| The 2-Minute Tack #51755 06/27/05 01:12 AM 06/27/05 01:12 AM |
Posts: 106 NW Washington | I need help tacking. I sail a nacra 450, 1-up and just learning. Only experience besides the 4 trips in the 450 are 12 trips in a Force 5. Here's how I do it in 5-15 knots: Sail close hauled, traveller centered (cuz I don't want to mess with it). Ease the tiller out until I'm facing the wind. Uncleat the burdened cleat and make it tight on the new side. Boat stops, not able to tack. Sometimes I drift backwards. I backwind the jib. 2 or 3 minutes later and I'm off! I've got Rick's video and don't see what I'm doing wrong. I also was surprised that I could tack better in 10 knots compared to 15. At least I know how to park  Any suggestions? Danno
Danno
| | | Re: The 2-Minute Tack
[Re: Danno]
#51758 06/27/05 06:44 AM 06/27/05 06:44 AM |
Joined: Jul 2003 Posts: 29 Netherlands Marc Woudenberg
Posts: 29 Netherlands | Having had a N450 my self, the trick is not to loose boat speed. The N450 and ist predecessor N4.5 have a keel, no daggerboard to pivot around. Turning into the tack not too abrubtly. Keep the jib out on the side of the previuous course as long as possible to pull the bows around. Only cleat it for the new course after the main flips over to the other side. The main should be sheeted in only slowly to pick up. To get you on the right tack floating backwards, apply opposite rudder. This pushes the sterns in the direction you want rather than aiming the bows. Good luck.
Marc Woudenberg T49/F16 Ned302
[Re: Danno]
#51759 06/27/05 07:11 AM 06/27/05 07:11 AM |
Posts: 12,310 South Carolina | Danno,
If your jib remains cleated and backwinded for even a second, it will stop the boat. Make sure that as soon as the jib collapses when it gets close to the wind that it is uncleated. The timing on moving the jib is important - too soon and you are loosing valuable speed into the tack - too late and the jib will push the boat backwards. As the other folks said too - don't put the tension back in the mainsheet until the boat is moving and you are moving your weight forward again. You want some twist and belly in the main while the boat is accelerating back to full speed.
Your weight placement on that boat will probably be important too. Make sure you have the crew weight as far aft as possible when tacking. This will help to lift the bows clear of the water so they don't have to push a lot of water as they turn. To see this affect exagerated, turn hard while reaching and you will see how much water the bows have to push when turning. Moving your weight back will lift the bows so the boat doesn't encounter quite as much resistance while it turns.
Jake Kohl | | | Re: The 2-Minute Tack
[Re: Danno]
#51761 06/27/05 07:52 AM 06/27/05 07:52 AM |
Posts: 887 Crofton, MD | When I had a Hobie 16, I found that in most conditions (*), backwinding the jib is a really good way to stop the boat, prolonging your tack by forcing you to sail backwards. I have found that you are better served by releasing the jib as soon as it wants to travel around the mast, then trim it on the new tack for power, not as tight as you would have it for close-hauled course at full speed. You may want to easy the main a considerable bit just after you come head-to-wind. I found that about 6’ was the right amount of sheet to let out on the Hobie 16. I believe this is important because of the change in apparent wind as my boat came through head-to-wind. It was going so much slower, although still moving forward, that if your main sheet is full on you couldn’t get down to the new tack and if you did the acceleration was slow because the top of the sail was over trimmed, way stalled!
You noted a difference between 10 and 15. It might be the wave state. Even with our dagger board boat, n6.0, in waves, big waves, we end up sailing backwards sometimes when I pick the wrong time to tack in a set of waves or the jib is cleated on the old tack for second to long. Also, any time attempting to bring the jib to the new tack side to early always, always stop us! Also, with the n6.0, I easy about a foot or so of main sheet after head-to-wind. When the wind is blowing 15, the backed jib may be stopping you much more effectively then when its only blowing 10.
