| Re: solo stepping question
[Re: bkyser]
#50371 06/07/05 03:17 PM 06/07/05 03:17 PM |
Posts: 152 Central Texas | I used the trap wires for balance purposes a few times. IIRC i tied to the cornercastings rather than to the pylons. I did not include much slack in my setup, since the pylons are in line with the mast base. There is a slight difference in height between mast base and corner casting. This is the amount of slack I would be aming for. In my setup the lines and the knots allowed for some "elasticity".
Howard... this is just a temporary setup while stepping the mast. Once the mast stays up by it self. He will use the shock cord to connect the two sides of the trap wire. Patrick
Patrick, Hobie 16 '85
[Re: hrtsailor]
#50375 06/10/05 08:50 AM 06/10/05 08:50 AM |
Posts: 152 Central Texas | There is an other pro trap wire argument... if you rigg some kind of support system (can be made up from PVC pipe) that supports the mast about a meter above the tramp, you could use a winch mounted to the trailer to raise the mast. Safe and controled - and healthy for the back.
Patrick
[Re: bkyser]
#50377 06/19/05 12:09 PM 06/19/05 12:09 PM |
Posts: 4,119 Northfield Mn | I swiped an idea from Hunter marine. I used two pieces of 3/4 plywood ripped down to 2 1/4" wide. I drilled a hole in one end on both pieces and ran a short length of rope through the holes, tied knots in the end so it doesn't slip through. I set the free ends of the plywood in the gap in the tramp at the back pylons, raise the mast and jam the rope against the mast to hold it up. This is good enough to hold it up until I get the front shroud line attached. Simple, and cheap.
[Re: bkyser]
#50378 07/19/05 09:00 AM 07/19/05 09:00 AM |
Posts: 72 Montreal , QC | Another easy way to do it is to put a log under each stern. When you solo right your mast now with your shrouds attached, the mast leans forward by gravity. Just jump down off the tramp with your forestay in hand and hook it up to the bridles. I've done it this way many times but be careful if you've raked your mast back alot. Just be careful, mine's max raked and I still do it this way if there's nobody around to hold the mast upright.
H16 '82
Tornado '88
[Re: hrtsailor]
#50380 07/20/05 06:23 AM 07/20/05 06:23 AM |
Posts: 72 Montreal , QC | Great idea Howard, I'm gonna try this next time (this week). Sounds logical and straight forward, etc. Easier than lifting stern or trying to rig a stop for the mast. Cool idea!
H16 '82
Tornado '88
14,964
guests, and 652
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online16,046 Yesterday at 04:24 PM | | |
