Length of shrouds and forestay #49029
05/11/05 10:32 AM
05/11/05 10:32 AM
sailing_in_Phuket Offline OP
I'd like to know the length of shrouds and forestay for the hobie wave.
I've bought a second hand wave but the wires seem to be too long, I may have to trim them.
Re: Length of shrouds and forestay [Re: sailing_in_Phuket] #49030
05/11/05 02:45 PM
05/11/05 02:45 PM
RickWhite Offline
RickWhite  Offline
You can contact our store by going to www.onlinemarinestore.com or by clicking on the following link: http://store.catsailor.com/tek9.asp?pg=contact
I am not in the store at the time (traveling along and reporting on the Tybee 500 race) but someone is there and can find out the lengths for you.
I know when I rig mine I use a 10 hole adjuster in the front (in lieu of the 7 hole) and remove the adjusters on the sidestays. Still there is quite a bit of slack in the rigging. I believe that is normal.
Rick
Rick White
Re: Length of shrouds and forestay [Re: RickWhite] #49031
06/17/05 11:12 AM
06/17/05 11:12 AM
midwest ( southern Kansas)
Jeff_P Offline
Jeff_P  Offline
Rick, where can some one get a 10 hole adjuster? I looked on your store but couldn't find it. Thanks Jeff
Re: Length of shrouds and forestay [Re: Jeff_P] #49032
06/17/05 12:57 PM
06/17/05 12:57 PM
RickWhite Offline
RickWhite  Offline
Sure enough, they are there. click on
http://store.catsailor.com/tek9.asp?pg=products&specific=jmoqhqqpr0
THere you will find the 7 and 10 hole shroud adjusters. I found them using the Search at the top right hand corner on the store. That seemed to be the easy way.
Good luck,
Rick
Rick White
Re: Length of shrouds and forestay [Re: RickWhite] #49033
06/17/05 02:06 PM
06/17/05 02:06 PM
Jeff_P Offline
Jeff_P  Offline
Thanks Rick, just order it now! Jeff
0 registered members (), 321 guests, and 38 spiders.
