| Re: End cap removal P19
[Re: ferminj]
#49953 05/25/05 11:32 AM 05/25/05 11:32 AM |
Posts: 284 Norfolk, VA | I don't think the end caps are iron, they should be cast aluminum. I recall that there was a rivet or screw on the bottom of the crossbar as well, so you might be missing that one. once you have made sure you have all the rivets completely drilled out, you just have to tap the end cap off with a flat head screw driver. If it has corroded and you can't get it off, you may have to break it off and get another.
Dan Berger Norfolk, VA A Cat USA139 Supercat 15
[Re: ferminj]
#49955 05/25/05 02:49 PM 05/25/05 02:49 PM | Anonymous
| Anonymous
Unregistered | I just replaced a traveler car on my P18. Just drilled out the rivets, switched cars and put the cap back on. Pic is the 'before' image. | | | Re: End cap removal P19
[Re: ferminj]
#49956 05/25/05 06:21 PM 05/25/05 06:21 PM |
Posts: 264 Long Island, NY | I've had to do the same thing you are attempting and agree with Dan. While you're back there you should check/replace the rivets holding the triangular piece of aluminum that supports the swivelling traveller cam cleats to the rear crossbar. Mine went on me while sailing last summer and it wasn't a lot of fun getting back to the beach. At least I wasn't in a race.
G Gove
Blade #728
Long Island, New Yawk
439
guests, and 51
