| Re: Sail Care
[Re: Mike Fahle]
#5175 01/11/02 11:04 PM 01/11/02 11:04 PM | Anonymous
| Anonymous
Unregistered | Mike:
Rick said you might know some good rules video's for 2001-2004 rules. Nice advise on sails. If you start keeping them good a start they will last a lot longer.
Doug Snell
H17 #6325
"Stress Free" | | | Re: Sail Care
[Re: Bob Klein]
#5177 01/13/02 09:04 PM 01/13/02 09:04 PM |
Joined: Jun 2001 Posts: 425 Toledo, Ohio (western end of ... Mike Fahle
Posts: 425 Toledo, Ohio (western end of ... | Hi Bob, Yes, start rolling from a middle batten - choose one that lets you roll up the head inside the sail; and, yes, you have to remove the top batten from a flat top main first. I usually slide the top batten into the second batten pocket from the top with it sticking out enough for easy retrieval. That way it is close to where I need it and hard to miss so that I do not raise the sail without putting it back in! Starting the roll from a batten makes it much easier to get a good roll going. Some sails may have battens that are at slight angles to each other so that you have to make slight adjustments as you roll the sail to keep the battens parallel but this gets easier the more you do it. In fact, I find it easier to roll the sail by myself than to have help, even on the Mystere 6.0 because I have done it hundreds of times alone and it is just second nature to me that way. Another tip: If you have a jib to roll up also it is easy to lay the jib on top of the main before you start and roll the jib up inside the main. I did not mention before that you should place sails on grass and never concrete, asphalt, stones, etc. for drying and rolling. That can be very damaging and staining. While you roll you can wipe/flick off anything on the sail(s) and check for wear and tear. | | | Re: Sail Care #5178 01/13/02 09:11 PM 01/13/02 09:11 PM |
Posts: 425 Toledo, Ohio (western end of ... | Hi Doug, U.S. Sailing has a two video set to explain the rules and they have that available on CD also. I am going to the Chicago Strictly Sail Boat Show at the end of the month and will keep an eye out for new sources. There are some good websites on the rules, at least one features interactive rules quizzes. I have concerns about their accuracy but it is certainly worth viewing at: http://www.uksailmakers.com/RulesQuiz/index.htmlDave Dellenbaugh produces an excellent racing tips newsletter that features the rules one issue each year and my favorite resource is Dave Perry's book. I will let you know if I find anything interesting at the boat show (better remind me early in February!) Mike Fahle | | | Re: Sail Care
[Re: Mike Fahle]
#5179 01/14/02 12:26 AM 01/14/02 12:26 AM | Anonymous
| Anonymous
Unregistered | Mike: Found the link to Perry's book, but not video's & cd's. Send me the page to [email protected]Thanks, Doug | | | Re: Sail Care
[Re: Mike Fahle]
#5180 01/14/02 02:25 PM 01/14/02 02:25 PM | Anonymous
| Anonymous
Unregistered | With my sail, I fold over the top in such a way that the
top batten is parallel to the rest of the battens and then
roll the sail down from there, to the foot. This way
I don't have to remove the upper batten. I also roll
the sail loose enough that I can store the jib inside
the main and feed the whole thing into the sail bag. | | |
281
guests, and 23
