| Re: Comptip Mast
[Re: SEISALisa]
#49220 05/12/05 10:56 AM 05/12/05 10:56 AM |
Posts: 9 | It is really quite easy to detect a comptip vs. an older full metal mast. If you look above the mast tang, you will see a seperate fiberglass section on the comptip mast. Also, the masthead for the comptip is rectangular; whereas, the masthead for the full metal mast is round. See the below pictures, and hopefully that will help. COMPTIP: FULL METAL: All the best... JAH | | | Re: Comptip Mast
[Re: mmiller]
#49224 06/13/05 01:45 PM 06/13/05 01:45 PM |
Posts: 152 Central Texas | Hmm... the comptip is not really a new design... Some people might not see it as an improvement. It will add weight to your mast in the wrong spot (up top) it ages - especially in the TX sun it modifies the bending curve of the mast abruptly. You might need one if you race - on the other hand if you buy a competitive boat (less than 10 years old) - it will come with a comptip. If you get something older and start racing the boat probably no one cares if you have a comptip.
Patrick
Patrick, Hobie 16 '85
| | | Re: Comptip Mast
[Re: yoh]
#49225 06/13/05 06:05 PM 06/13/05 06:05 PM |
Posts: 1,252 California | if you buy a competitive boat (less than 10 years old) - it will come with a comptip. Actually much older boats all had CompTips. Since 1985 these have been standard... 20 years ago. | | | Re: Comptip Mast
[Re: hrtsailor]
#49228 06/14/05 09:07 AM 06/14/05 09:07 AM |
Posts: 152 Central Texas | Howard / Matt... same here my 85 has no comptip... I have a spare mast that might be comptiped some day. Patrick
| | | Re: Comptip Mast
[Re: SEISALisa]
#49231 06/19/05 12:17 PM 06/19/05 12:17 PM |
Posts: 4,119 Northfield Mn | In 85' H-16's were made by two different companies. My 85 was made by Coleman, and has a comp-tip. I've been told that the Coleman was the better of the two, (could be heresy don't know), but I don't remember who the other manufacturer was/is.
2,548
guests, and 457
