| Grease recommendations #5027 01/02/02 09:11 AM 01/02/02 09:11 AM |
Joined: Jul 2001 Posts: 397 Burlington, Vermont USA Kevin Rose OP
Posts: 397 Burlington, Vermont USA | Even a simple thing like grease seems to come in countless variations. Does anyone have any recommendations for the best grease to apply to beam strap bolts? (Or, perhaps the question should be, are there any lubricants that should be avoided?)
Thanks
Kevin Rose
N6.0na #215
Lake Champlain (New England's "west coast")
Burlington, Vermont
| | | Re: Grease recommendations
[Re: Kevin Rose]
#5029 01/02/02 09:45 AM 01/02/02 09:45 AM |
Posts: 833 St. Louis, MO, | Kevin,
I would use the anti-sieze grease for sparkplugs. It can be bought cheap at any autoparts store.
Mike Hill
H20 #791
Mike Hill N20 #1005
[Re: carlbohannon]
#5031 01/07/02 11:18 AM 01/07/02 11:18 AM |
Posts: 397 Burlington, Vermont USA | On a related question, are there any recommendations for best substances to prevent galvanic corrosion (dissimilar metals - in this case stainless mast rotator on aluminum spar)?
Kevin Rose
N6.0na #215
Burlington, Vermont
[Re: Kevin Rose]
#5032 01/07/02 08:33 PM 01/07/02 08:33 PM | Anonymous
| Anonymous
Unregistered | I used a teflon spacer between the mast rotator of my Dart and the aluminum mast. | | | Re: Grease recommendations
[Re: carlbohannon]
#5034 01/08/02 10:52 AM 01/08/02 10:52 AM |
Posts: 397 Burlington, Vermont USA | My problem is located at the base of the mast where the SS mast rotator is held to the aluminum spar with a SS bolt.
How about the product, Duralac? I understand that it's not available in the US, but many sailors in the UK seem to swear by it. It was designed for aircraft use. (I read that it is primarily barium chromate.)
Kevin Rose
N6.0na #215
Burlington, Vermont
[Re: carlbohannon]
#5036 01/08/02 04:33 PM 01/08/02 04:33 PM |
Posts: 12,310 South Carolina | One other thing that will help, is to apply a sacrificial anode to the corroding metal (the aluminum part). If you were to rivet a block of magnesium to the aluminum, it will in turn absorb the currents causing corrosion and it will corrode instead of the aluminum. I used to work for a gas company monitoring the sacrificial anodes (bags of magnesium chips) that were electrically connected to all the steel pipe in the ground for the same purpose. They also do the same thing for outboard motors - look at the foot of the drive, you will see a small block of sacrificial magnesium bolted to the motor to prevent the corrosion of the motor and drive.
Jake Kohl | | | Re: Grease recommendations
[Re: carlbohannon]
#5037 01/08/02 05:35 PM 01/08/02 05:35 PM |
Posts: 397 Burlington, Vermont USA | Given that there isn't much of a load on the mast rotator bolt, I think I'll try inserting bushings and washers.
Thanks for the suggestions.
Cheers,
Kevin Rose
N6.0na #215
Burlington, Vermont
504
guests, and 43
