| Re: weight distribution and beach wheels
[Re: aaronhoy]
#54319 08/02/05 11:55 AM 08/02/05 11:55 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | The center of balance for your particular boat IS where it IS. You put the wheels under the boat until you find the perfect balance point. Nobody can answer that question for you. For a Hobie 18 the balance point was at the shrouds. For the Hobie Wave it is well back from the shrouds, between the two molded-in seats. If you think you know the perfect balance point for your boat and the back end is still too heavy, maybe it is full of water. | | | Re: weight distribution and beach wheels
[Re: aaronhoy]
#54323 08/03/05 10:19 AM 08/03/05 10:19 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | I hate to suggest something that might seem so obvious, but maybe it is not the boat that is the problem but the beach wheels themselves. Every time one of our boats gets hard to roll around, it is because one or both of the beach wheels are either flat or low on air. This has been a recurring problem with all three types of beach wheels we own. If the wheels are fully inflated, you certainly should be able to find a balance point somewhere. | | | Re: weight distribution and beach wheels
[Re: Mary]
#54324 08/03/05 01:22 PM 08/03/05 01:22 PM |
Joined: Jun 2005 Posts: 90 Saint Simons Island, GA aaronhoy OP
Posts: 90 Saint Simons Island, GA | I, unfortunately, have the crappy plastic type, so they dont inflate, they just hold up under their own structural strength. I've used inflatable ones before and they are indeed much better than the plasic ones even when one of the wheels is low on air. the problem here though is that the boat is not shifting the way it used to when I pull down the front. Usually when I pull down on the front cable stay, once I get the boat leaning forward rather than back, the wheels slip backwards a little and that puts the weight forward so I can pull the thing around. Now though, they dont slide back on their own, and even when I move them back manually, the weight is still behind the wheels. | | | Re: weight distribution and beach wheels
[Re: aaronhoy]
#54325 08/03/05 04:21 PM 08/03/05 04:21 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Do you think it might be possible to lengthen the lines that attach to the stays so the wheels could go back farther to reach the balance point? You are kidding about all this, aren't you? P.S. One last thing. If you are taking those hard plastic wheels into the water, maybe the wheels themselves are full of water -- although I'm not sure how that would affect your situation.
[Re: JaimeZX]
#54331 08/05/05 12:28 PM 08/05/05 12:28 PM |
Joined: Apr 2005 Posts: 292 Ontario, Canada Captain_Dave
Posts: 292 Ontario, Canada | Aaronhoy, Cool drawing for sure. But, I have to agree with Mary, you are kidding right? I mean, finding the center of gravity (balance point) in this instance is absolutely childs play - regardless of whether or not it has moved from where it was located previously. Just move the wheels until you find it...period. What else can people say on this? This is one of those problems that truly is...no problem at all...unless... The only thing you should be concerned about is WHY your C of G has apparently moved. It can only be one thing - weight. Weight has been added, subtracted or moved on your boat. If there is no apparent water in your boat - and you haven`t altered your setup - and the repairs you made did not add a significant amount of weight, then you may have a bad leak somewhere (possibly internal) and major water penetration into the core of your hull (very bad). If core H2O penetration is the case, then your description of having to pull down excessively at the bridles indicates it is likely towards the stern of one of your hulls. Percuss (gently tap) the hulls thoroughly with a small rubber hammer or similar object and look for changes in the sound you hear. Compare these sounds bilaterally (both hulls, same approximate location) and listen for differences. H2O penetration will yield duller more "thud-like" sounds by comparison. If you find this, you have a major problem that will require serious "boat surgery" and many months to fix. Also, without knowing your particular climate, do not let those hulls freeze this winter or you will be looking for a new boat in the spring. If you know a marine surveyor who will give you a cost break, have him/her examine your hulls with a moisture sensor and give you an opinion. Core penetration may not be worth fixing if it is bad enough to change your balance point so much. Dave
[Re: aaronhoy]
#54335 08/05/05 01:36 PM 08/05/05 01:36 PM |
As a rough estimate, and judging by the core thickness, if your ENTIRE core became saturated it could probably double the weight of your hulls. However, completely saturating all of the core material in a boat would be a rare instance for sure. The point here is that the weight gain from water could be very significant while your hulls appear completely dry inside and out.
As for why it is (may be) occurring only at the stern. This requires some visualization of "wicking". If the leak is near the stern, the water will enter there slowly and persistently. The actual leak can sometimes be very, very small. The water wicks in at that location and then spreads out. This is the chemical nature of water (look up osmotic and oncotic pressures/gradients for more understanding). Without sounding too dramatic, this kind of water intrusion can be a boaters` nightmare. It is the number one reason bigger boats are usually surveyed before being purchased. A boat may look great in every sense, but be a disaster because of this unseen problem. I have been a powerboater for years, and this is the one worry that can keep me up at night.
I do not know how commonly core H2O penetration occurs with the H16. I know the H16 is, in fact, a cored construction. Therefore, it can happen. But, since these boats are generally stored on land, it must occur to a lessor degree than boats that reside in the water.
Dave
[Re: aaronhoy]
#54337 08/05/05 04:46 PM 08/05/05 04:46 PM |
Posts: 292 Ontario, Canada | It is difficult to say. I would generally say that it would take more time than that to saturate any significant portion of your cores. But, this is just a guess for your particular situation - assuming this is even your problem to begin with. My personal experience with the human observation of various "problems" is that we often perceive things to have developed quickly when in fact they developed quite slowly over time - unnoticed. Then, once the problem reaches some noticable threshold, we QUICKLY become aware of them - a very different situation altogether that tends to lead us to an incorrect conclusion.
In any event, rather than continue to speculate, you need to determine if water penetration is, in fact, your particular problem here. Then you can report back to this forum if you wish.
Dave
521
guests, and 47