(*) Your wind range with relatively flat water. I recently had two different crew on board for a race. One of them backed the jib once very appropriately during a race. The other tried to back the jib on the first few tack with my response being “Please don’t back the jib.” I think I said please the first couple of times. | | | Re: The 2-Minute Tack
[Re: Chris9]
#51762 06/27/05 10:10 AM 06/27/05 10:10 AM |
Posts: 106 NW Washington | Thanks, everybody :-)
Even though I'm cutting my teeth, it sounds like you folks sometimes stop during a turn too. Makes me feel a bit better.
Some clarification:
I pretty much ignore letting out the main until I'm on the new tack. If successful, I don't try to sail close hauled until I've got a bit of speed.
The only time I backwind the jib is when I'm stopped, not before. I unleat the jib, hold it tight until it starts luffing, then pull it tight and cleat it on the opposite side. Most the time it doesn't fill on the new tack because the boat doesn't turn that far. I do stay on the old side until the jib fills on the new side.
One thing about the jib: I'm not sure how tight to set it, so I just pull it sorta tight.
Sounds like I need to experiment with how fast to turn and keep my weight back.
Thanks so much, Danno
Danno
[Re: jollyrodgers]
#51765 06/27/05 08:41 PM 06/27/05 08:41 PM |
Posts: 106 NW Washington | Thanks, Rolf and JR.
Rolf:
I'll try letting out the main as you said. I know that's what you're supposed to do when you tack. My view is that the boat stops before there's any wind filling the sail. Or if it does fill with wind, then I should be well into the new tack and could let it out then.
JR:
Thanks for another idea.
Danno
Danno
[Re: jollyrodgers]
#51766 06/27/05 09:15 PM 06/27/05 09:15 PM |
Posts: 6,049 Sebring, Florida. | Since you are not racing, why not do the fun and easy thing, go for a gybe instead of a tack? You just bear off, ease the main way out, get some speed and complete the turn, flip the jib over, trim in the main and off you go.
If you must tack, make sure you keep the tiller hard over until the bows are way off the wind and the main is eased out quite a bit, get the jib over and in asap to help get the bows down, don't trim in the main until you have some speed to steer with or it will round right back up and you will be parked again, but when that happens, you just reverse the rudders so the sterns go the other way, then again, ease the main and get some speed up on the new tack before you trim it in.
Blade F16 #777
[Re: Danno]
#51767 06/28/05 07:50 AM 06/28/05 07:50 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Since you do have the video on roll tacking, you might want to review it again. It sounds like you are not turning the rudders hard enough. That and not releasing the mainsheet when head to wind. Both of these are major errors that will get you head to wind and stop.
Review: You must be sailing close-hauled with main tight. Start your turn with steadily increasing pressure on the helm (If you jam it over, it will stop the boat; if you steer to easily, you will blow off all your speed before you make it through the turn)
And with the mainsheet tight, you are using the tight leech of the main to weathervane your turn into the wind. You must then release the mainsheet a foot or two when you go through the eye of the wind. That eases the leech of the sail -- otherwise it will want to continue weathervaning directly into the wind. That also allows the mast to straighten, making the sail fuller -- this is akin to a race car driver shifting down into 2nd gear from high when going through a tight turn. By easing the main sheet, you are making the sail fuller and more powerful to come out of the turn.
Hope this helps. If not go watch the video some more. Good luck, Rick | | | Re: The 2-Minute Tack
[Re: RickWhite]
#51768 06/28/05 07:59 AM 06/28/05 07:59 AM | Anonymous
| Anonymous
Unregistered | Hey speaking of the video, didn't Tim tell us the DVD version would be out in April or May. What's the latest on that?
Mark. | | | Re: The 2-Minute Tack
[Re: Andinista]
#51770 06/28/05 08:56 AM 06/28/05 08:56 AM |
Posts: 106 NW Washington | Thanks, again, guys!
The video I have is 'total boat handling'. Does the 'upwind sailing' cover tacking single-handed?
Danno
[Re: Andinista]
#51771 06/28/05 10:14 AM 06/28/05 10:14 AM |
Posts: 12,310 South Carolina | Andinista,
That is probably some good advice until the rudder problems are ironed out. Leaving the jib cleated on the wrong side will help to turn the bows through the wind - but it makes for a very slow tack and reduces boat speed dramatically.
Jake Kohl | | |
11,486
guests, and 392
