| Re: Sealing a Hobie 16 mast
[Re: Kappie]
#55266 08/17/05 09:15 AM 08/17/05 09:15 AM |
Posts: 152 Central Texas | Hi Heinz.... come to the dark site... move to the Hobie 14/16 category within this forum. Both, the solo sailing and the sealing of masts have been discussed there. In short... Identify the leak (most likely it is the foam plug under the mast top pulley) Drill out the rivets. Use a new foam plug if required or reseal (silicon) the old. After a good breakfast pop those rivets back in place (oh… use the sleeves to make the rivets watertight).
Patrick
Patrick, Hobie 16 '85
[Re: rbj]
#55268 08/18/05 05:37 PM 08/18/05 05:37 PM |
Posts: 152 Central Texas | "use the sleeves to make the rivets watertight" I guess it is not really accurate to say that the sleeve would make the rivet watertight but... The sleeves enclose the rivet. After the rivet has expanded water can only enter in that small area between sleeve and rivet. At least no water can enter the mast. The sleeve looks a bit like the metal cap at the back of a retractable pen. Check out the Murray catalog for a pic - I think I have seen them there.
Patrick
[Re: rbj]
#55270 08/19/05 02:50 PM 08/19/05 02:50 PM |
Posts: 306 St. Louis, MO | I have also seen a polymer patch placed over the area of the mast to be riveted to help create a seal between the mast surface the area around the rivet head. When the rivet is tightend the polymer is pinched bewtween the river head and the mast surface. I have still gone back and siliconed the rivets. Not pretty but it works.
Nick
Current Boat Looking for one
288
guests, and 19
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online2,167 Dec 19th, 2022 | | | |
