| Water in the mast, with positive air pressure... #54036 07/29/05 04:47 AM 07/29/05 04:47 AM |
Posts: 145 Cheshire, UK | My friend's cat (Nacra F18) had water in the mast. After a capsize recovery problem he decided it was time to remedy the situation and I wanted to help so I could have someone to race against. When he drilled out a rivet, there was the definite escape of air under pressure - I heard it from 10 metres away. When we drained it, we got something like a pint of water out.
1. Is that enough to worry about? 2. How can there be water in there AND positive air pressure? We'd expect that the air pressure would be equalised if there was even the smallest leak. Which begs the question as to how the water got in.
Any thoughts? Especially on how to find a leak that appears to be able to resist positive air pressure while letting water in!
We did find that two cleats low down the mast looked to have the white deposit typical after a water leak, and they were not fully flush with the mast (too concave to be a fit against the relatively flat surface), so had been fitted with a lot of sealant to fill the gap. Needless to say these look suspicious and will be replaced. But we still can't understand how there was air pressure and water in the mast.
Puzzled Simon
Simon Shadow 067 | | |
210
guests, and 53
