sections that you hold in your hand when sheeting the main to 6 mm section that runs through the traveller system which in turn will have a 3 mm line insert in its end to make up the spit tail that will help centre the traveller better. I found these diameters give the best handling of the named systems, with a comfortable grip and for the lowest weight. My mainsheet line is noticeably lighter then the standard 9 to 10 mm lines manufacturers use. I'm think about doing a similar thing for my spi halyard and spi sheet. Here the intend is to thicken the line locally where it must hold in a cleat or ratchet block while keeping the remainder of the line flexible and small/light.
I'm think about using 4 mm swiftcord for the spi halyard and only thicken the halyard to 5 or 6 mm at the points were you need to pull hard on it (the last bit) and where you cleat it.
Tricks like these you can perform with lines where you can only remove the outer mantle. Mostly because the cores are to slippery to hold.
I will try to make a few digital pictures and post them.
Re: Sorry, can you rephrased that for me ? [Re: David Ingram] #48941
05/20/05 11:34 AM
05/20/05 11:34 AM
This thread needs two things:
1) We need pics of Jake's "gauntlet"
and
2) We need to determine the difference between "Stripping" and "tapering"
Re: Sorry, can you rephrased that for me ? [Re: MauganN20] #48942
05/20/05 11:43 AM
05/20/05 11:43 AM
It's still under development and the design is a bit unprotected at the moment...no pics yet - give me another month....I promise more details then.
Re: Sorry, can you rephrased that for me ? [Re: Jake] #48943
05/22/05 06:26 PM
05/22/05 06:26 PM
Port Noarlunga, SA, Australia
Darryn Offline
Darryn  Offline
I use the mainsheet cleat to hold the main the majority of the time however I am constantly adjusting. Confidence in being able to uncleat is the key.
I have attach a picture of the system that came with my boat, while it has some minor dissadvantages which can be overcome with changes in procedure the advantage of being able to uncleat anytime by taking the load and easing the sheet to clear the cleat, the "flick" or a well placed kick as I skid across the tramp make it worth it.
Note how the cleat arm tracks the skipper position as you move rearwards while reaching and therefore trapeze higher as the trap wire shortens.
Darryn
1 registered members (JesperS), 759 guests, and 38 spiders.
