| shroud cable damage #50859 06/11/05 07:18 AM 06/11/05 07:18 AM | Anonymous
| Anonymous
Unregistered | How many strands of a shroud cable can be broken before you are uncomfortable using it? I just spotted 1 broken strand on one of my shroud cables and plan to go with it until the new cable arrives in the mail. Am I flirting with disaster or using good sailors common sense? | | | Re: shroud cable damage
[Re: Rolf_Nilsen]
#50861 06/11/05 07:30 AM 06/11/05 07:30 AM |
Posts: 1,911 South Florida & the Keys | I am with Rolf. I think the answer is "zero".I dismasted lst year in the Steeplechase, there was no apparent issues with the shroud and yet it blowed up!
Eric Arbogast ARC 2101 Miami Yacht Club | | | Re: shroud cable damage
[Re: arbo06]
#50862 06/11/05 07:37 AM 06/11/05 07:37 AM |
Posts: 12,310 South Carolina | I think replacing standing rigging every three years is what most recommend on the standing rigging for a saltwater sailed boat.
Jake Kohl | | | Re: shroud cable damage
#50863 06/11/05 08:35 AM 06/11/05 08:35 AM |
Posts: 3,293 Long Beach, California | Even on the schedule suggested by Jake, you should still take a good look every once in a while. I had the factory shroud on the 4.3 fail after only a year and a half. They were vinyl coated and the failure was down in the swage, so it wasn't somewhere I could easily see - I went up a size (diameter) when I replaced it and did new wires all the way around. Bottom line - if you already see a broken strand, that whole wire is done. Don't just replace the one, replace them all. Nothing is more disappointing than travelling eight hours to a regatta, losing the rig before the first race, dealing with getting the mast back on the boat, pulling the main off and rolling it up, begging some fishermen for a tow, then sitting on the beach waiting for everyone to get back.
[Re: John Williams]
#50864 06/11/05 12:22 PM 06/11/05 12:22 PM |
Posts: 122 | While we're on this subject, I would advise against using factory made wires for many boats. Some manufacturers have begun using cheap SS Wire Rope from less-than-ideal asian sources. Get them made locally using Mil/Aerospace spec wire made in the USA or EU, and genuine Mil/Aero spec thimbles, forks and etc. It won't cost any more than the factory supplied parts; mine actually cost a little less. And you can demand that the thimbles, ovals, forks and etc. are packed with Lifecaulk or 3M 5200 or similar before swaging so that water never intrudes into these anaerobic environments to eat away at the rigging; uninspected and uninspectable. This is the real reson why you change rigging so often. As for the number of wire starnds you can do without..C'mon, you're kidding, right?  Jimbo | | | Re: shroud cable damage
[Re: cyberspeed]
#50866 06/11/05 01:42 PM 06/11/05 01:42 PM | Anonymous
| Anonymous
Unregistered | Roger that. I hear your answers loud and clear! As you can tell, I am brand spankin' new to this and I'm trying to get this thing up and running without the benefit of a local experienced cat sailor to help me out. I bought the boat used, waited to get a new mast and tramp, and now I'm itching to go sailing. After waiting around for so long to get this project up and running, I certainly can and will wait just a few days longer!  Thanks again to all for the guidance. TRowe | | | Re: shroud cable damage
[Re: ]
#50873 06/16/05 12:10 PM 06/16/05 12:10 PM |
Posts: 1,200 Vancouver, BC | Went out last weekend on a Prindle 18-2. Before we put the mast up I noticed the upper port shroud had 3 broken strands right at the nicopress fitting. Though I had a pit in my stomach, we went ahead with our day sail. Winds were in the 10-12 kts range, waves not too bad. After 2.5 hours, we returned safely to shore. After the de-rigging, the shroud had 5 or 6 strands gone. I think we were luckt that day. Mike. How many strands of a shroud cable can be broken before you are uncomfortable using it? I just spotted 1 broken strand on one of my shroud cables and plan to go with it until the new cable arrives in the mail. Am I flirting with disaster or using good sailors common sense?
| | | Re: Vectran line
[Re: Rolf_Nilsen]
#50876 06/16/05 07:40 PM 06/16/05 07:40 PM |
Posts: 122 | Check this out: http://www.briontoss.com/education/archive/miscfall01.htm Seems all that nasty stretch comes from the braiding or even heavy twisting used on some types of lines. But these high modulus fibers do not like repeated bending, presumably even within their elastic potential. Thus braid or heavy twist is the only option for a beach cat that's going to be set up and taken down repeatedly. Otherwise the rope strength degrades. I guess from an engineer's perspective, beach cats do not have any 'standing' rigging; it's ALL running. Learn something new every day! Jimbo | | |
2,729
guests, and 216
