| Re: hulls & pylons
[Re: newbiesailor]
#53678 07/21/05 11:41 AM 07/21/05 11:41 AM |
Posts: 29 Banner Elk, NC | It depends a lot on the conditions, but a "gallon or two" seems a bit much. I've read that a cup or two is normal. I've yet to get any H2O in my hulls since renovation, but there's little wind here. What did you do to "seal" your hulls?
83' Hobie 16
| | | Re: hulls & pylons
[Re: newbiesailor]
#53679 07/21/05 11:51 AM 07/21/05 11:51 AM |
Posts: 152 Central Texas | common leaks are around the pylon to hull seam, the deck to hull seam, the drain housing or the O ring, and sometimes the foam plug inside the pylons. Use a shop vac in reversed mode (blowing) to blow air inside the hulls - use water with some soap to find the leaks.
Patrick
Patrick, Hobie 16 '85
| | | Re: hulls & pylons
[Re: aaronhoy]
#53682 07/22/05 09:22 AM 07/22/05 09:22 AM |
Posts: 152 Central Texas | I would not seal the pylon to corner casting... not that it would cause much problems - more because it will not fix the real problem for long... Thake the frame off and check out the foam plugs... The ones in the front pylon have ventilation tubes. The rear pylons could (depends on year)have lead in them. Replace the foam if it is questionable (water noodle foam works well) - also consider taking the lead out (mine - '85 - did not have lead in the pylons). Nylon hut with crack... I guess this is common. Replacing them with SS lock nuts might not work well since the bolt is not long enough to reach the nylon insert of the lock nut. Do not over torque what ever nut you use - IIRC this was the reason why Hobie used the nylon nut in the first place.
Patrick
| | | Re: hulls & pylons
[Re: newbiesailor]
#53685 07/28/05 03:52 PM 07/28/05 03:52 PM |
Posts: 493 Minnesota | If you use the noodle with the hole, you have defeated the purpose of the foam: ...to keep the water out.
The ventalation tube in the stock foam is very narrow. When it clogs, you need to use a thin wire to clean it out. Folks that have hulls that pressurize in the heat, need to clean this tube out to allow air to vent. Save this tube, and put it in your new piece of SOLID foam. Because it is so narrow, tha amount of water it lets in is very tiny.
799
guests, and 916
